2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old 06-23-2018, 04:38 PM
  #326
OhSixBalt's Avatar
Very clear thank you. Supercharging the 2.4L is quite an involved project but each modification in itself is do-able - the trick seems to be in keeping everything organized - the final tuning can't be easy - it seems HP Tuners has the software to make it work. So of the $750 a chunk of change ($500+) goes towards the brain box.
Old 06-23-2018, 05:28 PM
  #327
Henry3959's Avatar
I'll give you my Supercharged file which will get you up and running to perfection. Just find someone with an HPTuner. It was on the HPTuner repository but they haven't put them back on since they revamped the website. You will want it loaded before first starting.
Old 06-25-2018, 05:38 PM
  #328
Make sure they just copy and paste the tables instead of writing your file over theirs. The latter makes bad things happen.
Old 06-25-2018, 06:39 PM
  #329
Henry3959's Avatar
Correct... any good tuner should know which tables to copy. If not I can list them.
Old 04-25-2020, 10:26 AM
  #330
titlips's Avatar
great how to thanks for that. im working on supercharging a 2.4L i just dropped into my mazda miata, and this is exactly what i needed!
Old 04-25-2020, 03:53 PM
  #331
gonna be a lot of cutting involved, good luck
DarrenGC
12-24-2021 01:55 PM
Henry3959
07-28-2017 12:32 PM
Twoozofjuice
03-09-2012 11:56 AM
heathkidder
03-26-2011 03:39 AM
utsadude
04-08-2009 08:39 PM
Quick Reply: 2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
