All Engines: How-To install spark plugs
Old Jan 9, 2007 | 09:50 PM
joeworkstoohard's Avatar
Originally Posted by OniMirage
oh yeah you rub that compound in work it work it lol
FINALLY, someone caught that.
Originally Posted by marerick007
Cool vid...I was looking forward to your sister doing some crazy **** again!
my sister is like me, she's a camera *****... but if i let her be in more of them, then there'd be more of her shaking her ass in them.
Old Jan 9, 2007 | 09:53 PM
OniMirage's Avatar
???????????????????????????????????? have a vid to share that we dont know about ?????????????????????????????
Old Jan 9, 2007 | 10:02 PM
not that you goofballs will ever see, or that i'm happy that i ever did.
Old Jan 9, 2007 | 10:12 PM
OniMirage's Avatar
ahhhhhh thats too bad your such a tease as your explanation of compound application suggests
Old Jan 9, 2007 | 10:26 PM
shadowfaxss's Avatar
Great vid!!! I just wanted to add some things that typically happen when do it yourselfers change plugs in an overhead configuration.
1. As you notice on the video a spark plug socket with a rubber insert was used. You may find out that after you install your first or second plug and pull the extension and socket out that the rubber stays on the plug instead of inside the socket.....It is inevitable if the socket is used over a period of time.
I keep two spark plug sockets for this reason. One is used to remove the spark plug, the second is used to install the spark plug. On the second socket I use just enough di-electric grease to allow the spark plug to stay fixed to the socket while lowering it into the cylinder head but it is just enough that the socket will come off with the rubber insert.
2. Another item you can use to coat the threads of your spark plug is never-sieze (you can't put it on your plug wires). It is a gray compound that contains graphite.
Don't mean to steal your thunder but this will happen to someone eventually.
Old Jan 19, 2007 | 02:35 AM
mastoer's Avatar
kool video i tired yo do mine but i was like fudge it i got frustrated until this video
Old Jan 19, 2007 | 06:06 AM
Forseti's Avatar
You put dielectric gel on the threads? I thought dielectric gel was only for the point the coil mounts to...and that anti seize was for the threads....
Old Jan 19, 2007 | 10:53 AM
Originally Posted by Forseti
You put dielectric gel on the threads? I thought that was only for the point the coil mounts to...and that anti seize was for the threads....
you can use dielectric on the threads... you can also use anti seize... but you can't use anti seize on the plug wires.
Old Jan 22, 2007 | 01:45 AM
Forseti's Avatar
The heat on the threads would be high...not sure if dielectric gel would be a good choice for threads. No telling how a particular formulation may react to sustained high metal to metal engine heat....
The tip of the electrode is thermally insulated to some extent by the ceramic portion of the spark plug....
I don't think I want to leave dielectric gel for roughly 30000 miles on the plug threads....just our luck it would cure into glue or something...
Old Jun 19, 2008 | 06:06 PM
  #36
ViSiONZ's Avatar
Just saw this video now. Nice how-to bro
Old Jun 19, 2008 | 06:17 PM
  #37
PimpLay2's Avatar
nice vid bro i give u props
Old Aug 21, 2008 | 06:50 AM
  #38
PinaSS's Avatar
Originally Posted by Codyak Supercharged
good job dude, haha sparkplugs are not a mod! LOL thought that part was funny.
I think spark plugs are a mod cuz ur getting better performance spark plugs compared to the stock ones. For example getting step 1 colder spark plugs.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
justinchinn
Oct 2, 2015 12:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
