Other/Misc: HOW TO: Antenna Mod
Okay, i know a lot of people have cut the stock antenna to make a "shorty". but i just hate the antenna all together. i hate the "rc car" look. so i decided to remove the entire antenna. But be warned, i lost all but one of the stations i listen to. but i've moved to cds lately anyway so i don't really care.
Difficulty 1-10 with 10 being the hardest: 0.5
Elapsed Time: 15-20 minutes depending on the location of your nearest parts store
Result: Amazing
Tools need:
adjustable pliers
1/4" vaccum caps(autozone)
old rag
Step 1:
put the pliers on the first setting. then fold the rag in half, and then in half again, so you have a four layer square that is 1/4 the size of it unfolded.
Step 2:
Open the pliers and insert the rag, then close the pliers around it, still on the first setting.
Step3:
put rag/plier assembly around the top of the base of the antenna(where it isn't a full circle)
Step 4:
squeeze tight and turn untill it is able to be loosened with your fingers. when off it should look like this.
Step 5: twist on 1/4" vacuum cap
And finally, admire your work.
Before:
After:
Result: Amazing
Tools need:
adjustable pliers
old rag
Step 1:
Step 2:
Step3:
Step 4:
Before:
After:
But other than that, you can always stick to satellite radio. Or I just got a Pioneer DEHP5000UB and a 4gb flash drive. It works sooo good.
Thanks for taking the time to write out a how-to!
Just a NOTE (my .02 on the matter) -- there have been more than a few owners who's antenna did not come off with a simple twist. If the antenna does not loosen with a simple twist do not keep turning until the entire antenna assembly begins to turn! I've seen it where the antenna assembly gets turned and breaks the pinch welds off of the antenna body mount/bracket in the trunk. It is either from corrosion or cross threading when the antenna was installed -- if that happens you need to hold the antenna body in the trunk while trying to twist off the antenna.
thankyou
Last edited by EXsoccer1921; Oct 28, 2008 at 11:43 PM. Reason: Automerged Doublepost
or coarse its not gonna come off with a simple twist haha. its screwed on about 3/4" of an inch. and if your turning to where "I've seen it where the antenna assembly gets turned and breaks the pinch welds off of the antenna body mount/bracket in the trunk." that happens, you're trying to unscrew the wrong part.
I'm not referring to "difficult" antennas....at one of the CED Cobalt shows we tried helping a CSS.net member remove a stubborn antenna. 3 people working at it could not remove the antenna!!!!!no joke
Thanks for the write up. I might go out and do that now to replace my crappy rubber shorty. I took off the OEM antenna with my hands without much of a problem.
Would AM radio still work at least? I listen to a lot of my sports teams while driving home from work.
if you guys wanted to keep ur radio u could easily buy an aftermarket antenna and hide it
http://www.crutchfield.com/S-rNVVLGd...px?I=12044UA20
i was talking about if u want to do what u said and for better reception just plug this in.
this will even plug directly to the bak of the stock reciever if u choose. its the same plug
which means: ordering this badboy, waiting for it to come in, take the stock radio out, run the wiring, put the radio back in, and hope it works.
it works. I have seen a few of them in some trade ins. Or something similar that is. I even found one truck with TWO full antennas. One was stuffed under the whindsheild and dash. Did not know untill we had to replace the window. Funny thing is both were hooked up and worked???
