Interior: How to change cluster, HVAC control, window and door lock to LED
Old Mar 28, 2010 | 02:22 PM
zerosk8ter83's Avatar
Wink
Originally Posted by 09xfebalt
Also why are you recirc, a/c and defroster indicators lit up blue?
because the leds light up that clear plastic thing inside the hvac control.you want your leds to shine sideways not upwards.ill take a picture of it soon to show you
Old Mar 28, 2010 | 06:20 PM
09xfebalt's Avatar
i keep my plastic in there as well mine does not light like that.....i would like to see pics
Old Mar 28, 2010 | 07:41 PM
Talking leds
heres my setup,i put tape to cover the leds and make the light bounce back down to reflect into the clear plastic
Here is what it looks like without the tape,not so bright huh?(left botton side)
http://i61.photobucket.com/albums/h7...9/102_1594.jpg
and here is what it looks like with the tape. thats pretty much it.
http://i61.photobucket.com/albums/h7...9/102_1593.jpg
hope this helped
Old Mar 28, 2010 | 07:55 PM
Nighthawk243's Avatar
Nice firecracker
Old Mar 28, 2010 | 08:32 PM
Talking
Originally Posted by Nighthawk243
Nice firecracker
haha thankx
Old Mar 28, 2010 | 10:01 PM
bruiserinpink's Avatar
sub'd i wanna do this!
Old Mar 30, 2010 | 03:45 PM
dskav's Avatar
I did this after I had done my gauges with this kit:
https://www.cobaltss.net/forums/black-cat-custom-151/our-led-lighting-kit-stock-gauge-face-96714/
I used the same kit for the HVAC controls, plus that kit comes with a strip of red tape to keep the heat side of the dial red. This is how the redline portion of the tach stays nice and red with the gauge mod
Old Apr 4, 2010 | 06:09 PM
DC02's Avatar
I think someone needs to make that tape available by its lonesome
Old Jun 10, 2010 | 06:59 PM
ryaan's Avatar
would there be anyway to keep the red on the heat/ac controls red??? it seems like with the blue leds the red side doesnt illuminate
Old Jun 11, 2010 | 04:20 AM
PsyKAlex's Avatar
Hi, i have a question
Do you use 5mm or 3mm leds??
Old Jun 11, 2010 | 06:28 AM
  #36
countrySS's Avatar
how bout the radio i've had mine apart same with the switch's and the factory bulbs are small as ****
Old Jun 11, 2010 | 10:34 AM
  #37
I used 5mm leds
Old Jul 7, 2010 | 02:48 PM
  #38
cobaltguy889's Avatar
Good how to!
Old Jul 8, 2010 | 09:48 AM
  #39
Axelthered05's Avatar
Just throwing this out their, I also did this a few months ago but their is like a blueish tint film on everything so it makes it hard for any color light other than blue to be seen for example the red of the temp control has a red tini film on it which is why it wont show veary well in this pic if red leds were used that part would be super bright and everything would be dim
on another note nice wright up 09xfebalt
Old Aug 8, 2010 | 03:11 PM
  #40
RTkid59's Avatar
Originally Posted by zerosk8ter83
I used 5mm leds
I used a 3.6 volt LED for the cruise control and have some left over.. will those work for the HVAC or will it short out the circuit?
Old Aug 20, 2010 | 01:37 PM
  #41
Chilipado's Avatar
ok so i've done this twice now. once with 3mm red LEDs and once with 5mm green LEDs. Both times I bought the 12V LEDs from led-switch (same place as the OP). Both times they have not been anywhere near that bright.
any ideas on why they aren't bright?
Old Aug 21, 2010 | 05:36 PM
  #42
09xfebalt's Avatar
might be just how the green is. you may have to buy lower voltage greens and use resistors
Old Aug 21, 2010 | 06:36 PM
  #43
Chilipado's Avatar
it's how the red and green were lol.
Green on most LEDs is one of the brightest, if not the brightest colour.
I'll try with the oznium super bright LEDs and resistors and post up
Old Aug 23, 2010 | 04:27 PM
  #44
Chilipado's Avatar
ok so i checked the cluster again and realised that there is a blue film over the the areas that light up. you can see this if you take the black (or silver) face off and look at it from the back. i would imagine that this is why the blue lights up so well and the other colours do not.
im still waiting for my super bright LEDs from Oznium
i'll try to see about taking off that film as well
Old Aug 23, 2010 | 05:09 PM
  #45
really? i didnt even notice i just stuk those dam leds in there
Old Aug 23, 2010 | 05:28 PM
  #46
Chilipado's Avatar
yea and i didnt even notice someone else said that earlier too. i need to read every post lmao
Old Aug 29, 2010 | 07:18 PM
  #47
09xfebalt's Avatar
i fixed my clutser and hvac today make cluster red areas back to red and changed the kilometers to green and tach area dots and line to green. hvac red lights up red but currently no pics
more over exposed one to show actual colors but not brightness
Old Aug 29, 2010 | 10:22 PM
  #48
chrisjaldin's Avatar
it is pretty cool but I still prefer stock lights.
Old Aug 29, 2010 | 10:42 PM
  #49
09xfebalt's Avatar
installed pics
Old Aug 29, 2010 | 11:05 PM
  #50
check my out,the camera makes it blinding bright but its not so bright http://i61.photobucket.com/albums/h7...9/102_1867.jpg
