Electrical: How To: Factory Cruise Control and Remote Radio Control Installation (2007- 2010)
Old Nov 25, 2009 | 05:15 AM
Nighthawk243's Avatar
OK. I got mine installed.
The harness from the HHR forum is NOT the same as the one from the Cobalt. The one we have has 3 connectors: 2 bezel connectors, and then a connector for the horn switch (red connector).
Old Nov 25, 2009 | 11:20 AM
Maven's Avatar
Originally Posted by Gimpster
Do any of you guys know the p/n for the wheel trim pieces WITHOUT controls/buttons? I don't like steering wheel controls and been wanting to delete them. Not sure if there is a bezel for the left side without em or not?
The Corvette was available without any wheel controls. 05 and 06 I believe.
Old Nov 25, 2009 | 11:47 AM
JL-KA's Avatar
Originally Posted by 09blackonblack
VERY IMPORTANT UPDATE...
on my 09 i bought a used ss steering wheel and plugged in it and it worked without adding any wires for the radio... i already had cruise control it mutes the radio track up track down volume up volume down. just thought some of you would like a heads up
This is what I don't understand. I saw an HHR post that said this also. How is this possible?
You simply put on the new steering wheel with absolutely no conecting of new wires?
Old Nov 25, 2009 | 12:48 PM
warrenb213's Avatar
this may have been something GM changed to cut costs.
perhaps they already have cruise enabled, so they could save time in production. I'd imagine this may be an 09+ thing, I'll try it on my 07 soon enough.
Old Nov 25, 2009 | 01:17 PM
JL-KA's Avatar
He already had cruise...I'm talking about audio. And if I remember correctly the HHR was a 2007. I'll try to find the post.
Here is the one I was thinking about
https://www.cobaltss.net/forums/show...radio+controls
From what I'm reading, it seems like if you have cruise already then you don't need to wire anything to get audio...just a simple swap
Can anyone confirm this?
Old Nov 25, 2009 | 07:39 PM
The wires to add the radio controls are there. I added bezels and the harness from a donor wheel (leather on the donor was not up to my standard, so I stuck with the stock one) and the wheel audio controls worked right off the bat.
I'm driving a 2007 G5 btw that came with the base model 2007 wheel (Only had DIC controls... nothing else).
As far as cruise, cruise DOES NOT work immediately when connected. You will need to take it to the dealership to have it enabled. GM just flashes the ECU for each car, so the Cruise in cars that didn't get equipped with it from factory will have it turned off in the ECU. The pins on the clock spring socket are there however.
Old Nov 26, 2009 | 12:18 AM
Maven's Avatar
09 and 10 cars are going to be different there is a lot of parts and option consolidation going on since the car is on its way out, expect some 09s to have the harness already and some not to, I would wager that all the 10s will have the audio harness since they all have OnStar. Something new for 2010 is the return of the base model,(LS is an option now again) and for the first time a Cobalt with no air, 2010 is gonna have weird **** happen
Old Nov 26, 2009 | 04:57 AM
Yeah, which is why I suggest verifying the pinouts before ordering. I know changes in the pinouts is causing alot of issues for the HHR guys. Even if someone does end up with the wrong pinout, at least it is possible to fix it.
Old Dec 2, 2009 | 11:14 AM
Success on my 2.2L G5 with just a wheel control (and harness) swap and a reflash. The service manager was dumbfounded.
I think you only need to do the pin additions if you don't have the BCM wiring there to support the cruise (Probably on very low trims of the Cobalt that don't even have MP3 capability or power locks...etc). The G5 Coupe is pretty much equal to the Cobalt LT, so I'd imagine the 07-10 Cobalt LT and higher trim levels are capable of doing just a simple swap. If you have the Grey wire in BCM Pin 61, you should just be able to do the easy bezel/wheel swap method. Mine already had an occupied pin 61 slot (By a grey wire), so it was already wired up to the clock spring.
Old Dec 4, 2009 | 08:42 PM
kafer79's Avatar
Nighthawk....just curious how much were you charged for the ECU reflash?
Old Dec 4, 2009 | 09:50 PM
  #36
Maven's Avatar
Its not actually a reflash its literally a 2 minute procedure, anyhting more than the shops minimum charge is a ripoff
Old Dec 5, 2009 | 12:08 AM
  #37
LTBALTBMX's Avatar
Can you just order the buttons from GMPartsDirect and install them as opposed to buying an entire wheel? I have an 09 LT.
Old Dec 5, 2009 | 03:10 AM
  #38
$67.84. Basically equal to 1 hours worth of labor. This number will be higher or lower depending on what the dealership's labor charge is.
Yes. You need the buttons and the harness that plugs into the buttons. Be warned though that the harness isn't cheap for the Cobalt. It seems to be much more expensive than the one from the HHR. I'd imagine that you could use the HHR's if you just repinned it.
Personally I just bought a leather wheel from LKQ Quebec for like 71 shipped, and I just yanked the harness and buttons out of it. I'm currently selling just the leather wheel (less buttons) on ebay to recover some of that cost.
Last edited by Nighthawk243; Dec 5, 2009 at 03:12 AM. Reason: Automerged Doublepost
Old Dec 6, 2009 | 01:50 PM
  #39
warrenb213's Avatar
the portion they would flash on would not flash my tune away would it? pretty sure it's just setting a value right?
Old Dec 6, 2009 | 03:14 PM
  #40
Maven's Avatar
Nope has nothing to do with your tune, and its not a "flash" its just checking an option box in the BCM, it doesnt even get hooked up to the computer, Tech2 and candi module is all thats needed.
Old Dec 11, 2009 | 01:09 AM
  #41
Cobalt08LS's Avatar
what if i just wanted the leather wheel?
could i just take the harness from my 08ls wheel and plug them into the leather wheel and just have the same controls as my ls wheel but just have a leather wheel?
idc about cruise control and radio i just want a leather wheel
Old Dec 11, 2009 | 09:32 AM
  #42
Maven's Avatar
Yeah leather wheel is a direct swap, just take your switches and bezels and harness and swap em to the leather wheel. Ive got the leather wheel(and all the controls) in my LS.
Old Dec 12, 2009 | 03:59 AM
  #43
Yep. All the bezels fit both wheels. I'm using the cruise and audio from a leather wheel on my stock non-leather one. I already sold the wheel though. You should be able to find stripped 07-10 wheels on ebay though, there are a few.
Old Dec 15, 2009 | 01:06 AM
  #44
Cobalt08LS's Avatar
really? so i can just have the 2 controls on a leather wheel and use it on my ls???
the info button and the back button
Old Dec 15, 2009 | 03:22 PM
  #45
Maven's Avatar
yes really.
Old Dec 15, 2009 | 03:25 PM
  #46
PsychoCam's Avatar
controls harness and plastic bezel.
I have the part numbers for the bezel and control switch but I cannot get a part number for the harness.
there are like 5 different ones to choose from. ced tried helping me out and we couldnt find the exact harness I need.
so i may just buy the whole steering wheel
Old Dec 15, 2009 | 09:11 PM
  #47
Cobalt08LS's Avatar
Yeah all i would need is the wheel leather wheel would be ftw! Idc about cruise or audio controls.so ill swap my bezels and harnesses I just have to figure out who would install the wheel. Im not even guna think about putting it on or messing w it. How much do u think chevy would charge me.? I know a shop who may beable to do it tho. But wanted to know if i should even think about going to chevy
Old Dec 15, 2009 | 11:44 PM
  #48
Maven's Avatar
Any reputable shop should be able to do it for less than an hour labor.
Old Dec 15, 2009 | 11:54 PM
  #49
Cobalt08LS's Avatar
anyone have pix of a ss wheel on a ls with ls controls on it
Old Dec 16, 2009 | 12:20 AM
  #50
I couldn't get a solid number on the harness either. It won't come up in anyone's systems. The harness is a Delphi harness, but not a recongized P/N.
The label on the harness gave the following number: 6092610 00A
It'll look like your current wheel... but only leather wrapped. The airbag emblem will be the same...etc.
Last edited by Nighthawk243; Dec 16, 2009 at 12:20 AM. Reason: Automerged Doublepost
