Door won't open
Old Dec 23, 2010 | 06:38 PM
doug11's Avatar
Door won't open
My buddy's 06 ss/sc driver's door won't open. It doesn't feel like the handle is broken and door isn't locked lol.Said he got in drivers door left went to work went to get out drivers door and wouldn't open, had to climb out passenger side.......any ideals Thanks.
Old Dec 23, 2010 | 06:42 PM
BigRyanJackson's Avatar
needs a door lock actuator.
Old Dec 23, 2010 | 06:44 PM
doug11's Avatar
how bad is that to replace can't get door panel off cause door won't open, less there is another way
Old Dec 23, 2010 | 06:47 PM
MastaShaKe_88's Avatar
Hold the handle and have your buddy push the door reeeeeeeally hard from the inside
Old Dec 23, 2010 | 06:58 PM
that doesnt work. im a tech at a chevy dealer. you gotta take apart the door panel inside the car and have the window up so you can open the door with a srewdriver inside the door. its pretty easy if you know basic mechanics.
Old Dec 26, 2010 | 05:13 PM
aethean's Avatar
Smack the outside door panel where the latch is until the door can open with the handle, once its working soak the latch in wd40 to clean it out, then drench it in white lithium grease. You will never have this problem again.
Now, this will only work when it feels like there's no resistance when trying to open the door. What happens is the factory grease is garbage and can get very dirty, so you have to remove it all (with wd40) then apply a GOOD grease (white lithium grease).
ineedacobaltss
Nov 7, 2015 02:25 PM
Oct 13, 2015 09:32 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
