Appearance: 1st Gen Projector Aiming
Old Apr 12, 2007 | 05:33 PM
  #101
an0malous's Avatar
zig did you try flipping your bulbs?
the beam pattern is far more normalised and bright to drive with.
but you will have the return lead line on the road thats all.
Old Apr 13, 2007 | 11:41 AM
  #102
zigggy56's Avatar
I'm going to drill out the top spot and try and flip the bulbs this weekend, I'll let you guys know if that helps at all
  #103
zigggy56's Avatar
Old May 21, 2007 | 10:55 AM
  #104
YellowCobaltLT's Avatar
does anyone know how the cut-offs should line up??? like should they blend together? Should they be seperate? Should the z cut-off part be in the center of the correct height mark on wall?? i can't tell from pics posted. Thanks
Old May 21, 2007 | 01:11 PM
  #105
CCBalla10's Avatar
refer to my thread. I was also having this problem but figured it out after a while. Watch both videos and look at the pics...then farther down the thread, I list exactly how I did it....hope this helps YellowCobaltLT
https://www.cobaltss.net/forums/pictures-videos-64/an0malous-thanks-projectors-finally-aimed-pics-vid-58442/
an0malous I had to flip my halogen bulbs around to give me even lighting...if you look at any of the pics from before I had them aimed you can see two round dots under the cutoffline. Took the headlight out and just turned the light over to see if maybe it would do anything and it did. Got rid of my bright spot in the middle of my cutoff...i'm sure its the same deal with the hids
Old Jun 30, 2007 | 11:42 PM
  #106
The_Blur's Avatar
If there's anyone in STL who wants to aim mine, I'll give them $30 to do it right. That means very little or no notch. I've been trying to get mine properly calibrated for the last 2 hours with no luck. I'm way too pissed to keep trying to do this. Somebody PM me ASAP.
I'll put an ad in my profile until the offer is over. Please help me!
Old Jul 7, 2007 | 09:00 AM
  #107
Kristiano's Avatar
Awesome!
Hey, I'm a n00b to the forums and a while ago I saw a good how-to about installing the Halo Projectors - man are those things ever sweeeeet! My problem is that I can't find anywhere to get them.. now I'm sure it has been posted at some point, but would someone be so kind as to paste a link showing me where I can get them or suggest somewhere to look?
- Kristiano
Old Jul 7, 2007 | 09:15 AM
  #108
DaREDss's Avatar
ebay... www.cobalt-addiction.com
Old Jul 7, 2007 | 09:24 AM
  #109
Kristiano's Avatar
Thx, Dude! That was quick..
Old Jul 8, 2007 | 11:29 PM
  #110
The_Blur's Avatar
I just attempted to aim them again. For the 4th time they aren't right. I'm very close this time, but these damned things won't line up in the distance at all. And that "Z" shape won't go away.
If you are anywhere remotely near 63040, I will pay for you to align my projectors and high-beams. I will cover your gas. PM me!
Old Jul 9, 2007 | 04:33 AM
  #111
EmperorJJ1's Avatar
the z shape doesnt go away
Old Jul 9, 2007 | 04:52 PM
  #112
an0malous's Avatar
Z shape is an intended part of projectors.
it allows you to have higher lighting on your lane, and the ditch, while keeping the beam below oncoming traffics eyes.
Old Jul 9, 2007 | 08:53 PM
  #113
Blankobalt06's Avatar
Is anybodies fogging up already like mine? I just put them in at the end of march
Old Jul 9, 2007 | 08:56 PM
  #114
DaREDss's Avatar
yes mine are ... i belive there are holes in the bottom that let stuff in i have a bug in mine wtf
Old Jul 13, 2007 | 03:34 PM
  #115
any one know how exactly to get the moisture out of the headlights?
Old Jul 16, 2007 | 09:59 AM
  #116
farfrmnormal's Avatar
I worked on my projectors this weekend - I drilled out a slot for the return lead and they slid in nicely, but they are still tight enough that the bulb doesn't wiggle around. I don't get how people could actually fit the bulb in there without drilling (unless they put the bulb in where the original H1 bulb went in. Anyhow - I still have somewhat of a black spot and I am curious if it is from improper aiming or whether I need to drill more out in the projector.... I will post a picture tonight and maybe someone here can maybe give me some opinions. Damnit! I am at work and now I am itching to get home and do something about this...
Old Jul 23, 2007 | 09:05 PM
  #117
zigggy56's Avatar
Welcome to the club, glad you finally got around to installing these. If you go back through all my posts, here and clubg5, you'll find that its not really the aiming of the light but the focus of the beam in the housing. Before you attach the lights to the car, shine the lights against a wall and give the bulb a wiggle, in/out up/down and notice how the beam pattern changes. People have also recommended removing the small rubber nipple from the bulb, I have not tried that however. Good luck
Old Jan 12, 2008 | 11:27 AM
  #118
A-rod's Avatar
i have a couple of questions.. first my projectors are foggin up where and how do i seal it up. also with my aiming.. i have this single skinny beam going down the middle but i cant see **** on the sides... i dont believe anyone had this problem.. if you do i need help.. do i need to flip my bulbs around??
yea i havea couple problems ..first how do i get rid of the foggingg. where do i seal and how.. also with my projectors i have this single skinny beam of light right down the middle and nothing on the sides.... which is really weird.. what do i have to do..
Old Jan 14, 2008 | 06:11 PM
  #119
zigggy56's Avatar
the housing is made with small holes to allow moisture and heat to escape. If the lights are on, it should burn through the fogging pretty quickly, especially if you are using HIDs.
Before we can help you with the beam problem, you have to tell us what type of bulbs you are using. and posting pictures from inside the car at night (no flash) of the beam pattern
Old Feb 26, 2008 | 01:31 PM
  #120
ssweeet's Avatar
How high should HIDs be up from the ground when aimed at a wall or a garage door?
Anyone know?
Old Jun 1, 2008 | 01:05 PM
  #121
Turbo06Sedan's Avatar
this saddens me that this video is no longer there.
Old Jun 3, 2008 | 12:24 PM
  #122
jay99's Avatar
so the headlgiths have to come out again to align the light lol.. that sucks
Old Jun 18, 2008 | 10:01 AM
  #123
bms1990cobalt's Avatar
yah sadly, it is a P.I.T.A. too. car designers.................
Old Aug 24, 2008 | 10:18 PM
  #124
liljone's Avatar
find a random wall thats what ima do
I used a random white wall too (side of a car wash)
btw here is anther pic of the **** (low beams).
Old Nov 22, 2008 | 02:52 PM
  #125
rmpro1's Avatar
i was wondering if anyone could help me out with the 3rd gens. they only project like less than 15 feet from my car i need to aim them higher how do i do this i did not notice any screws on the back to adjust i dont know help please!!
