Electrical: How to install an Interceptor.... :D
Old Dec 9, 2011 | 09:31 PM
  #176
snoftall's Avatar
Originally Posted by snoftall
Pictures don't work again...so frustrating! How-To threads should not be approved until the pictures are uploaded and hosted by this website (i.e. cobaltss.net)...that way this problem will not happen.
Does anyone have the pictures saved and want to post them?? Would be greatly appreciated.
Well...don't I feel dumb...apparently it was the domain being blocked at work which was keeping the pictures from being displayed...all the same though, pictures for how-to threads should still be hosted by cobaltss.net rather than a third party...
Old Mar 5, 2012 | 06:18 PM
  #177
bump, pics dont work on this thread anymore
i just got an interceptor and if anyone can pm me on this:
does it ONLY hook up to the obd2 or what are those 3 wires for comingout of the interceptor? power, ground and acc?? anyone that knows how to install this please pm me thanks
Old Mar 7, 2012 | 06:58 PM
  #178
tanelk's Avatar
Look at page 4 I believe, shows pictures
Old Mar 8, 2012 | 07:18 PM
  #179
Keelo93's Avatar
Nice write up, I'd definitely consider doing this if I had a Cobalt. -_-
Old Mar 9, 2012 | 05:32 AM
  #180
tanelk's Avatar
So basically u just splice the red wire into a fuse and plug the obd? What about the white and green wires
Old Mar 9, 2012 | 05:45 AM
  #181
robd53's Avatar
White and green wires are the analog inputs. You don't use those unless you have extra sending units from Aeroforce for the gauge. I just installed mine a few weeks back, I hooked up the red wire to a switched 12 volt, and removed the jumper on the back of the gauge. If you don't do this, it won't power up and down correctly. Yes so just the red wire to a switched +12 volt, and plug in the OBD plug. You can leave the OBD part plugged in all the time.
Old Mar 10, 2012 | 09:24 AM
  #182
tanelk's Avatar
I just installed mines, easy as hell only took 10 mins. How do I set up the shift lights?
Old Mar 10, 2012 | 09:47 AM
  #183
tanelk's Avatar
When the interceptor starts up it says annucator not set up, can someone tell me step by.step on how to do it
Old Mar 10, 2012 | 10:41 AM
  #184
robd53's Avatar
I don't know how much that part of setup changed from version to version, but here's the list from Aeroforce.
Aeroforce Technology Inc | Interceptor Manuals
Old Mar 14, 2012 | 12:40 PM
  #185
michiganfootball911's Avatar
does the Aeroforce Interceptor read air/fuel ratio for the lnf?? Does it need any additional wiring harnesses?
Old Jun 5, 2014 | 05:55 AM
  #186
street253's Avatar
So I don't have the red wire is it easily replaceable?
Old Jul 9, 2014 | 08:51 PM
  #187
Tony Pshenichnykh's Avatar
need different write up. The pictures don't show anymore
Old Jul 9, 2014 | 10:43 PM
  #188
tuned08ss's Avatar
Yes and no. Plug and play
Old Jul 14, 2014 | 03:21 PM
  #189
Anyone got a new write up with pictures? Thank you
Old Nov 27, 2014 | 09:14 PM
  #190
dufcobalt's Avatar
pictures dont works.....
Old Apr 6, 2015 | 09:20 AM
  #191
killcitytx's Avatar
Pictures?
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
