Appearance: How-To: Replace a Burnt Out Halo
Old Jul 14, 2008 | 12:29 AM
  #76
csementuh's Avatar
Just wanted to post some info since I finally got around to replacing the LEDs in my burnt out halo...
First of all, Radio Shack only sells one kind of 3mm LED, and it's red, soo that's a no go... The proper 3mm LEDs can be ordered online. But I was in a hurry, and I figured I'd try and go brighter, soo I tried some 5mm's.
I used "high intensity" white 5mm LEDs from Radio Shack. I de-soldered the old 3's off the base and stuck the 5's in there place. The more difficult part came when trying to shove them back into the headlights. You need to cut/grind/file/etc a bit of the slot inside the headlight to make these bigger lights fit. I still had fitment problems, soo I actually bent the LEDs toward each other into a "V" shape instead of the original "T" shape and they cleared the housing and slid into place...
Overall it is a decent improvement. They are a bit brighter, but nothing special. If you do not feel like really having to mess with the halo LED slots to fit the bigger bulbs, then just get the 3mm LEDs. I'm just happy to have them fixed...
Old Aug 14, 2008 | 08:54 PM
  #77
Dystrctred's Avatar
anyone sell this part
the board thing
Old Aug 15, 2008 | 12:04 AM
  #78
JPizzle's Avatar
Pics or BAN!!!!!!
the board thing
I don't believe so... I had to ghetto-rig both of mine since I am now using the pre-wired 3mm led's.... It doesn't look as good, but we will see...
Old Aug 15, 2008 | 12:55 AM
  #79
EmperorJJ1's Avatar
CCFLs is the way to go... check out my gallery for my pics of the swap and a maybe the how to i wrote might someday be approved
Old Aug 15, 2008 | 12:58 AM
  #80
forced_induction's Avatar
Nice job, subscribed
Old Aug 15, 2008 | 11:45 AM
  #81
JPizzle's Avatar
Yea. I really want to see that how to....... Did you PM one of the mods. about it???
Old Aug 16, 2008 | 03:55 AM
  #82
EmperorJJ1's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-swap-ccfl-halos-1st-gen-projectors-125327/
Old Sep 16, 2008 | 04:02 AM
  #83
raikou's Avatar
HOw in the F are your headlights so clear and flawless??? Thats the How to I need....well that and my leds are all burnt out too!! Nice Job
Old Sep 17, 2008 | 02:43 PM
  #84
JPizzle's Avatar
Thanks. Your headlights aren't clear? Is it crap that's on the outside, or on the inside?
Old Jan 31, 2009 | 06:09 PM
  #85
Halfcent's Avatar
I'm old school
Had to give you kudos. I used your info today for a repair and it was very helpful.
Old Jan 31, 2009 | 09:54 PM
  #86
JPizzle's Avatar
Lmao. Well, I'm glad that I helped somebody with this.
Old Feb 1, 2009 | 12:25 AM
  #87
EmperorJJ1's Avatar
fyi i do have a few of the halo leds i could sell
Old Feb 2, 2009 | 01:03 PM
  #88
Halfcent's Avatar
I'm old school
I suggest you make a classified ad thread for yourself and link to it in your signature file. That is very common.
Old Feb 2, 2009 | 06:07 PM
  #89
EmperorJJ1's Avatar
lol ya i will eventually but i wasnt sure if you needed them or not
Old Nov 5, 2009 | 10:12 AM
  #90
iboost's Avatar
Great write up!
Old Nov 5, 2009 | 11:14 AM
  #91
JPizzle's Avatar
Damn dude. Those halos look awesome!!!
Thanks. Joeworkstoohard helped me through the process.
Old Nov 5, 2009 | 11:22 AM
  #92
iboost's Avatar
Thanks man. Oh alright. Thanks to Joeworkstoohard also,
Old Nov 15, 2009 | 02:45 PM
  #93
4dr-RS's Avatar
ok i have a question, both of my halo rings are burnt out on one of my headlights, cant i just take one of the leds from the other headlight and put it into one of the burnt out halo?
Old Nov 15, 2009 | 05:52 PM
  #94
JPizzle's Avatar
You could take out the LED's from the halo that works, and put them in the halo that doesn't, but you would still have 2 halos that don't work...
Old Nov 15, 2009 | 09:00 PM
  #95
iboost's Avatar
yea if you take one of the leds off the good halo, you'll just end up with two iffy halos...
Old Jan 18, 2010 | 09:55 PM
  #96
bruiserinpink's Avatar
sub'd for later use
Old Jan 23, 2010 | 12:42 PM
  #97
4dr-RS's Avatar
o n i have the gen2 halos, the halos dont come out the same way they do on these, how do i get the leds out cuz i really wanna avoid sticking the headlight in the oven
Old Jan 23, 2010 | 06:11 PM
  #98
iboost's Avatar
just like it says on the first page man...
Just flip the light over you'll see where the white/black wires go in through a gromet like thing. Pull the gromets out and you'll be able to see inside the light. Follow the wires inside the head light. You'll see the rubber connectors that hold the little circuit boards with the leds on it. They are easy to get out...not so easy to put back in.
Old Jan 23, 2010 | 06:37 PM
  #99
4dr-RS's Avatar
alright dude thanx
Old Jan 23, 2010 | 09:02 PM
  #100
iboost's Avatar
no problem
