Interior: How to: Remove your passenger airbag
You need to do this if you want to remove your entire dash. I am not responsible for anything that goes wrong so please be careful because messing with airbags is dangerous.
Passenger Airbag Cover Part #: 15814451
Tools needed:
10mm socket
Flathead
MAKE SURE YOU DISCONNECT THE BATTERY AND REMOVE THE AIRBAG FUSE!!!
1) In the picture below is the side cover on the driver's side. Remove the passenger side one.
2) Remove the clip for the airbag. Your first going to have to pull out the orange part. After that, I used the flathead to disconnect the clip. It really hard to disconnect.
3) Remove the glovebox. To do this, remove the cord holding it on the right side. Then squeeze the sides to get it off the tracks and push it down. It will be hanging down out of your way.
4) Use the flathead to pry down the small flap on the left side inside the glovebox compartment. Then pull it out.
5) Remove the two 10mm bolts.
6) Now pop up the airbag cover with your flathead and just pull it out!
Tools needed:
10mm socket
Flathead
hello,
my airbag cover is already popped up slightly, i hit a pot hole and it popped up, airbag did not deploy.
do i still need to do this to remove the airbag to remove it? i dont see how it comes off.
