Interior: How-To remove door panels
Old Oct 10, 2010 | 06:30 PM
webster8004's Avatar
Originally Posted by Julex
?? Welded plastic?? You can't weld plastic. You can melt it but usually that's not done either.
Cool idea with the fiberglass door panel. I'm thinking of doing the back of my girls cavy and my SS SC behind the back seats where the speakers are mounted. Goodluck on that.
It's called sonic welding, i don't really know how its done but my friend used to work at a plastic factory and it sounds like its done by vibrating 2 pieces of plastic together at a very VERY fast rate
Old Feb 10, 2011 | 12:35 PM
quikdcride's Avatar
hahah i was doing this and i actually ripped the top and bottom apart not realizing i should have read this thread first now ive been driving around all ghetto'd out with the two parts just apart now its gonna cost me 150 bucks for a new panel LOL
any chance we could get some pics up of this?
Old Jul 29, 2011 | 02:30 AM
06_Cobalt SS's Avatar
For the guy with the passenger door not opening....my driver door has done that to me several times.. the easiest way to get your door opened is to use a flat jimmy bar and slide it down from the outside directly above the door handle and you can push the rod down and you will be able to feel it. then your door should open.
Old Nov 17, 2011 | 05:48 PM
nabrian84's Avatar
Old Nov 21, 2011 | 10:59 PM
lilskarvcx's Avatar
can anyone post some pics of the tabs inside the door? I heard they're fragile. I want to fix that dang door handle rattle. Thanks!
Old Nov 22, 2011 | 12:36 PM
nabrian84's Avatar
They are fragile..... they are only a few dollars at any auto parts store tho.... one trick is to slide your panel tool along the doorpanel and try to figure out where the pins are and pry from that area.... there is a lot less of a chance to break them if you pry from right near them.... tho they can still break no matter how gentle you are good luck
Old Nov 22, 2011 | 04:50 PM
lilskarvcx's Avatar
yeah i got it and fixed the rattle, thanks! Now to fix the 3,000 others
Old Feb 25, 2012 | 10:20 AM
mexi_loco's Avatar
sub'd
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
The Rookie24
Sep 14, 2015 07:03 PM
chris88z24
Sep 8, 2015 01:55 PM
