What gear to park in?
Old Jun 9, 2006 | 02:04 AM
Fastwhiteguy09's Avatar
cant you just take it to the dealer and have them adjust the e brake then?
Old Jun 9, 2006 | 02:05 AM
b-spot's Avatar
For those that say 1st for an up slope and reverse for a down slope, your engine can turn both directions your car can go backwards in first gear when its turned off. The reason you leave it in gear is because all of the friction in your engine/trans will hold the car. First is best because for the same distance it revs your engine the most and provides the most friction.
Old Jun 9, 2006 | 02:20 AM
alleycat58's Avatar
Apparantly not. I've had mine in 3 different times and all they do is adjust the cable. I told them that wasn't the problem, that it was the brakes themselves that wouldn't hold, but still. EVERY time I take it in they just adjust the cable and send me on my way. Jesus if it was that simple, I could have fixed it myself.
Old Jun 9, 2006 | 03:02 AM
SpecialK's Avatar
Originally Posted by Blown 4-banger
SEE that shows how stupidly low our first gear is!!! What were they thinking!?!?
They were thinking you didn't want to slip the clutch from a dead stop. And that idling along in first and gogin 10mph is kinda hard on the clutch in a parking lot cause you'll be thoring it out so often.
Old Jun 9, 2006 | 03:12 AM
Blown 4-banger's Avatar
Thats all good, but why did they make 2nd gear so high!?!? You can go 67 mph in 2nd gear, and with stage 2 you can go like 73! The rsx can only go like 53 in second. I just don't get it, its harder on the clutch to have to absorb that huge drop from first to second than it is to slip the clutch a little in a parking lot.
Old Jun 9, 2006 | 08:39 AM
SS_Canuck's Avatar
Uphill / Flat ground = First gear
Downhill = Reverse
Old Jun 9, 2006 | 08:54 AM
memphisr24's Avatar
Originally Posted by CobaltSS422
I can push my car with the e-brake on. It's tough but I can still push it
I know what you mean, my girlfriend lives on a hill. I always park down hill so I don't wear out my clutch as much when driving off. I pull the e-brake up as hard as I can every time and put it in reverse. Sometimes I don't even put it in reverse (and I should) I went behind my car one day with just the ebrake on and started pushing. It starts making creaking noises lol. I told my GF "Look what I could do" lol she did not care one bit
Old Jun 9, 2006 | 09:36 AM
06VRCoupe's Avatar
I usually park it in R with the e-brake. I do golf on slight inclines, but mostly flat, and my e-brake holds her in place.
Manual says R, but you can park it in 1st if need be!
Old Jun 9, 2006 | 09:37 AM
Permafried-'s Avatar
Originally Posted by DC52NV
depends if i'm parked uphill or downhill. uphill i park in first. downhill in reverse.
Typically the same for me but I also take into account which way I'd prefer my car to shoot if I forget to put it in neutral before starting and let my foot off the clutch (yes this saved me once from hitting my garage door, and yes I felt like a complete idiot )
Old Jun 9, 2006 | 11:39 AM
l Sh1ft l's Avatar
First.. 3rd.. Whatever I decide to put it in.
Old Jun 9, 2006 | 11:40 AM
  #36
1stbluSS's Avatar
I would have to agree that the E-brake in these cars suck. I always put my car in first gear and put my e-brake on.
Old Jun 9, 2006 | 01:09 PM
  #37
b-spot's Avatar
Wrong
  #38
b-spot's Avatar
Downhill = Reverse
Wrong
  #39
Strider_2001's Avatar
I have always just left it is Neutral and used the E brake
Old Jun 9, 2006 | 01:10 PM
  #40
b-spot's Avatar
Right.
No one reads on here
Old Jun 9, 2006 | 01:15 PM
  #41
1stbluSS's Avatar
quoting your own post lol WRONG !
Old Jun 9, 2006 | 01:16 PM
  #42
Tomtwtwtw's Avatar
Yup...1st and reverse are the shortest gears in the car, hence why they're recommended. In the SS/SC at least, I know 1st is a little shorter than reverse, and so would provide more resistance to rolling. That said, I live in AZ. I only use the e-brake so the wind doesn't push my car anywhere.
Old Jun 9, 2006 | 01:22 PM
  #43
OniMirage's Avatar
normally only use the e brake. no big hills in phx but there are some and in those cases i will use 1st plus the e brake. I cant drive away if my e brake is on I will literally drag the tires like blown 4 did
Old Jun 9, 2006 | 01:27 PM
  #44
plyboy-illest's Avatar
i always park in 1st..
Old Jun 9, 2006 | 01:28 PM
  #45
1stbluSS's Avatar
Here is the sure fire solution. Put your car in 1st. Pull your e-brake all the way up. Turn your wheel toward the curb. Put a block behind and in front of every tire. Place 4 police boots on the wheels. Let the air out of your tires. You should be ok then.
Old Jun 9, 2006 | 01:36 PM
  #46
FLCobalt's Avatar
i use 1st here and E brake of course
Old Jun 9, 2006 | 01:39 PM
  #47
hatrickstu's Avatar
i dont know about your cobalt but mine redlines right at 60 in 2nd gear
Old Jun 9, 2006 | 01:59 PM
  #48
Leafy's Avatar
What I do is come to a complete stop, Put it in first and still have my foot on the clutch and brake, then pull the ebrake... turn the car off, let the car settle on the ebrake.
This method allows 1st gear to stop a roll just in case the ebrake fails, but also causes no stress on the Transmission itself.
The ebrake on this car is one of the best I've ever had in a car, and I find most people who complain about it either abuse it by engaging it before they come to a complete stop or use it to powerslide on pavement.
Old Jun 9, 2006 | 02:00 PM
  #49
Tomtwtwtw's Avatar
2nd in the SS/SC is approx 10.5 mph / 1k rpm. Yours will redline same as everyone else, unless you've got smaller wheels for some reason.
Old Jun 9, 2006 | 02:03 PM
  #50
Tomtwtwtw's Avatar
RSX is also a 6-speed n/a engine...the shorter ratios keep it in its powerband. With our wider powerband we don't suffer any real performance hit with the 5-speed.
I personally like being able to gallop at 80 mph and only 3krpm. My friend's old 05 Si was at 4k at the same speed. Sounded like a swarm of bees when he was on the highway.
