Appearance: How To : Chevy Skyline Tail Lights
Old Apr 13, 2009 | 01:26 AM
  #126
Gestapo007's Avatar
Finsihed mine tonight. OMG pain in the ass. hacking up reverse lights is not for the faint hearted but i finally did it, wired it up to parking lights. Dont have resistors or **** because I dont want them as turn signals. The uneven blinking bothers me a little and I just like the always on thing. It does kinda illuminate the center part but since my lights are heavily nightshaded it looks bad ass.
And I got 9.5" LED strips wich were too short so I had to cot and sodder and ugh. nightmare lol. PIC!
Old Apr 13, 2009 | 01:27 AM
  #127
El Mariachi's Avatar
nice
Old Apr 13, 2009 | 01:32 AM
  #128
MBMCustoms's Avatar
so have we come up with the correct size to do this with? i am still debating it
Old Apr 13, 2009 | 01:35 AM
  #129
Gestapo007's Avatar
9.5" strip plus 3 more LED's lolprobobly like 12". go bigger and cut it to size
Old Apr 13, 2009 | 01:37 AM
  #130
MBMCustoms's Avatar
i may give it a whirl when i get some spare time
Old Apr 13, 2009 | 01:43 AM
  #131
Gestapo007's Avatar
^Its not bad its just finding the right LED's and removing the sealant between the lense and the housing. The 2nd one went alot faster than 1st.
Old Apr 13, 2009 | 01:45 AM
  #132
MBMCustoms's Avatar
i imagine, i just gotta find the right leds first and then find some time. did you go with white leds or red?
Old Apr 13, 2009 | 11:06 AM
  #133
jefferyss's Avatar
i went with the red ones
Old Apr 13, 2009 | 11:37 AM
  #134
Gestapo007's Avatar
i went with white leds. they light up a bit brighter so u can see them better during day
Old Jul 7, 2009 | 12:52 AM
  #135
09turbo's Avatar
i will be doing this soon.
Old Jul 26, 2009 | 10:13 AM
  #136
SS Gordon's Avatar
Has anyone tried to make them fully functional by using two sets of LEDs like use the red ons for the running lights & then get the brightest white ones to use for the signals & brake lights?
I have found a couple of sets of LEDs & the first set I tried were to tall causing the light to bleed into the reverse light area so Now I'm going to try a set more like the ones used in this how to
WFLB96 series 96-LED Waterproof Flexible Light Bar
http://www.superbrightleds.com/light_bars-flexible.html
I found a set I can cut to length as far as every 3 leds have a cut area, so I was thinking about going with 2 sets per light? Any thoughts on this?
Old Jul 26, 2009 | 11:04 PM
  #137
cobalt05blue's Avatar
nice write up, i might do this
Old Jul 26, 2009 | 11:15 PM
  #138
jschatte's Avatar
Yeah you could definately do it with the two sets of leds. Or you could try the other way, by building a small curcuit board like i did. The scematics of this board are posted up on the other LED taillight how to, a couple pages in. This way only requires one set of leds.
Old Aug 9, 2009 | 03:04 PM
  #139
SS Gordon's Avatar
This is a great Idea & write up as I just got mine done & I was thinking about also doing the outside lights to match but was woried about the LED life span & having to replace them.
I did get the WFLB96 series 96-LED Waterproof Flexible Light Bar I listed in the above post & it worked great & I used red as these leds are 1/4" tall & I was afraid of the white bleeding into the reverse light area. And instead of a drill I had a dremel with a drillbit & it worked great to romove the seal or glue.
Thanks again for the How to & idea as I love the looks of it heres a picture
Old Aug 20, 2009 | 06:55 PM
  #140
LTBALTBMX's Avatar
Well I cracked mine open today... I wouldn't say the job was overtly hard, here's a protip:
Pierce the sealant and use a screw driver to pry it up so it comes out as 1 long strip of sealant. The hardest part is that initial piercing then its cake walk after. Using a hairdryer helps a lot and prevents the strip from breaking. Also, WD40 makes the job go a lot quicker.
Old Aug 20, 2009 | 07:39 PM
  #141
09turbo's Avatar
dont use a hair dryer just pop'em in the oven
Old Aug 20, 2009 | 08:33 PM
  #142
jschatte's Avatar
how are you guys doing this? that sealant is like cement!
Old Aug 20, 2009 | 08:40 PM
  #143
LTBALTBMX's Avatar
Read my post above, only getting the initial cut is a pain in the ass.
Old Aug 20, 2009 | 08:44 PM
  #144
jschatte's Avatar
yeah i did read it, ill have to try that as i am cracking open my outers. Im also curious what temp and time you put it in the oven for.
Old Aug 20, 2009 | 08:54 PM
  #145
LTBALTBMX's Avatar
Hairdryer, man. I'm just wondering, does anybody know a good place to buy the LED strips in Toronto? I don't feel like ordering online... Also, How long of a strip do I need to do a full 360 for one light?
Old Sep 29, 2009 | 03:02 PM
  #146
Sweetsandman's Avatar
bump cuz I'm about to do this and will need the instructions pretty frequently ha ha
Old Sep 29, 2009 | 03:04 PM
  #147
WVsuperSS's Avatar
id eff that up sooooo bad, any way great job man...
Old Feb 8, 2010 | 07:53 PM
  #148
TommyP's Avatar
AWD > FWD
has anyone tried this with putting the lights pointing outward instead of upward? as in towards the outside of the light and not towards the red lens? like this
I'm thinking this might eliminate any chance of getting light in the reverse part and would give you a better spread of light because it would use the entire reflector to illuminate the red lens
Old Feb 15, 2010 | 03:12 AM
  #149
jefferyss's Avatar
did you not see the pictures in the first post? there is no light that comes through the reverse light area.if you were to turn the lights 90 degrees like your thinking you will waste the light on lighting up the outter edge of the trunk lid around the light.the output of the light will be focused on the edge of the light /trunk instead of focusing it straight out of the light.
this way works....its a very sipmle mod..... and it looks great once its done.
you are more then welcome to use my write up to do your adaptation of these lights......but when you fail, dont reflect it on my thread
Old Feb 15, 2010 | 06:42 AM
  #150
Gestapo007's Avatar
that black sealent gunk....is the WORST. lol. looking at the OP pics brings back nightmares
