Interior: How to: Install subs and amps with original H/U (with pics)
Old Aug 2, 2010 | 08:42 AM
scottie's Avatar
Originally Posted by pursuitforever
i dont understand why u needed a switch with the amp. should it not turn on when ur car does?
They just wanted the option of a way to turn it off while still listening to the radio with the car on. Its a nice option to have. Especially if you have dick cops around. Or in that one guys situation where his mom drove his car. She wouldn't have to figure out how to lower the bass.
*parents and their technology.
Old Aug 5, 2010 | 03:19 PM
Omega1x's Avatar
Originally Posted by MannyP
do you have to add the switch?
i got two jl audio 12" subs and a 600W amp already on the side of the box
i have the 10" pioneer already in there, is there anyway i can run the wires from that to my sub?
This is what I am doing at the moment. You will have to splice (or cut completely) the wire that leads from the factory amp to the sub. I can get pics later.
Originally Posted by SWmaster
I doubt the stock amp would be damaged by hooking a different sub direct to it but it would be quiet as hell since the stock amp doesn't put out much power. FYI the stock sub is a standard dual voice coil 2 ohm sub that handles around 50 watts.
That is why the best thing to do is run the stock sub signal left and right into an amp with hi level inputs like I did. Saves you the need to get a hi level to low level converter and has less things to go wrong.
Actually, it's a 2+2 ohm sub, seing as it's dual voice coil. And from what I've heard, it's actually rated as a 300W sub(peak), so prolly 150 RMS(constant).
Old Aug 5, 2010 | 07:04 PM
SprChrg4Life's Avatar
holy dead thread revival, batman! the switch is definately cool for the mom or dad who wants to kill the amp.
as for turning on the amp w/ the car, you can totally hookup the remote wire of any amp to any fuse that gets power in acc or run. then the amp turns on and off w/ the car, no switch needed.
For those that wanna add any amp for either internal speakers or subs, use that fuse #18 as bansaw suggested and then you won't need a switch.
as for turning down the bass, some sub amps have remote bass knobs like what i had with my old RF Punch amp. Turn the knob, lower the bass, life is good. also helps control sub bass when you raise and lower the bass settings in the stock HU. IF your system isn't tuned with test tones and your sub bass is much louder or quieter than the midbass from your inside speakers, and you adjust the bass on the HU, you'll effectively change your sub bass as well. A seperate knob for the sub amp only is a great feature to have. Good to know for any1 wanting to upgrade
Old Dec 15, 2010 | 11:33 PM
thefinalgamer's Avatar
what line out converter did you use?
something like this? Scosche LOC80 2-channel line output converter at Crutchfield.com
Old Jan 12, 2011 | 05:18 PM
blackss2.0's Avatar
Why did you need a switch?? I just wired the control wire from the amp to my power windows fuse.
Old Jul 7, 2016 | 05:13 AM
Nnelson's Avatar
What wires do I connect to fit the back speakers
Old Mar 13, 2017 | 08:50 AM
Bryan Michael Wood's Avatar
Ground
Where is a good spot for their ground wire? As most of the trunk interior is aluminumim havingtrouble with it.
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
c_m_shooter
Sep 27, 2015 04:40 PM
