Zzp Pcm
Old Dec 7, 2007 | 02:12 AM
cer3bral's Avatar
Zzp Pcm
Is any one running the ZZP PCM? If so, please post your dyno numbers if you have it and what is your A/F?
Old Dec 7, 2007 | 02:11 PM
LopsidedJester's Avatar
I am also, interested to know how these pre-programmed PCM's are working out. They look like a good idea for a fairly cheap price
Old Dec 7, 2007 | 02:27 PM
hungryhip-ccp's Avatar
runs great very highly recommended my #s are in sig and dont be fooled by them i am at 2500 alt 85 deg i was running a 2.8 and still because the air is so thin i only make 15-15.5 lbs boost and a/f was perfect at 11.5-12.0 the whole rpm range in 4th gear with 42s everyone claims they go crazy at 6k at the top of third... so i trust zzp 100% they have never done me wrong and there tech serv is GREAT
Old Dec 7, 2007 | 07:25 PM
cer3bral's Avatar
When I contacted them thats what the A/F would be at...and Iam thinking its too lean. I do trust zzp but at the same time I dont what to blown my engine.
Old Dec 7, 2007 | 07:35 PM
SFPH's Avatar
Thumbs up
FYI, with an Air/Fuel Ratio of between 11.5-12.0 you will be right where you want to be on any Forced Air Induction engine tuned properly. Less than 11.5 you will be a little to Rich. With more than 12.0 you will definitely be a little to Lean , especially running over 15 psi of boost. Actually 11.5 to 11.8 is the sweet spot for performance running higher boost numbers. Hope this helps.
Old Dec 8, 2007 | 12:09 AM
cer3bral's Avatar
Hey thanks alot...Btw u guys make great pulleys.
Does any body else have any input?
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
