wwhat is the point of this
Old Oct 5, 2009 | 12:36 PM
red2006 ls's Avatar
i have read some people are putting the 2.4 manifolds on the 2.2 why would you do this and what will you gain by doing it
Old Oct 5, 2009 | 12:38 PM
Whining-devil's Avatar
im guessing because the 2.2 has a crappy plastic mani
Old Oct 5, 2009 | 12:42 PM
MP Cobalt's Avatar
no it's bigger and has better flow. It will give you more top end
PsychoCam's Avatar
I put the 2.4 mani on my car b/c the 2.2 mani will only hold up to so much boost then it will blow apart.
Other reasons include better top end power
More horsepower
not that expensive of a mod
good thing to get if going for a fully bolted 2.2
Old Oct 5, 2009 | 12:43 PM
MachiBLue's Avatar
this..but you do lose some low end torque.
Raiden8816's Avatar
more airflow with the 2.4 manifold. you get more hp/tq.
of course this is totally dependant on which year you have. 05-07 will have this advantage with 05-06 2.4 manifold. 08+ have the same manifold as 2.4 hence the 148 hp rating at crank.
Old Oct 5, 2009 | 12:45 PM
PsychoCam's Avatar
good look for those ppl who had no idea lol
MP Cobalt's Avatar
yep, only downside of it
TurboTechRacing's Avatar
x2..
Old Oct 5, 2009 | 12:46 PM
weiss27md's Avatar
I noticed no loss of torque
PsychoCam's Avatar
just got to watch out bc the 05-06 have the same size map sensor
07's need to dremel out the map sensor hole to get the o-ring to fit into the mani
Old Oct 5, 2009 | 01:06 PM
red2006 ls's Avatar
how much trouble is it to do the swap and would i need any thing else
Old Oct 5, 2009 | 06:11 PM
jmz250's Avatar
Pretty simple. It'll take time only because you need to disconnect and reconnect several things. You may need new gaskets (I've heard you can reuse the old ones), a throttle body spacer plate if you're not putting a 2.4 TB on as well, and a way to extend the brake booster hose (connects on a different part of the 2.4 mani as opposed to the 2.2 and needs to be lengthened).
Old Oct 5, 2009 | 06:18 PM
springerdesigner's Avatar
I'm tuned but want to get this mod so should/would I get/need a new tune if I install this..?
Old Oct 5, 2009 | 06:30 PM
weiss27md's Avatar
You don't have to but alot more air is coming in so a tune helps. It's better just to get a 2.4TB and a 2.4IM and then get tuned. A 2.4TB requires a tune.
Old Oct 5, 2009 | 06:34 PM
HatedCobalt's Avatar
buy this:
http://www.crateenginedepot.com/stor...P1817C144.aspx
Old Oct 5, 2009 | 06:36 PM
Originally Posted by HatedCobalt
heard you can part it yourself from gmpartsdirect and save about $100...
So let's say I just get the 2.4 IM and then wait on the TB... would I be doing any harm w/o getting re-tuned until I get the 2.4 TB..?
blackbolt89's Avatar
to utilize it, it would make sense to retune. i ran untuned with the 2.4 and got the tune and it felt awesome. so i'd say cough up the 75 bucks and see for yourself.
Old Oct 5, 2009 | 06:39 PM
see ^^^ and did you notice any differances when you added it on w/o the tune..?
and if I want to S/C iin the future, these will be good or bad mods..?
thanks.
Old Oct 5, 2009 | 06:53 PM
weiss27md's Avatar
I've been running my 2.4IM for a couple months with no problems untuned but I plan to get a 2.4TB very soon. The 2.4IM cannot be used with a supercharger, it can be used with a turbo from what I understand though.
Old Oct 5, 2009 | 07:03 PM
eutechnyx's Avatar
Very helpful insight on this mod.I might just do the high flow 2.2 mani that was posted earlier.
Old Oct 5, 2009 | 11:22 PM
nhanson's Avatar
thanks.
it would be a waste unless you can resell if you go S/C...you would need the LSJ's intake mani
RaginChopsuey
Oct 27, 2015 01:27 PM
Adecker
Oct 20, 2015 09:46 PM
Sep 30, 2015 07:22 AM
goaliemo
Sep 28, 2015 01:37 PM
TheSandMan
Sep 20, 2015 06:02 AM
