Electrical: How to install an Interceptor.... :D
Old May 13, 2008 | 03:38 PM
  #76
wisemanonice's Avatar
just got my dual interceptors and these pics dont work....
Old May 13, 2008 | 03:40 PM
  #77
Texas SS's Avatar
Originally Posted by Billig ss/sc
So am I the only one who can't see the pics on the first post? I'm probably going to be getting my Interceptor in the next week or two and obviously pics would be pretty helpful haha
haha i cant either
Old May 13, 2008 | 03:44 PM
  #78
does anybody have these pics saved or something and maybe want to send me them?
Old May 14, 2008 | 03:57 AM
  #79
krazycobalt's Avatar
Very much appreciated if i could some how see these pics...???
Old May 14, 2008 | 09:42 AM
  #80
Xenozx's Avatar
Sorry guys, I changed my domain, but the pictures are still hosted on the new one. It wont let me edit my post so ill just post the pictures here instead, unless a MOD is willing to change the URL's from
www.xenozx.com
to
www.xenshardware.com
OK seems to be some confusion on this, so I will post up my install of the Aeroforce interceptor.
You have to start by taking this hex bolt out of your a pillar. I am not sure of the size, but IM pretty sure its in any standard issue hex set as its in mine.
Once you have it removed the A-pillar should just pull out. There are 3 small clips holding it in place. You cant break anything so just pull it and it will pop off.
This is what holds the stock gauge in place. 2 small bolts. Losen these and the stock boost gauge should pull right out. also you must unclip that clip.
The Interceptor will not stay in place the same as the stock gauge. If you LOOK CLOSELY here you can see I wrapped the rim of the Interceptor with Electric tape.
I wrapped arround until it fit snug in the housing.
Here you can see it snug in place, and keeps it from moving and falling out. Very easy way to mount it IMO, and allows adjustment on the fly if needed
Here is the stock harness that was connected to the stock boost gauge. I cut this off of the boost gauge and used tapped off the pink wire to power the new Interceptor.
You can just tap off a wire if you find it easier as you dont have to damage the stock wiring, however I found this way more effective.
Here is the stock connector from the stock gauge spliced into the interceptor wiring.
Here is another clsoe up.
This shows how I ran the ODBII cable. I just pushed it inbetween the plastic and the weather stripping using a flat head screw driver. Very easy and once its back there its not noticable at all.
Another showing the wire being pushed through.
Once you have that completed you will have something that looks like this.
I just pushed the excess wire up and into the crevace, again completely un-noticable.
After that. Just reconnect everything and push all the excess cables down near where the A-pillar first inserts itself. Push the A-Pillar in place and make sure all three clips click. Then put the bolt back in and your good too go. of course before you completely reconnect everything you may want to turn your car on and make sure the gauge works incase you need to double check your wiring.
This is what you can expect when completed
Enjoy!
haha I tried to be sneaky and edit it via URL, but I get this message
The administrator has specified that you can only edit messages for 432000 minutes after you have posted. This limit has expired, so you must contact the administrator to make alterations on your message.
Old May 14, 2008 | 09:43 AM
  #81
USMCFieldMP's Avatar
Rattlesnake Race Shop
Thanks for the Pic update.
Old May 14, 2008 | 12:00 PM
  #82
Billig ss/sc's Avatar
Thank you!!!!!!!!! haha
Old May 14, 2008 | 02:13 PM
  #83
thats awsome man. Now Im just stuck on how to power it. I have the dual guages and I heard that the boost wite wont be able to power both guages. I was told to use the ignition, do you know how to do that?
Old May 14, 2008 | 02:28 PM
  #84
I thought you could run power from another fuse in the car?
Old May 14, 2008 | 04:08 PM
  #85
I think you can. I just dont know how. I might just end up putting all of the gauges on a switch and use it like that. I guess its not a big deal. If im cruising at night and dont want the light in my eyes
Old May 14, 2008 | 04:37 PM
  #86
blue06's Avatar
Tap into the Ignition fuse in the fuse box with a add a fuse
Old May 15, 2008 | 03:50 PM
  #87
thats a lot this is going to help a lot when it arrives hopefully today or tomorrow
Old Jun 4, 2008 | 12:12 AM
  #88
chevy cobalt 08's Avatar
DAMN! I wanna do this so bad, But I have a sedan and the coupe is 1.5 inches shorter
Old Jun 4, 2008 | 12:55 AM
  #89
huh? this gauge works on both cars. just have to get the right version when you buy. installing should be the same
Old Jun 4, 2008 | 01:11 AM
  #90
I'm non SC I don't have the gauge pillar. A member on here was gonna custom make me one and then just suddenly stopped answering my PM's. ?!?!?!?!? And no I don't wanna do steering wheel pod. I want pillar pod!
Old Jun 4, 2008 | 01:13 AM
  #91
CobaltSS 16's Avatar
How does the red interceptor gauge match up against the stock speedometer?
Old Jun 4, 2008 | 01:30 AM
  #92
that sucks that they dont make a pod for you man. I have a buddy with a redline and he just kinda screwed a dual pod onto his a pillar.
I think the red is a different shade than the cluster. I personally went blue (favorite color) But red wouldnt look bad Im sure
Old Jun 4, 2008 | 01:44 AM
  #93
95cam86roc's Avatar
subscribed
Old Jun 4, 2008 | 01:51 AM
  #94
hmm know where I might be able to find a single pod to screw into my pillar then? also do you have a pic? I wanna see if it looks tacky screwed in.
Old Jun 4, 2008 | 06:14 AM
  #95
Old Jun 4, 2008 | 09:51 AM
  #96
Xenozx's Avatar
looks good
Old Jun 4, 2008 | 11:48 AM
  #97
Sorry no pic. Im sure someone around here with a redline has it. I can ask my buddy where he got it from though.
Old Jun 4, 2008 | 12:15 PM
  #98
Perfect, that's the exact gauges I'm looking to get (prob keep the stock boost gauge though). Do you have a further picture out of your whole dash and speedometer, etc.? TIA.
Old Jun 4, 2008 | 02:11 PM
  #99
he told me there is a guy on redline forums that makes and sells pods for the pillar
Old Jun 4, 2008 | 11:38 PM
  #100
member name?
