Other/Misc: HOW TO: Antenna Mod
Old Nov 5, 2008 | 06:38 AM
G5Wisz's Avatar
just put the vaccum cap on yesterday, fits perfectly, and out of my 6 preset fm stations 2 of them are clear while the others are mostly static
Old Nov 5, 2008 | 06:46 AM
car_guy_09's Avatar
Originally Posted by Erod
Thanks, its sitting in my garage.
Old Nov 5, 2008 | 10:15 PM
thehov's Avatar
Originally Posted by kkanowitz
I'm gunna assume that this mod == no FM radio?
Looks good BTW
what is this FM radio you speak of?
Old Nov 6, 2008 | 01:52 AM
EXsoccer1921's Avatar
youre kidding right?
Old Nov 6, 2008 | 09:04 PM
tru2nrtt777's Avatar
I should do this...
Does anyone know if a valve cap will screw right on? It seems fesable. Get some custom valve caps.
Old Nov 6, 2008 | 09:09 PM
Rissa's Avatar
I wanna know if the Ark antenna still gets good FM reception...i DO like to listen to Kevin and Bean in the morning still.
rocketrex's Avatar
i did another way, i just cut off from the middle and too the ball off, then filed down the tip to accept the ball and one good hit to the ground and presto! shorty antanna, cost me nothing i'll post a pic up tomorrow.
Old Nov 6, 2008 | 09:40 PM
timmhimself's Avatar
my '77 el caminos factory antenna runs in the glass of the windshield up the middle, then outwards accross the top. i got more stations clearer with that than my cobalts antenna. i'm shaving the cobalts off smooth and going for the hideaway.
this might be my temporary fix till that happens.
Old Nov 6, 2008 | 10:20 PM
Originally Posted by tru2nrtt777
I should do this...
you mean on the tires??? no. its a different thread pattern.
Last edited by EXsoccer1921; Nov 6, 2008 at 10:21 PM. Reason: Automerged Doublepost
Old Nov 6, 2008 | 10:27 PM
Red07SSNA's Avatar
I think he means can you screw a valve stem cap on the antenna stud....anyone try?
Old Nov 6, 2008 | 10:30 PM
  #36
thats what i just said. no, it doesn't work
Old Nov 7, 2008 | 03:56 PM
  #37
kevinj4891's Avatar
my antenna
Thanks for taking the time to write out a how-to!
Just a NOTE (my .02 on the matter) -- there have been more than a few owners who's antenna did not come off with a simple twist. If the antenna does not loosen with a simple twist do not keep turning until the entire antenna assembly begins to turn! I've seen it where the antenna assembly gets turned and breaks the pinch welds off of the antenna body mount/bracket in the trunk. It is either from corrosion or cross threading when the antenna was installed -- if that happens you need to hold the antenna body in the trunk while trying to twist off the antenna.
i went out an bought a shortty euro style antenna (see my vGarage) and the antenna came off, but the stupid kit with the new antenna didnt fit. i had to file down and re-tap the threads for the new antenna to work. it looks good, but i did lose quality. DOES ANYONE KNOW ABOUT SPLITTING/TAPPING into the original cable so that i could possibly use a new amplified antenna? or do i just need to run a new wire from the h/u? i saw a nice shortty amplified one at Joke boys (pep boys), but it comes with its own cable and i dont want to disassmble the head unit to get it to wrok
Old Nov 7, 2008 | 07:10 PM
  #38
Damn, I was thinking of putting one of my skull caps on there... lol.
Old Nov 7, 2008 | 07:20 PM
  #39
NWAE Cobalt's Avatar
you can also cut it short, use the same vaccuum caps...and put it back on
and for that matter..if you are leaving the antenna off..then screw the rag, just put the plyers on there and twist!
exactly...
i did mine like that...but before putting the ball back on i added some vaccuum tube and built it up so it was fatter, then i drilled out the ball end and glued it back on...then reprayed it black... worked like a charm!!!
will get pics on next break
Last edited by NWAE Cobalt; Nov 7, 2008 at 07:20 PM. Reason: Automerged Doublepost
Old Nov 9, 2008 | 04:04 PM
  #40
Yellow-Ls's Avatar
Nice! It looks way better, the stock antenna is nasty..
Old Nov 10, 2008 | 03:58 PM
  #41
Stetson's Avatar
Look way better, i use mine to fish wires through the firewall
Old Nov 10, 2008 | 06:41 PM
  #42
Yellow-Ls's Avatar
More efficient use i would say lol
Old Nov 13, 2008 | 07:59 AM
  #43
HIM666fan's Avatar
Worked awsome i love the way it looks!
just was a pain toget off for some reason!
but it was worth the wait!
Old Dec 3, 2008 | 09:58 PM
  #44
-Diamond-'s Avatar
how well does that vacum cap stay on?
Old Dec 3, 2008 | 10:20 PM
  #45
snake890217's Avatar
I did that for a while only I had a really long cap, like 2". Tried the short one, went with that big one lol
Old Dec 3, 2008 | 10:28 PM
  #46
Otown07's Avatar
I've had mine like this for 8 months or so. Haven't had to mess with it at all. And if someone pulls it off...oh noes! ! A whole $.40 to replace it!
Old Dec 4, 2008 | 02:11 AM
  #47
it stays on really well. just make sure you get a 1/8th
Old Dec 4, 2008 | 04:59 AM
  #48
kotton1605's Avatar
thanks will probably do this today. to anyone who has done this, will this effect those "blank" stations that i use to play my ipod? yes i know i need to hardwire it but dont have cash for the harness right now
unrelated but does anyone know if a can change/edit my user name on here without signing up all over again?
Old Dec 19, 2008 | 12:44 PM
  #49
Platinum_Injected's Avatar
yeah ask a mod to change it for you! i changed mine!
Old Dec 22, 2008 | 04:34 PM
  #50
well i went to the nearest parts store today to look for these "vaccum caps" buddy looked at me like i had 3 heads!! is there a different name for them in canada that i should call them?? was really looking forward to chopping my antenna
