What is the name or part number for this?
Old Apr 20, 2020 | 12:50 PM
solman98's Avatar
A while back I mentioned my daughter 06 LS had a left rear door that was locked, and the lock know would move, but not unlock the door. Well over the weekend I decieded to tackle the issue and see what. Managed to get the panel pulled away from the door enough so I could get my hand in and pull the lock rod to unlock the door. Once opened, and the panel completely removed, I could see the issue. I was able to pop it back in, but it's loose fitting and will probably happen again. So the next time, I'd like to have a replacement. Probably pick one up for each door. Since this 06 only has 56K on it, it will be around for a while.
So, anyone know what this is called, part number, or where I can get a replacement? WIth most places shut down, I'm in no hurry. Daughter is only taking it out once each weekend to get it up to temp vs just letting it stay parked. It's just the plastic part, rods are still good.
Old Apr 20, 2020 | 01:47 PM
solman98's Avatar
I think I found it.
Door Lock Rod Bracket - GM (24420664)
https://www.getoemparts.com/oem-part...w0LWdhcw%3D%3D
Mr.SS/SC
Dec 26, 2015 12:20 AM
doug11
Dec 26, 2010 05:13 PM
67C10
Jan 25, 2010 07:15 PM
blackbolt89
Jun 26, 2009 09:52 PM
greygoose08
Apr 21, 2009 11:59 PM
