Exhaust: How-To: Installing HIDs W/ Relay Harness
Old Dec 16, 2010 | 01:11 PM
  #51
mkulrey13's Avatar
Originally Posted by Turbalt2010
ok im going to be installing my H1 hids in my projectors tomarrow, where do these 2 wires have to go?
they dont plug into the stock harness right? cuz my projectors are plugged into there.
They plug into your projector harness..
Old Dec 16, 2010 | 04:29 PM
  #52
Turbalt2010's Avatar
ok im doing these first thing tomarrow morning. hopefully all goes well haha.
thanks for the help.
Old Dec 20, 2010 | 04:42 PM
  #53
ujustgotshook713's Avatar
I am starting my installation...NOW. Might be back in a few minutes if run into a problem
Old Dec 20, 2010 | 04:50 PM
  #54
umrdyldo's Avatar
Couple things I wouldn't mind seeing added to the install.
1. On the stock headlight housing there is a bracket that hold the bulb in place. i had to pull the wiring for the HID bulb through the bracket to get these into place. Was that the correct way to do that? I found no mention of it. The bracket is round if that helps
2. I thought it might be best to not have the EXTERIOR LIGHT function turned off in the DIC menu. Seems like it's a good idea for HIDs
Old Dec 20, 2010 | 07:38 PM
  #55
yea, My H1 bulb doesnt fit right...what do i need to "drill"...
Old Dec 20, 2010 | 07:48 PM
  #56
mkulrey13's Avatar
Someone has made a how-to somewhere on this site. you basicly still a hole where the lead wire on the bulb goes.
Old Dec 20, 2010 | 08:46 PM
  #57
already got it in almost finished !
Old Dec 21, 2010 | 12:10 AM
  #58
bamaboy22's Avatar
Fogs do a write up on them unless I missed it
Old Dec 21, 2010 | 08:32 AM
  #59
Its the same exact thing. Just put the bulbs in the fogs and not the headlights. And mount your ballasts in a safe spot.
Old Dec 22, 2010 | 07:12 PM
  #60
wWaldo's Avatar
my car is off and my HIDs r on.. LMFAO?? theyre draining my battery!
Old Dec 22, 2010 | 07:36 PM
  #61
RedStil's Avatar
did you check that you didnt connect the plug on the relay harness on the passenger side?
Old Dec 22, 2010 | 07:47 PM
  #62
wWaldo's Avatar
i removed one wire it was on the passenger side it had a red/black wire
That..
Old Jan 5, 2011 | 08:56 AM
  #63
trey ss's Avatar
yeah if some one does the hid install on 1st gens please post pics!
Old Jan 30, 2011 | 08:28 AM
  #64
ericgt79's Avatar
sub'd
Old Feb 2, 2011 | 07:54 PM
  #65
ericgt79's Avatar
damn dont have a harness
Old Feb 2, 2011 | 08:23 PM
  #66
JacBlackSS/TC's Avatar
ok i got a relay with my lights but i still kinda flickering what do i wire to the fuse box just on the post in the one of the pics it looks like something is done to one of the actual fuses
Old Feb 13, 2011 | 09:38 PM
  #67
Rage915's Avatar
will use this
Old Feb 15, 2011 | 02:05 AM
  #68
Drew.4L's Avatar
are these going to be the same steps with out relay harnesses? i didnt buy them... figured id go without till summer.
Old Feb 15, 2011 | 08:52 PM
  #69
Drew.4L's Avatar
wait a second... did mine come withthem? i have the bi xenons, and i followd this and it came with all the materials.
Old Mar 7, 2011 | 12:19 AM
  #70
SupaCharged06's Avatar
bump. it is safe to put HIDS in 1st gens right?
Old Mar 7, 2011 | 12:29 AM
  #71
Cobalt08LS's Avatar
yes
Old Aug 31, 2011 | 02:19 PM
  #72
user 70823082's Avatar
Why is this labeled under Exhaust? lol
Old Sep 5, 2011 | 12:56 PM
  #73
keiserX13's Avatar
cuz mikes a noob
Old Nov 5, 2011 | 04:54 PM
  #74
sergiochaotik's Avatar
I know this is an old post but... I followed these intructions to the letter and my driver side hid still doesn't turn on. I ran a week with my HID's before a relay. They worked fine (if I had my car on high-beams so it could provide more power) but after a few days, my driver side light would turn on when I turn them on (for about 1 second) and then shut off.. I tried installing the relay today. Now the passenger side light turns on brighter and without the need of putting my car on high-beam mode (which is good and means my connections are right) but for some reason, the driver side won't turn on at all anympore (not even for 1 second like it did earlier today). Any common mistakes or something that I'm not seeing!??
Thanks..
Old Nov 5, 2011 | 06:10 PM
  #75
Nevermind, my driver-side ballast went out. Off to guarantee dealing....
