2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
Old Jul 29, 2010 | 09:30 AM
  #351
MP81's Avatar
Which LSJ MAP? The 1-bar from the Supercharger? It plugged right into my injector harness...which was weird, cause it was older...
Old Jul 29, 2010 | 11:19 AM
  #352
Axelthered05's Avatar
No the one for the Intake Manifold
Old Jul 29, 2010 | 11:23 AM
  #353
MP81's Avatar
Well - that's in my manifold...that's what quite a few people did.
The 2-bar requires some rewiring.
Old Jul 29, 2010 | 11:36 AM
  #354
does anybody know how or have instructions on doing that?
Old Jul 29, 2010 | 11:40 AM
  #355
MP81's Avatar
I know Gene did it, but I don't remember how or where he got the info - he may have had a pinout of it.
I know you need to move some wires from the MAF to the MAP.
Old Jul 29, 2010 | 11:45 AM
  #356
Yeah the AIT Sensor wires from the MAF Conector need to be Wired to the LSJ MAP because it has an AIT Sensor in it
I think Beck did it with his 2.4 let me search through his thred
Found it
Originally Posted by Beck
STEP NINE: Wiring the Map Sensor
SEE THE DIAGRAM BELOW: Basically you'll need to cut two wires from the stock MAP sensor (which is located on the fuel injector harness) and splice them into the new map sensor pig tail. Next take two wires from the MAF (see diagram for which to cut) and splice them into the appropriate wires on the new MAP pigtail.
Old Jul 29, 2010 | 12:46 PM
  #357
MP81's Avatar
I remember seeing it, maybe that was where.
Old Oct 8, 2010 | 06:34 PM
  #358
hay hunter im in the process of puting a supercharger on my balt now, but im having problems with the stock 2.2 tensioner, its pushing up against the tensioner from the LSJ and jaming the belt, I was told I could fix this if i replaced 2.2 tensioner with the LSJ idler can you confirm this?
Old Oct 8, 2010 | 06:45 PM
  #359
ecot3c inside's Avatar
Originally Posted by HunterKiller89
wow bro, you party hard! look at the size of that plastic cup!
Old Oct 8, 2010 | 08:47 PM
  #360
HunterKiller89's Avatar
yep. The tensioner on the NA ecotecs is replaced by an idler on the LSJ, and it uses a different sized pulley. Grab the LSJ idler and you'll be all set
on an unrelated note, i found my camera that i lost 3/4 through install all those years ago last weekend. Unfortunately, i dont have the balt, and the pics that are still on there are already uploaded.
Old Oct 8, 2010 | 09:51 PM
  #361
ok thanks Hunter, I hope to have this beast up and runing soon
Old Oct 12, 2010 | 12:18 PM
  #362
Novajoe's Avatar
I'm a little confused... I read most of the thread(not all 15 pages though...), but didn't actually see how you tuned the car. Did you have someone with access to dealer tech go in and make some changes? Or did you go with an aftermarket gizmo to adjust your a/f, timing, and TB position settings?
Old Oct 12, 2010 | 01:02 PM
  #363
Vince at trifecta tuned it.
There are several tuning options, depending on year and model, or you can get the AEM FIC (have to get the one that supports frequency based MAFs), but that route is more work and more expensive.
Old Oct 12, 2010 | 02:40 PM
  #364
Novajoe's Avatar
I have an 06 ls auto. It's been awhile since I looked into this stuff. Have you had any issues with your timing? Dunno if you've done any datalogging, but I'd be interested to see how everything's running with your current setup since your car's pretty much the same thing as mine. However everything on my car is stock. If I were going to do this, I'd probably end up grabbing an LSJ header/exhaust as well(or an aftermarket).
A few other questions I have:
Are you still running the stock fuel pump? Is the pressure still good even with the bigger injectors?
Which tuning option did you go with? The AEM? Did that take care of all of your TB issues?
Old Oct 12, 2010 | 07:59 PM
  #365
i went with Trifecta. My TB issues were resolved once i re-pinned the TB, which i then included in the how to by editing. I think i ran around 18* timing. It was a more conservative tune, and the higher CR keeps you from running LSJ timing.
Stock fuel pump is plenty until near 450-500whp.
Old Oct 19, 2010 | 08:57 PM
  #366
I got the supercharger on the car and have it runing, and I was wondering if you know how much vacume at idle I shood be seeing. curently im geting -8/-10 psi on the manifold
Old Oct 19, 2010 | 11:27 PM
  #367
is that -8psi as in 7PSIa? or are you saying 8 in Hg? Very different. If you mean in-Hg, then it doesnt seem like enough. I'd check for leaks. If im remembering correctly, i saw 18in HG
Old Oct 20, 2010 | 06:58 AM
  #368
well my gage only reads PSI so I meen -8 to -10 PSI from atmospheric pressure so in PSIa it would be 6.7/4.7 and in inHG thats -16.29/-20.36
Old Oct 20, 2010 | 11:08 AM
  #369
what gauge are you using? Almost every gauge ive seen uses in-hg for vacuum and psi for boost. The only gauge i know of that reads PSIa is on the AEM FIC.
If that's correct though, then that seems like a normal vacuum range
Old Oct 20, 2010 | 11:28 AM
  #370
im using glowshift's red digital boost/vaccume gauge it reads -15 PSI ~ 44 PSI no inHG
Old Oct 20, 2010 | 11:31 AM
  #371
umrdyldo's Avatar
Their site says
52mm Gauge With a Range from -14.5 inHG to 45 PSI
Old Oct 20, 2010 | 11:59 AM
  #372
and the instruction under their tech articals say "-15 PSI ~ 44 PSI" I quite seriously copy and pasted that lol
And i know its acurate cause my OBD link CI confirms with the MAP sensor that the gauge is displaying the proper PSI equivalent to the inHG data from the MAP
http://www.glowshift.com/instruction...cuum-Gauge.pdf
Old Oct 25, 2010 | 04:18 PM
  #373
just wondering, why are their 2 wires for the throttle position sensor signal, 2 for the 5 volt reference, and 2 for the Sensor Low Reference? do they do diferent things or what?
Old Oct 25, 2010 | 04:27 PM
  #374
Glowbalt's Avatar
thanks! I used this thread for my build. Came out successful!
Old Oct 26, 2010 | 03:37 AM
  #375
no, which is why the later model throttle bodies only have 6 wires. (each throttle body has two throttle position sensors, so i imagine they were originally powered and grounded independently, and then were powered and grounded with common wires)
Glad everything worked out! Enjoy it as much as i did!
