What gear to park in?
Old Jun 12, 2006 | 12:46 PM
  #76
GSoccer24's Avatar
i always use reverse just as the manual says. draws a lot of questions from passengers. anyone who had a cavalier at some point remembers they were the same way.
  #77
p7x's Avatar
p7x
neutral, unless ur on a hill and the owners manual says put it in reverse.
Old Jun 12, 2006 | 01:06 PM
  #78
iso's Avatar
iso
Originally Posted by Tomtwtwtw
I would actually bet on the radar gun being off before your speedo...those things can vary greatly depending on the distance and angle you're being scanned at. I've passed by those sidewalk radars that are supposed to remind you how fast you're going, and as I drove by, with cruise set to 45 (just in case!), the readout started at 42 and slowly dropped to 38 as I passed by.
the radar had been calibrated that morning and i was the first car it was used on (my good friend is a trooper). they are off +/- 1-2 mph. even if that is the case and it was off 2 mph then that would put my speedo dead accurate.
Old Jun 12, 2006 | 01:39 PM
  #79
Tomtwtwtw's Avatar
Dug this up...if my *calculations* aren't good enough for some of you, here is what Road and Track actually achieved on their test track.
http://www.roadandtrack.com/assets/d...data_panel.pdf
If you guys are getting different readings, I would also suggest find an empty road, and gradually accelerate to redline in your gears. If you're flooring it, your speedo will not be reading actual speed, as the gauges tend to run just a little behind. (hence why you seem to hit the rev limiter at 6100 or so in 1st, and 6300 in 2nd) Again, not trying to be a smartass, but I will repeat that this is how the car was designed and built. Whatever your speedo or radar gun says, if you're on properly inflated stock tires and rims, you will be going that speed in that gear. Road and track uses GPS equipment to calculate test speeds and times, which is much more accurate than any radar gun. Only other exception I can think of would be a slipping clutch...I think most of us know that feeling by now. (not me though, knock on wood!)
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
