2.0 LNF Engine: Boost leak test a stock SS LNF.
Old Jun 23, 2013 | 05:16 AM
iboost's Avatar
Originally Posted by DoMiStIc_RuSh_06
I made one of these for my car....did you disconnect the lower cp from the tb....if I don't, the air disappears into the intake manifold and into the engine.
Is this true or no? I made a tester tonight and will be testing it tomorrow and want to know if there is anything else I need to do.
Old Jun 23, 2013 | 04:08 PM
iboost's Avatar
Anyone?
Old Jun 23, 2013 | 04:45 PM
gotboost?17's Avatar
Nothin Stock
hmm I think I may try this next weekend for ***** an giggles
Old Jun 23, 2013 | 05:05 PM
Terminator2's Avatar
Lightbulb
Originally Posted by iboost
Anyone?
Yes that post is correct.
Old Jun 23, 2013 | 05:18 PM
Nothin Stock
what do u put on the end of lower cp once its off?
Old Jun 23, 2013 | 05:30 PM
A cap.
Old Jun 23, 2013 | 05:53 PM
iboost's Avatar
Thanks for the update.
Old Apr 5, 2014 | 05:00 PM
WhiteBullSS/TC's Avatar
going to give this a try. Thanks.
Old Jun 30, 2014 | 07:34 PM
Shanedude's Avatar
Nice write up. I like the stuff a rag or cap where the turbo is so nothing falls in. It's be good to do the same with your engine oil cap(Do you HAVE to remove that?). Do not want anything falling into there either.
Old Jun 30, 2014 | 08:09 PM
Really good info to have, thanks for the time and info
Old Jul 5, 2014 | 02:22 PM
  #36
SSlobalt's Avatar
Thanks, guys. I never did cap my cold side pipe. I realize that means air pressure is just flowing through the open oil filler cap hole and the open valves out the exhaust and does create a little noise all on it's own, but it has never kept me from finding a leak. I use the soapy water method most of the time, anyway.
Shane, I don't know why I take the oil fill cap off. It was just something I was told way back in 1999, when I had DSM. I never asked, so I just kept doing it. There's a baffle inside the hole, but maybe putting a rag in it would be a good idea.
Old Jul 5, 2014 | 02:29 PM
  #37
I just pop the oil cap loose, you don't have to completely remove it. I find the pipe leak finder they sell at hardware stores for natural gas to work better for finding leaks, it says wet and bubbles better than just soap and water
Old Jul 14, 2014 | 12:26 AM
  #38
SINISTER's Avatar
2.5 by turboboostleaktesters.com
Our turbo outlet is what 2.5 ? I know it is not as good to test it this way, but I would like the option to do both ways.
I figure this can test it at the turbo and when I want to test it at the hot pipe (I think the preferred method) I can just clamp it on one side to a PCV pipe and the other side of the PCV pipe into the hotside pipe and then clamp.
This sound like it will work? ....I used to use this brand on my SRT4 worked great and it has a gauge built in....
Old Sep 30, 2014 | 05:58 PM
  #39
Gugi96's Avatar
i ****** love you man this is awesome and helped alot
Old Mar 5, 2016 | 07:54 PM
  #40
Anyone know what kind of cap works best for the lower cp?
Turbo Johnny
Feb 21, 2019 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
camaromanss1992
Oct 1, 2015 10:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jcarroll53
Sep 24, 2015 07:43 PM
