General Suspension: How to Install springs
Old Jun 16, 2008 | 09:40 AM
  #76
celicacobalt's Avatar
good thread, i will be using this when my springs come in.
Old Jun 28, 2008 | 01:49 PM
  #77
Jn2's Avatar
Jn2
my springs came in today, im hoping the electric impact will be enough for that strut bolt, as it seems to be the biggest pain in the whole install
Old Jun 28, 2008 | 03:36 PM
  #78
thebucky84's Avatar
awesome "how to" post!!!...i just lowered my car less than an hour ago and this realy helped!!! thank you!
+1
Old Jun 29, 2008 | 02:20 AM
  #79
116Fanatic's Avatar
Ok, I installed the Eibach Sportlines on my 2.4. Everything went great. I removed the TOP shock bolt on the rear I don't know if that makes a difference but now that the springs are on the rear passenger spring makes weird creaking noises. I took everything off again after a day of creaking to look at it...it looked a little twisted but nothing really bad...I adjusted it to make it look EXACTLY like the other side and its still creaking. I Just can't figure out what it is. Could it be a faulty spring? Could it somehow posibly be the clear rubber wrapped around the spring? PLEASE someone help me!!
Old Jun 29, 2008 | 02:42 AM
  #80
Jn2's Avatar
Jn2
there some pics, between me and a friend, we got it done in 2hrs...we used air tool and a electric impact, also before the drop i could fit my fist in the wheel gap and still be able to move it up and down, now i can only get 3 fingers on the front, 2 in the back got to love them tenzo's. now since i didnt get done late, and its saturday i have to wait till monday for a aligment
Old Jun 30, 2008 | 01:28 AM
  #81
116Fanatic's Avatar
anyone??
Old Jun 30, 2008 | 02:04 AM
  #82
thebucky84's Avatar
i not an expert in this area of the a vehicle, but maybe its just settlin in?..dont kno though
Old Jun 30, 2008 | 12:24 PM
  #83
Halfcent's Avatar
I'm old school
Originally Posted by 116Fanatic
anyone??
Springs by themselves dont make noise. Usually its the mounts. Check the top and bottom spring buckets. Clean them out, check the mounts for tears or cracks. It doesn't matter which shock bolt you removed. But the shock itself could also be the culprit.
Old Jul 13, 2008 | 10:57 AM
  #84
wbrevels's Avatar
STEP: "-Take out the 2 bolts holding the lower part of the front strut on..."
i can get the nuts off but can't get the bolts out, any advise? please help soon!
Old Jul 13, 2008 | 02:55 PM
  #85
Jn2's Avatar
Jn2
hammer them out, they are pressed in, use a hammer and hi the threading side to get them out, the holes dont hav threading, so once u beat them out they should slide off...good luck
Old Jul 13, 2008 | 03:26 PM
  #86
wbrevels's Avatar
great write up, thanks for all he info and a successful install.
Old Jul 13, 2008 | 05:33 PM
  #87
BULLETSSMOKE's Avatar
the top pain in the ass strut bolt can EASILY be solved with an impact wrench. vice that sucker and grab the right socket and unbolt away. just press down hard and keep gunning it, itll come loose. same way with reinstallation.
Old Jul 13, 2008 | 11:41 PM
  #88
n0xid's Avatar
Having trouble getting the stabalizer link nut back on fully, just seems to spin in the bushing, anybody have an idea?
Old Jul 13, 2008 | 11:44 PM
  #89
D4u2s0t's Avatar
mine are like that too, can't even get them off with an impact wrench.
i use a small pair of vice grips, there's just enough space behind the bushing to get a small pair on there. should go on after that.
Old Jul 13, 2008 | 11:57 PM
  #90
n0xid's Avatar
Funny, we tried that and everything else. Do you mean like just in front of the rubber part? That is what we were trying to grip.
Old Jul 14, 2008 | 01:33 PM
  #91
behind the bushing. try grabbing it and screwing the nut on manually ALL the way down then back off. should make it easier, then put on the vices in the backside and screw it back on.
Old Jul 14, 2008 | 07:24 PM
  #92
n0xid's Avatar
Letting a shop deal with it while I get the alignment done, then I can blame them if it screws up
I love having almost no body roll
Old Jul 17, 2008 | 03:35 PM
  #93
scampbell's Avatar
Nice write up man im gonna be using it tommoro when i pick up my sportlines from another member. Got a question for anybody who might know this though...if i put my stock SS/SC springs on my girlfriend LT will there be any drop or difference in handling?
Old Jul 17, 2008 | 04:09 PM
  #94
D4u2s0t's Avatar
will be about a 1/2 drop all around, and will be better handling. not as good as aftermarket, but much better than stock 2.2 springs.
Old Jul 17, 2008 | 04:16 PM
  #95
scampbell's Avatar
thanks man thats about what i figured.
Old Jul 17, 2008 | 04:18 PM
  #96
D4u2s0t's Avatar
you're welcome. and even though it's only like a 1/2 inch, it makes a big difference appearance wise since the 2.2 looks like a monster truck. any lil bit helps!
Old Aug 21, 2008 | 06:06 PM
  #97
dman090's Avatar
subscribed
Old Sep 5, 2008 | 10:08 AM
  #98
Snakes709's Avatar
going to be installing my eibach sportline springs tomorrow. how much of the bump stop should i cut off?
Old Sep 21, 2008 | 07:00 PM
  #99
ACESSbalt's Avatar
click
Old Oct 29, 2008 | 09:17 PM
  #100
jareds064drSS's Avatar
i just got my sportlines in hopefully this write up will help me instal them
