2.0 LSJ Suspension: How To: Rebuild Front SS/SC Brake Calipers
Old Feb 26, 2010 | 05:28 PM
mkriebs's Avatar
I picked up some junk yard front calipers to put on my 08 SS so I can run slicks. Well, with them being junk yard parts, I wasn't comfortable just putting them on the car, so I decided to rebuild them. A rebuild kit costs about $10 per caliper. This is very cheap insurance, since your life pretty much depends on it.
First, the tools you will need are
- A punch (or screwdriver if you don't have one the right size).
- Rubber Mallet.
- Sockets (10mm,and 11mm, 13m) and a ratchet.
- Vise (unless you have really good grip!).
First, take the pads out and get your bearings with the caliper, if you are not already familiar.
Second, Put the caliper in the Vise, take the Banjo bolt and caliper slide bolts out. The caliper will basically fall into 2 pieces now.
Give the slides a god tug, and they will come out.
Next, take the bleeder bolt out, as it could be corroded much like mine was.
Put the caliper back in the vise, and take your punch or screwdriver and put it in the banjo bolt hole. This will push the piston out the other side. Give this a real firm push, or give it some taps with a hammer. It might be a bit stubborn to get out, depending on the shape of your caliper.
The caliper will slide out, much like this. As you can see, my dust seal was torn, so I am going to have to replace that (I believe it comes in the rebuild kit).
Pull the seal off the top of the piston using a small regular screwdriver.
And lastly, take a small screwdriver, or a seal hook tool (w/e its called) and pull out the oil seal in the caliper. This will be replaced with the rebuild kit as well.
After this, I would recommend soaking the parts in a heavy duty, degreaser/parts cleaner. This will get all the grime off the parts, and will allow you to paint the calipers if you want.
I will show how to put it all back together when I get my rebuild kits in. CED should be able to get them, of not, GMpartsdirect has them.
Old Feb 28, 2010 | 11:37 AM
Black SS/SC 06's Avatar
Approved. Please update the thread when you get your parts in.
Old Mar 26, 2010 | 05:25 PM
rallyracer's Avatar
any pics and info from the rebuild?
how often should one there Brake Calipers?
Old May 31, 2010 | 07:19 PM
Axelthered05's Avatar
good to know
Old Jun 1, 2010 | 10:06 AM
BlackyK's Avatar
4 months later Any updates on the rebuild kit?
Old Mar 24, 2011 | 09:06 PM
NexTnmE's Avatar
Would this apply to the rear caliper also? My rear, passenger side is frozen closed... and pretty sure the pads are gone
Old Mar 24, 2011 | 09:56 PM
xnigelx's Avatar
yeah, but instead of pushing the rear out you need to twist it out.
Centric Rear Brake Caliper Repair Kit
this dude prolly didnt post the pictures because its a pain in the freaking ass to put them back together
Old Mar 24, 2011 | 09:59 PM
NexTnmE's Avatar
hahaha. I'm sure! And that kit is almost the exact one I bought. I got mine from RockAuto.com, same parts tho... actually a little more...
Old Mar 24, 2011 | 10:24 PM
xnigelx's Avatar
rockauto.. i was trying to remember that damn site. lol
Old Mar 24, 2011 | 11:49 PM
rallyracer's Avatar
where's the rebuild pics???
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
