Wheels/Tires: How to: Clean your filthy polished wheels
Tools Needed
Large plastic bags (garbage bags), baking soda, vinegar, a bucket, hose, water, rags
Project Time
1-4 hours depending on how dirty they are and how clean you want them
Project Cost
Free - $5
Materials
Note: this how-to is for rims that have some major dirt caked on them, or seemingly impossible-to-clean stains on your rims. However, you can still use this method on not-so-dirty wheels. The materials can be used on alloys, aluminum, steel, basically anything.
It is easier to clean with the wheels off the vehicle, but this is not necessary.
Note: this method is a lot easier and much much cheaper than using chemical cleaners. It is 100% safe for your rims. Some commercial cleaners contain ammmonia or other chemicals that will tarnish your rims over time. This method is failproof and will keep your chrome rims looking great and shiny for a long while. Not recommended for painted or plastidipped rims.
Note: this method is a little time consuming, but it is only necessary when rust has accumulated in your rims or they have dirt caked on the for a long while. After cleaning them, maintain their condition with regular washing and waxing so you don't have to spend this much time later on. I only had to do this because I had stored my rims in a barn through winter without covers. Dirt had accumulated and stains too.
Note: Don't mix the baking soda with vinegar in the bucket. You will get a large frothy reaction.
Keep in mind that mixing the baking soda and vinegar will neutralize both substances - you will lose the acidity that vinegar brings into the equation, therefore wasting your vinegar entirely.
Furthermore, you would need a hell of a lot of baking soda if you would mix the two. Remember, you are using the baking soda as an abrasive, and it needs to be in powder form (even slightly mushy power form) to act as such. Mixing it with water and vinegar will dissolve it and so it wouldn't be able to get rid of those stains and rust.[/QUOTE]
Project Time
Project Cost
Free - $5
Materials
- Pull rims out of storage or off your truck. Lay them on the ground, on some plastic or bags to keep them clean and prevent scratching them. Its easier if you do the inside of the rim first. Do 1 rim at a time.
- Pour vinegar into the bucket. Dilute with some water (diluting is not necessary, it just helps increase the amount of solution you have - vinegar ain't free.) Diluting makes the solution less acidic but pure white vinegar isn't acidic enough to damage your rims anyway. Throw a couple rags into the bucket. Don't add too much water or you will lose the purpose of using vinegar.
- Spray rim down with hose to dislodge any loose dirt and to get it wet.
- Using a vinegar-soaked rag, scrub interior of wheel. Toss rag back into bucket. Hose rim down again to wash off vinegar. You don't want vinegar sitting on the rim for too long.
After scrubbing with vinegar:
- Pour baking soda into hand or onto slightly damp cloth. Use a decent amount. (i found using my hand was easier, but after doing 4 rims with bare hands I had cuts all over my hands).
- Using hand or cloth, scrub rims with the baking soda. This will get rid of rust, surface dirt, or surface stains. Baking soda is a fine powder that acts as an abrasive (kind of like sandpaper). It is not rough enough to damage the rim, its cheap, eco friendly, extrememly effective at cleaning and easy to wash off. It will not tarnish your rims. Dont worry about damaging your rims with it.
- Rinse rim off. Shake your head in awe at your rim that now looks new!
- Flip rim over. Repeat 3 to 7 for face of rim.
Before:
After vinegar and spray down: (Note there is still stains on the rim)
- Apply baking soda:
- Rinse and marvel at your work!
Stains all gone:
- Dry rim off with cloth, or leave to air dry.
- Repeat for all 4 rims.
- Polish with Mother's rim wax. Polishing is easier with the wheel off the vehicle.
- Reinstall rims
- Enjoy as peoples' heads turn, watching your vehicle go down the street.
Would this work on ss/tc alloys to remove heavy brake dust buildup as well? No matter how much wheel cleaner I use theres always just a little bit of brownish residue remaining...
