Electrical: How To: Traction Control Switch
Old Mar 6, 2008 | 05:33 PM
originaladrian's Avatar
EDIT 8/30/08 everyone look at post 24 before PMing me or posting.
Do this at your own risk, I am not responsible for u messing up ur car.
Now there are 2 ways to do this, the other way, which involves putting a switch before the ABS fuse, will turn off T/C AND ABS. But i like my brakes
the first thing you want to do is take off this panel
Find the light blue wire going to the underside of the Ebrake and tap it. You can use wire taps or just solder it like i did.
Run that wire to an inline switch
these are my switches
attach an Alligator clip to hook up wire and the other end without the clip to the switch.
Look under your Ebrake, there is a copper strip, Attach the clip to the back of that. (If you can get the E brake out, solder the wire to this strip)
Turn on your car with the switch off and make sure your ebrake works as normal. Now test the switch.
Thats All Folks
Old Apr 2, 2008 | 11:30 PM
Halfcent's Avatar
I'm old school
This is e-brake override. The correct way to do this is simply shift into 1st or "L" depending on which year you have.
Old Apr 3, 2008 | 04:15 PM
wow, totally forgot i made this thread, ya u can put it into L gear. just for convenience.
Last edited by originaladrian; Apr 3, 2008 at 04:15 PM. Reason: Automerged Doublepost
Old Apr 4, 2008 | 05:44 PM
waldo84's Avatar
Why would you want to do this anyway????
Old Apr 4, 2008 | 07:20 PM
when you launch an automatic you dont want traction control on,
you can
.click ur e brake up one
.put your car in low gear
.or do this
Old Apr 4, 2008 | 07:23 PM
waldo84's Avatar
yeah I guess I don't know thats kinda weird for me cause I have the SC ha ha ha
Old Apr 4, 2008 | 07:25 PM
cobaltspeced's Avatar
what he said? what? why? reason?
Old Apr 4, 2008 | 07:27 PM
did u read the thread?
Old Apr 4, 2008 | 08:08 PM
i posted that thread while the other threads were being typed and posted i didnt beat the other threads from posting. my bad. i read it though
Old Jul 20, 2008 | 05:20 PM
mrsilent13's Avatar
i know its only one wire to the ebrake.....but do i need to cut it...and add my switch or just strip it and add my switch? and it looks like the other end coming of the switch just goes to the copper strip...is this correct?
Old Jul 20, 2008 | 05:25 PM
your talking about tht blue wire im holding with the electrical tape rite? thts just tapped and soldered. you can use a plastic wire tap as well.
ya tht copper strip is what is touched by ur ebrake to send the signal that ur ebrake is on.
Old Jul 20, 2008 | 05:44 PM
mrsilent13's Avatar
o ok the blue wire is the signal wire that im going to tap...and then route the red wire to a switch and return it to the cooper strip....correct?
Old Jul 20, 2008 | 05:57 PM
yup, so ur car thinks its completed the circuit. just make sure when ur ebrake is down and the switch off tht ur T/C on.
Old Jul 20, 2008 | 06:14 PM
Red07SSNA's Avatar
Resurrected -- When you pull up your e-brake does your "TC" light up on the dash? When I lift my e-brake the "TC" light does not illuminate. Only when I shift into "L" does the "TC" light up.
Old Jul 20, 2008 | 06:15 PM
ya i just replied in tht other thread. i guess its different with the 2.4 and 2.2s. i guess u would have to find a way to make sure ur ebrake turns ur T/C off... which it most likely does.
Old Jul 20, 2008 | 06:17 PM
Red07SSNA's Avatar
DARN! doesn't turn it off on mine, so much for your tip. Glad you got a "fix"!
Old Jul 20, 2008 | 06:18 PM
not really a fix since the past couple of months i have been starting in L.
Old Jul 20, 2008 | 06:24 PM
Red07SSNA's Avatar
Good choice, but you shouldn't have mentioned that.....now all the manual dudes will be telling you you're an idiot for shifting
Old Jul 20, 2008 | 06:27 PM
lol well... at least WE kno why.
upshift isint going to do a damn thing to harm ur car. Downshifting MIGHT but our trannys are electronic anyway its not tht bad... i have the shift plus so i try and stay away from downshifting as i keep it on stg 2.
Old Jul 20, 2008 | 10:34 PM
mrsilent13's Avatar
well thanks now that im sober.....lol...it makes more sense....i dont know why i was tripping about one wire....thanks.....ill do this as soon as i can get my car running again
Old Jul 20, 2008 | 10:35 PM
lol, its ok. ya once u realize wht ur looking at it makes sense.
Old Jul 20, 2008 | 10:40 PM
mrsilent13's Avatar
yea it makes perfect sense.....
Old Aug 30, 2008 | 09:40 PM
knoxbox's Avatar
i have an 08 ls and standard equipment says all gear traction control, when i put my car in L or I the trac off light doesn't show up... so my question is will this work on an 08?
Old Aug 30, 2008 | 09:43 PM
no clue whatsoever to be honest
i dont use this mod anymore, people have been PMing about it and i have been answering the best i can, i dont want any of u to screw up ur car,
this is a traction control OVERRIDE switch, and putting ur automatic into L is better for it and turns TC off.
go ahead and do this if u want but when in L ur automatic will actually perform better.
Old Aug 31, 2008 | 10:06 AM
Red07SSNA's Avatar
A little off subject -- when I shift into "I" -- like when I know I'm going to pass a slower car (just waiting for a safe opening) I find that my car performs less then when I just leave it in "D" and pass. It seems to accelerate slower with the shifter in "I" starting between 45 MPH to 65MPH. If I leave it in "D" the engine revs easier when starting to pass from 45MPH to 65MPH. Anybody else with the auto notice this?
