All Engines: Fuel Filter Change How-To with pictures
Old Mar 12, 2008 | 01:41 PM
  #51
Red2.4SS's Avatar
Nice!
BTW peeps, mine was COMPLETELY CLOGGED at 32k miles!
So change it regularly!
Old Mar 24, 2008 | 03:41 AM
  #52
Jn2's Avatar
Jn2
i got 28,000 miles on mine, i might do this tommorow,
autozone has these filters for 14.99,
autozone part # FF4002
Old Mar 24, 2008 | 04:22 AM
  #53
steddy2112's Avatar
I may do this on my next set of days off
Old Mar 25, 2008 | 03:07 PM
  #54
galeblanc's Avatar
So, since crate engine depot charges 20$ for canada shipments, is there anywhere else to obtain this filter for a decent price ? I tried GMPartsDirect but I don't think they ship to Canada. (To be confirmed)
Any ideas other than the dealer at 77$ plus tax 15%.
Thanks
Old Mar 25, 2008 | 03:13 PM
  #55
thought's Avatar
Originally Posted by sauced1173
haha nice...FYI these fuel filters are cheaper at gmpartsdirect.com then at crateenginedepot.com...its $31.76 there and $30.65 at parts direct lol...not a big difference but every penny counts sometimes. atleast for the same damn thing. also, if you or someone you know works for GM they can get it for $30.54.
Yeah but check the shipping, Gm Parts Direct can have some big shipping costs...
Old Mar 25, 2008 | 05:35 PM
  #56
redlineblueline's Avatar
Thanks
autozone has them for 14$us
Old Mar 25, 2008 | 07:52 PM
  #57
galeblanc's Avatar
The Acdelco one's ? Or an equivalent ? Is it ok ?
  #58
equivalent i have been running mine for about 6k miles now
Old Mar 27, 2008 | 03:08 PM
  #59
galeblanc's Avatar
So I bought the filter at Crate Engine Depot and added a cabin filter while I was at it cause the shipping is fixed at 20.65 to Canada so i may as well make it worth it. What an expensive filter. ..
Old Apr 12, 2008 | 01:27 PM
  #60
Changing mine today and using this writeup, halfway done. mine wouldnt depressurize fully. It sputtered but then just kept running and running. i finally just said f-it and shut it off. pulled the lines off and gas came out for 2-3 seconds then stopped, there goes 5 bucks in gas. going to pull off other end now. black nastyness came out with the gas as well. guess it was plugged lol. great writeup btw
damn thing wouldnt de pressurize. oh well. got it changed, thanks for the writeup. see if this fixes my problem.....
Last edited by 07MetallicSC; Apr 12, 2008 at 01:27 PM. Reason: Automerged Doublepost
Old Apr 29, 2008 | 12:07 AM
  #61
Eric304's Avatar
I did exactly everything this thread recommended doing, and I went to repressurize the system, and I heard the fuel pump start to whine. All Good Right....
Wrong, I tried to start it after shutting it off thinking the system was fully pressurized, and the Car wouldnt start. I said what the hell. So i turned the ignition to the ON position again for about 20 seconds, turned off the car and tried to start it again and nothing.
I decided to pull the fuel line going to the Fuel Rail, and i wasnt getting any fuel. I reconnected it and decided to check the lines going to the fuel filter and i wasnt getting any fuel either.
Any suggestion on what else i should check for? Fuel Pump Relay?
I have a half talk of gas so i don't think the fuel pump is fried.
Old Apr 29, 2008 | 12:09 AM
  #62
make sure its in the correct slots
Old May 3, 2008 | 04:12 PM
  #63
sic_infested's Avatar
i read threw this really quickly... and i NEED mine changed.... BAD... reason i didn't is cuz my dealer said i don't really have to for a long time... i thought they were wrong but thought y would they say no to making money... but anyway... i didn't see anything about where i can buy that tool... where can i pick 1 up?
Old May 3, 2008 | 04:19 PM
  #64
SSRedSC's Avatar
Sears and I would imagine any auto parts store like autozone.
Old May 3, 2008 | 04:20 PM
  #65
awesome... thanx
Old May 3, 2008 | 04:56 PM
  #66
its super easy to do. hardest part was jacking up the car, and for some reason my system wouldnt depressurize but i got it done in 10 mins either way.
Old May 3, 2008 | 11:38 PM
  #67
rnjmur's Avatar
I assume by now you got it running again?
Old May 4, 2008 | 03:40 PM
  #68
Foximus's Avatar
AC Delco should be fine since that GM parts. also, i should do this. I have 67,000 miles on mine....
Old May 5, 2008 | 04:22 PM
  #69
cyrix's Avatar
fark me, i'm on the same boat with eric304 on not starting. I probably put the relay in backwards or something. Sucks for me is that i work in like 1 hour /wrists
-edit-
what a bunch of Diarrhea Sauce. I'll see if I can maybe get pictures later this week. If you look closely were the relay plugs into, it can go either up or down, not just rotating 360 either.
To entertain you, here is some ASCII crap drawing of the relay plug in.
This is how the relay should go back in
Old May 5, 2008 | 04:30 PM
  #70
HackAbuse's Avatar
I have 43k miles lol.
Next oil change (in a few weeks) I'll try to change mine
Old May 6, 2008 | 12:20 AM
  #71
rnjmur's Avatar
Yeah, I am not sure why GM didn't plug one of those holes so that you couldn't put the relay back in the wrong spot. That would save alot of people alot of headaches. The first time I did my fuel filter I put the relay in the wrong spot. Took me an hour of messing with everything before I figured out what a ******* I was... lol
Old May 18, 2008 | 03:07 PM
  #72
galeblanc's Avatar
I had a problem with the disconnect part of it and I couldn't get it done. I'll have to re-try another day.
Old May 18, 2008 | 04:40 PM
  #73
what part did you need help with?
Old May 18, 2008 | 09:23 PM
  #74
rrutter81's Avatar
use the grey one and use it on the 1 big line. It is supposed to release prongs cylindrical to the wall. Push it in and the prongs will detach from the hose. I didnt know how until my old man showed me while I was changing my oil and trans fluid.
Old May 19, 2008 | 09:38 AM
  #75
galeblanc's Avatar
So I assume I have to push really hard. Is there any twisting at all?
I'll try again next weekend.
