2.0 LSJ Engine: how to-timing chain tensioner
Old Jun 27, 2010 | 12:21 AM
xnigelx's Avatar
i thought they had a problem with the stock one and the new one is a revised version?
Old Jun 27, 2010 | 12:38 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Changed mine at CED today in 10 minutes. The only hard part was getting the new one threaded. The new tensioner is real easy. Don't even need to pull the Valve Cover off.
Screw the old tensioner out (careful, mine fell apart as soon as it came out)... then screw the new one in.
Old Jun 27, 2010 | 10:37 AM
Stiner's Avatar
Mine just came in I'll be doing this tmw
Old Jun 27, 2010 | 03:07 PM
scotch89's Avatar
ya thread the new one is a pain. i had to rest mine like 3 times! also my stock one just fell apart when i did mine lol
Old Jun 30, 2010 | 05:09 PM
corey_osu10's Avatar
just did this. this write up helped tons! and it was a piece of cake. less than 10 minutes. great job.
Old Jul 9, 2010 | 03:29 PM
ddawg23213's Avatar
It has come time for me to do this on my car as well, but I have one quick question. I know you have snap wring pliers listed in the tools but do you actually need them, or do you not need them because the new one is one piece?
Old Jul 9, 2010 | 04:03 PM
You don't need them.
I literally used one tool (two technically) when I pulled mine out. A Ratchet and the my ECOTEC Oil Filter Cap Socket.
Old Jul 9, 2010 | 04:06 PM
Bl4des's Avatar
i did my a week ago and all you need to do it unbolt the old one take it out and put the new one it
Old Jul 9, 2010 | 04:10 PM
scotch89's Avatar
ya the reson i put pliers was if you needed to reset the part. or just buy the snap ring thingy mo bob
Old Jul 13, 2010 | 07:42 PM
crash_ss's Avatar
so just a quick question about this the chain doesnt come off any of the sprockets when u take the tensioner out? so no need to put tension on the chain
Old Jul 13, 2010 | 07:43 PM
  #36
No. Pull the old one out... put the new one in.
Old Jul 13, 2010 | 07:46 PM
  #37
crash_ss's Avatar
alright thanks for the quick reply on this.
Old Jul 13, 2010 | 07:47 PM
  #38
ls1fbody's Avatar
Haz l33t wheelz.
It's oil pressure operated, so when the engine is off, it releases the tension anyways.
Old Jul 13, 2010 | 09:08 PM
  #39
crash_ss's Avatar
so i just swapped the tensioner and took it out for a lil drive to make sure all was good and it threw a P0017 code all of a sudden. what could cause that
Old Jul 13, 2010 | 09:12 PM
  #40
BLAZIN07SS's Avatar
I'm too JDM for you
thats a cam/crank correlation code....
  #41
crash_ss's Avatar
so what did i do wrong?
Old Jul 13, 2010 | 09:19 PM
  #42
BLAZIN07SS's Avatar
I'm too JDM for you
you torqued down the new timing chain tensioner correctly right?
Old Jul 13, 2010 | 09:20 PM
  #43
Furious_Cobaltss's Avatar
does anyone now the part number for they updated tensioner from gm.. called couple days ago and the guy didn't know what i was talking about.. I got a 2005 ss and don't want to get the same one as in the car
Old Jul 13, 2010 | 09:23 PM
  #44
Bl4des's Avatar
it is in the first post
http://www.crateenginedepot.com/stor...P2216C133.aspx
  #45
crash_ss's Avatar
yeah i did torque it. would that cause the issue if it wasnt torqued right
Old Jul 13, 2010 | 09:26 PM
  #46
Bl4des's Avatar
sounds like you could have some how skipped a tooth
Old Jul 13, 2010 | 09:28 PM
  #47
crash_ss's Avatar
DAM IT!!!!!!!!!!!!!!!! all i did was spin the old one out n the new one in like some of the guys on here said that they have done
Old Jul 13, 2010 | 09:29 PM
  #48
Originally Posted by Bl4des
so its en-45027-2.. and if i call the dealer this will be the part number right
  #49
Bl4des's Avatar
that is what i did to and it went fine
how does the car sound and idle
did you clear the code and see if it came back
the part number should be
12608580
it might be cheap online comparied to the dealer
i would just order it online
Old Jul 13, 2010 | 09:33 PM
  #50
crash_ss's Avatar
i cleared the code and it cam back....... and the car sounds about normal so in other word im gna have to take the valve cover off and and check the markings on the cams to the ones on the chain?
