What is this part?
Old Mar 25, 2023 | 04:27 PM
daxfas26's Avatar
What is this part?
Hello! I have had an SS/SC since 2006. It has sat up for 5 years this month. I’m getting the engine swapped out this week. I bought a new battery and hooked it up last night. Everything looked good. Only thing was this part was running the entire time even with the key out. So I had to undo the battery cable to make it stop. Any help identifying this problem and what to do would be greatly appreciated!
Old Mar 29, 2023 | 10:23 AM
Eagle_f90's Avatar
I cant really help diag the problem but that us your abs module
Old Mar 29, 2023 | 09:36 PM
audisfelicia's Avatar
ABS Pump Module, maybe a stuck relay?
Old Mar 30, 2023 | 04:44 PM
daxfas26's Avatar
I found out what it was recently and now I’m looking into the relay. I looked through my owners manual and don’t see relay for ABS anywhere? Can someone point me in the right direction?
Old Mar 31, 2023 | 01:28 AM
Eagle_f90's Avatar
i belive the relay is in your under hood fuse box and the inside of the cover should have a label diagram.
Old Mar 31, 2023 | 08:29 AM
WilliamAtkinson's Avatar
I don't know about it but i will searching about it.
Old Mar 31, 2023 | 10:29 AM
daxfas26's Avatar
I checked that. It doesn’t say relay for ABS pump anywhere. I looked in owners manual. It says it has an air pump relay for 2.2 and 2.4 motors but none for the 2.0? Is air pump the same thing for ABS Pump?
Old Apr 12, 2023 | 04:01 PM
The air pump is not the same as the ABS pump. IIRC it's labeled ABS in the engine bay fuse/relay panel.
Old Jan 31, 2026 | 07:52 AM
erween@'s Avatar
Lil Kim
Nov 10, 2023 06:56 AM
GreenspointCser
Jun 23, 2022 11:00 PM
insylem
Oct 28, 2013 12:36 PM
Grimfoo2
Oct 31, 2010 12:30 AM
F_Imports_09tc
Apr 10, 2010 02:41 PM
