Appearance: Debadging the rear
Old Jan 22, 2006 | 06:24 PM
laserblue2006's Avatar
Debadging the rear
There have been a lot of people wondering how to remove rear badges so i figured i'd do a write up on it.
This is really easy and does alot for the look of the car.
i used-
an old credit card(to remove badge) you can use fishing line also.
meguiars body scrub
meguiars wax
hair dryer(optional)-but makes things easier
something to apply wax and body scrub with
heres a pic with the badge
now to start take the line or whatever you are using to remove it and slide it under the emblem. this is when you can use a hair dryer or heat gun to melt the glue a little and make it easier. once you have it removed get all the glue off with your fingers. now take the body scrub and apply it to get the last of the glue off. repeat scrubbing until you think it looks right. once you are satisfied with the body scrub apply some of the meguiars wax and remove. wash car and you are done.
heres a pic without the badge
Old Jan 22, 2006 | 06:37 PM
Doc's Avatar
Doc
awesome....just wish you had some pics of yourself doing the dirty work
Old Jan 22, 2006 | 06:42 PM
wikkymaster's Avatar
heat gun makes it ALOT easier! and i use gasoline to get the rest of the glue off, works like a charm, just be sure to wash it right after, and wax the area again! it wont hurt the paint, but will take the wax off
Old Jan 22, 2006 | 06:57 PM
distillion's Avatar
i used fishin wire, and thats it
Old Jan 23, 2006 | 02:06 AM
Sempher55's Avatar
i used fishing wire and my ladys hair dryer... then i just used goo gone to take it off... then i washed it... and it looked sexy. gave me almost 10 more hp.... lol j/k
Old Jan 29, 2006 | 08:53 PM
BlAckOnBLaCK's Avatar
What pound test fishing line did you guys use. I have some layin around here somewhere but I think it is only 6lb.
Old Jan 29, 2006 | 09:11 PM
victoryredss's Avatar
I used a heat gun and a pick tool. warmed them up and used the pick tool on the corner of the badge and just slowly pulled it off. didnt think about gas to remove the leftover crap prob. works better that that goo gone $hit.
Old Jan 29, 2006 | 09:23 PM
I was going to use my heat gun, just didn't know how to pull the hot badge off. Did want to scratch the paint and I also have black, which shows everything. That is why I was looking for the safest way. So you didn't touch the paint with the pick tool right? You just pulled it off from the corner.
Old Jan 29, 2006 | 09:44 PM
RaineMan's Avatar
I tried with 12lb fishing line and it keeps breaking... I may go get some spider line... like 40lb... should work.
Old Jan 30, 2006 | 07:55 PM
mcglothlindl's Avatar
25lb worked just fine
Old Jan 30, 2006 | 08:32 PM
Nuclear's Avatar
Looks better with the badge
Old Jan 30, 2006 | 09:02 PM
RaineMan's Avatar
Well... after 3 unsuccessful tries with 12lb stren I got bored tonite... so I ran down to walmart and picked up a spool of 30lb monofilament spider line and some goo gone... put on my work gloves... wrapped about 3 turns of line around the badge and pulled...
the badge popped right off... no problem... I think I'm gonna let the remaining sticky stuff sit overnight and see if a little time to be exposed to the weather will help get rid of it... plus it's a little dark now.. heheh.
Old Feb 7, 2006 | 12:27 PM
co-yellow-balt's Avatar
and heres a pic of a little modification of the letters.
Old Feb 7, 2006 | 06:14 PM
LSpower05's Avatar
See now that I saw that it makes me wanna change mine... :-\
Old Feb 7, 2006 | 06:17 PM
Waylin22's Avatar
heres a pic of mine...butt a$$ naked!
Old Feb 9, 2006 | 10:57 PM
M-Dub's Avatar
Heres mine without the badges.... Old Credit Card, and GOO GONE and about 25 minutes!
Old Feb 16, 2006 | 01:04 PM
ajent's Avatar
I used fishing wire to get mine off. Hot enough in florida you dont really need to heat it up.
However, to get the glue off someone said fingernail polish will work, and it did.
Now i think it ate thru my clear coat or something, as its kinda shiny in some parts, then other parts looks dull.
grr.
LSpower05, do you have a pic of the back of your cobalt that shows the entire back end?
Old Feb 16, 2006 | 01:09 PM
plyboy-illest's Avatar
looks sweet
Old Feb 16, 2006 | 01:10 PM
like yours 2 !!
good job guys
Old Feb 16, 2006 | 01:17 PM
LSpower05's Avatar
grr.
sure.
Old Feb 16, 2006 | 03:59 PM
ajent's Avatar
Cool looks good. Did you use emblem adheasive to get them to stick back on?
All I've taken off is my bowtie on the back, but I might take off the supercharged one as well, for some reason the right side wont stay down and little sht like that bothers me.
I'm interested in doing the SS replacement of the bowtie in the front also.
Old Feb 16, 2006 | 04:13 PM
LSpower05's Avatar
I used 3m tape to put the emblems back on. I like the whole ss emblem on the front look. They should have done that to begin with imo.
Old Feb 16, 2006 | 09:13 PM
LSpower05's Avatar
Finally got around to removing my bowtie from the rear today. Looks pretty good. Although I think i'm gonna spread out my cobalt lettering
Old Feb 16, 2006 | 09:16 PM
ajent's Avatar
Yeah, the spread cobalt lettering reminds me of the S T R A T U S
Old Feb 19, 2006 | 03:02 PM
Dragonsfire12345's Avatar
what would be the best method for on a black SS?
