Electrical: 12 volt power tap and grounding for accessories
Old Mar 1, 2009 | 02:20 AM
massivematt's Avatar
If you have an open spot on the fuse block can you add a fuse and fuse tap to power a gauge?? Or do you have to use an existing fuse?
Old Jan 27, 2010 | 01:42 AM
kissrocker52's Avatar
good write up very useful
Old Feb 10, 2010 | 10:20 PM
superbrowndude's Avatar
Thank youuuuuuuuuuuuuuuuuu !
Old Jun 14, 2010 | 06:39 PM
mrgrinch's Avatar
this is good, was thinking aboutlooking for something in there. thanks!
Old Jun 15, 2010 | 03:11 AM
scottie's Avatar
Originally Posted by Dmoney
Would anyone know the steps of hooking a aftermarket amp up to the base stereo in a 06 cobalt?
You have to get a output converter to convert your stereo wire going into your factory sub to rca outputs. Then you can plug those into your amp and so on.
Old Aug 1, 2010 | 05:13 PM
lilskarvcx's Avatar
I recently wired leds into my footwells.
I tapped into the int light fuse and it is NOT switched.
It stays on when the doors are shut and the int light shuts off
Plus, empty fuse spots don't have an power
I used a regular sized fuse tap, but had to cut it to get it to fit.
Where are the wires that run to the headlights? I want to tap those so they only come on at night and I don't have to turn them on and off every time.
Scratch that, slot 22 is a switched fuse slot
Old Dec 29, 2010 | 01:20 PM
TitanSoulja's Avatar
Hey um so i own a 2006 lt cobalt coupe and im trying to hook up a street glow music interface to make my led lights dance to the music and i wanted to wire to the accesory plug, the accesory plug always has constant power to it no matter what, i cut the power wire and hooked the 12 volt wire from the music interface to it and grounded the black wire on the interface to metal, but the music interface isnt working. What did i do wrong? did i ruin the power wire to the accesory plug cutting it it? was i suppose to do something with the ground wire from the accesory plug? Please help. And i used the accesory plug near the e brake on my cobalt wich is in the middle.
Old Sep 27, 2011 | 05:14 PM
PikerAA's Avatar
subd
Old Mar 7, 2012 | 12:20 AM
mcottingham's Avatar
Hey Guys,
Just my $.02.
When I installed the gauges in my car I used an 'Add a Circuit' kit. Amazon.com: Littelfuse FHA200BP ATO Add-A-Circuit Kit: Automotive
This kit is similar to using a tap, however, gives you the ability to put a separate fuse on your new accessory line. I also chose to use my sunroof fuse location, however, used a 5A fuse for my gauges.
Mike
Old Mar 7, 2012 | 12:55 AM
EmperorJJ1's Avatar
^^ much better way to install but ud need the mini fuse not the regular size
Old Mar 7, 2012 | 01:11 AM
  #36
CannonBalt's Avatar
Originally Posted by Black07SS
so if i tap into any of those fuses and ground it on the bolt under the dash, my interceptor will turn on when i turn the key correct?
Yes
Old Mar 7, 2012 | 01:14 AM
  #37
EmperorJJ1's Avatar
no
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
Stuff
Oct 1, 2015 05:47 PM
grampss
Sep 27, 2015 08:51 PM
