2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
#326
Very clear thank you. Supercharging the 2.4L is quite an involved project but each modification in itself is do-able - the trick seems to be in keeping everything organized - the final tuning can't be easy - it seems HP Tuners has the software to make it work. So of the $750 a chunk of change ($500+) goes towards the brain box.
#327
I'll give you my Supercharged file which will get you up and running to perfection. Just find someone with an HPTuner. It was on the HPTuner repository but they haven't put them back on since they revamped the website. You will want it loaded before first starting.
