Electrical: How to install an Interceptor.... :D
Old Aug 9, 2006 | 03:44 PM
ToMeGuN's Avatar
Originally Posted by black06ss
i had that until i just picked a random empty slot and stuck it in there. i cant remember which fuse location it was but i will try to get it for you.
Any idea where ya tapped in the red wire ?
Old Aug 9, 2006 | 04:12 PM
Xenozx's Avatar
The car is providing continuous power to the Interceptor then. this issue is not the gauges fault its the cars. Where did you tap into the power at? You want to tap into a fuse that powers down when the car is off. Your radio doesnt stay on when you shut the car off does it? So if you tap into the radio fuse the Gauge will shut off with the radio. If you tapped it into your dome light, then it always has power going to it so then so would the interceptor. To me it sounds like you didnt tap it into an accessory switch and you need to tap it off somewhere else. Use the radio fuse or the stock boost gauge wire. both of these power down when the car is off.
Old Aug 9, 2006 | 06:09 PM
black06ss's Avatar
i tried the radio and the gauges but it stayed on so i put it in an empty one here is a pic of where it is i used the add a fuse.
Old Aug 15, 2006 | 06:46 PM
Matty's Avatar
I installed mine today and instead of using electrical tape to hold the gauge in place, I used a rubber band. Works great.
Old Aug 18, 2006 | 01:10 AM
mattieboy's Avatar
i think this is a must have and it is soooo easy to install(compared to other modz)
Old Aug 19, 2006 | 02:50 PM
biohazard's Avatar
Get low
will it do anyhting for a 2.2 balt? i like the HP display, but is it accurate and does it have to say SS edition?
Old Aug 20, 2006 | 10:45 AM
jbauer's Avatar
i don't know about the horsepower accuracy cause i haven't installed mine yet...but i know the SS edition is only an option they make. they make universal ones.
Old Oct 4, 2006 | 10:32 PM
bigd2114's Avatar
anyone know about the hp and option and if there is a lag when it tells u the boost amount
Old Dec 26, 2006 | 12:21 AM
fWdCoBaLt's Avatar
nice write up for install. will be using your method very soon
Old Dec 26, 2006 | 07:58 PM
an0malous's Avatar
for those wondering about the shift light....read the instructions :P
you have to go into your menu and turn your datarate up to its maximum (which happens to be 1)
your shift lights ONLY work when your guage is datalogging at its highest speed.
Old Dec 27, 2006 | 12:35 PM
  #36
Coblt ss super's Avatar
wow thats crazy i did not know the install was so ez i may wanna order my interceptor soon
Old Jan 21, 2007 | 06:46 PM
  #37
dervin3's Avatar
Looks great! I'm gonna order one along with the AEM wideband gauge. I'm gonna get CA's 3-gauge pod and put the stock gauge, and interceptor, and wideband. Does the stock gauge fit in the CA 3-gauge pod? Also since I can't tap into the stock boost gauges wiring, I have to go to something in the fuse panel. Are there unused fuses in there or will something have to share power? Finally, is the wire easy to run(as in no drilling through firewalls or anything?) I'm no electrician so sorry about questions about basic stuff lol
Anyone?...please...
Old Jan 28, 2007 | 07:02 PM
  #38
staged06's Avatar
So am I reading this correctly that you can turn off the shift lights if you want because I already have a raptor and I dont really want them on too.
Old Feb 5, 2007 | 09:47 PM
  #39
Boost Fr33k's Avatar
hey good write up, quick question because i bought this gauge but im some what noob. all the data it proclaims to read is purely plug and play? in other words, just by installing it like you did we'll be able to recieve all this data?
Old Feb 5, 2007 | 10:40 PM
  #40
dervin3's Avatar
Yep, any of the 25 or so parameters...2 at a time.
Old Feb 12, 2007 | 12:15 PM
  #41
SS/SCking's Avatar
Can I just tap the pink wire to get power? I want to keep the stock boost gauge and put this in with it on the piller.
Old Feb 20, 2007 | 12:08 AM
  #42
chipmonk212121's Avatar
this only took me 20 minutes and that inclided trying to figure out what size socket to use...... BTW i used a 9/32 (i think) socket to get the a-arm off. i did it all while sitting in my car and only having the light under the rearview mirror. now im gonna read the directions to figure out how to really sue it....
Old Mar 13, 2007 | 08:46 PM
  #43
Coop's Avatar
Where an you get these and how much are they? What functions do you have with this?
Old Mar 16, 2007 | 07:03 PM
  #44
I WANA KNOW THE SAME THING!!
hey ss/scking, im almost positive that we can do that but i just wana make sure.
Old Mar 17, 2007 | 11:52 PM
  #45
memphisr24's Avatar
Yeah, that's how I have my interceptor installed...However, in my opinoin, and in a lot of other people's opinions, it would be better to get power from the fuse box. At the time I installed it, I wasn't really there.....I was kind of....tipsy lol
Old Mar 18, 2007 | 03:31 AM
  #46
haha the way to go when it comes to your car!!! i actually installed mine today already. tapped into the stock boost pin wire. works great!!
dude idk how accurate this thing is but im pulling 229 horse power in 3rd gear pulls
Old Mar 18, 2007 | 03:50 AM
  #47
memphisr24's Avatar
The hp calculator isn't accurate, everything else is though. Oh and the 1/4 mile time is slightly off, the trap speed is about 3 mph high from my experience. But yeah, the best $225 i've ever spent in my life. The guage works wonders. I just wish it was able to calculate a/f ratios.
Old Mar 24, 2007 | 05:36 AM
  #48
justin04's Avatar
the info for the aeroforce interceptor says it can scan and clear codes could this product turn like low coolant light off? and or move up the rev limiter? and i heard something about data logging do i have to hook this to a computer?
Old Mar 24, 2007 | 10:31 AM
  #49
myoshizawa819's Avatar
I have had an Interceptor installed for a long time. That install is kinda getto. My gauge came with a metal bracket to go over the threaded studs on the back to hold it in place rather than using tape or rubberbands. Also, don't butcher your harness, run a separate power cable to the fuse block! HOLLA!
Old May 18, 2007 | 01:01 AM
  #50
dhutch's Avatar
Once my car gets fixed...I'm ordering one of these bad boys!
