2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
Old Jun 28, 2010 | 01:07 AM
  #326
wbrevels's Avatar
thanks for all the help with my build man, everythings running great with a lot of help from you.
Old Jun 28, 2010 | 11:38 PM
  #327
HunterKiller89's Avatar
always glad to help!
Old Jun 29, 2010 | 02:05 AM
  #328
Pedobear's Avatar
i will be using this
Old Jul 6, 2010 | 05:50 PM
  #329
Axelthered05's Avatar
Question
I see your using the AEM F/IC 6 HunterKiller89. just wondering how you avoid the code for (MAF) seeing as the F/IC 6 cant calibrate or clamp a frequency based MAF sensor
Also have you had any water issues haveing the F/IC on the fuse box, is that a safe spot? Ive taken one apart before and i know they are veary much NOT waterproof
Old Jul 6, 2010 | 10:05 PM
  #330
its a sealed unit and seems pretty water tight, at least splash proof. Never ran into an issue with it, however i did ditch it for a trifecta tune. I bought the F/IC before Trifecta started supporting the L61.
Old Jul 6, 2010 | 10:15 PM
  #331
Pedobear's Avatar
oh im so close to finishing i can taste it
Old Jul 7, 2010 | 08:44 AM
  #332
I was going to use an aem F/IC8 for my build cause that version suports the frequency MAF sensor and i have a lot of experience with the F/IC6. But the F/IC8 is almost $600 that along with the wideband and other equipment needed to tune it my self brings it to around 850 Trifecta doesent have the pricing on their wabsite for the Cobalt with that said compared to 850 between the F/IC8 and the gauges to do it my self is the custom tune worth it? they dont give an exact price on their website How much did it cost for yours?
Old Jul 7, 2010 | 09:17 AM
  #333
it was below $300 for me...i think about $300 for you. my tune kicked ass! i definitely recommend it
Old Jul 7, 2010 | 09:20 AM
  #334
Thanks for the info ill most likley do that insted saves me the trouble of doing it my self and a few hundred
Old Jul 10, 2010 | 09:44 AM
  #335
Another question for you HunterKiller89, What all did you include when you were listing Vehicle Modifications when ordering your trifecta tune, just wondering what detals I would need to include to get the tune right
Old Jul 10, 2010 | 12:29 PM
  #336
wbrevels's Avatar
tell him every engine mod you have done, one he sends you a basic tune you can more then likely run the car, but i wouldnt go crazy with it because the ratios will stil need tweaked. run a data log and send him the file so he can see how the car is running, then he should send you back another tune file to load.
Old Jul 10, 2010 | 09:13 PM
  #337
like the above, every performance mod and supporting mod you have. suspension stuff obviously doesnt matter, but mention exhaust stuff, cams, injectors, what TB you're gonna use, things like a transmission cooler, etc.
Old Jul 10, 2010 | 10:01 PM
  #338
Pedobear's Avatar
good to know
Old Jul 27, 2010 | 07:50 AM
  #339
Were you able to use the stock brake hose for the manifold to the mastercylinder or did you have to buy the one for the LSJ?
Old Jul 27, 2010 | 08:07 AM
  #340
the stock one just baarely fits. its gotta be held tight to reach
Old Jul 27, 2010 | 08:24 AM
  #341
ei3dag3's Avatar
man i haven't read this is in so many years.
it brings back good memories
thanks for this how to, it def helped me out.
Old Jul 27, 2010 | 08:30 AM
  #342
MP81's Avatar
Yep - I'd suggest just getting an LSJ one.
Old Jul 27, 2010 | 09:11 AM
  #343
glad it helped. I just wish it would let me edit the older posts so i can finish it.
Old Jul 27, 2010 | 09:16 AM
  #344
MP81's Avatar
Talk to a mod, and have them edit it for you.
Old Jul 27, 2010 | 10:47 AM
  #345
Pedobear's Avatar
im going to use the LSJ one make my life easier but i have a problem, i need to tell if the belt i bought is stage two or not i bought it off a member here not labeled or anything and i cant remember who i bought it from.
Old Jul 27, 2010 | 11:15 AM
  #346
MP81's Avatar
Stage 2 Belt is 1,767 mm in length.
Old Jul 27, 2010 | 11:25 AM
  #347
Pedobear's Avatar
cool. ill take some string and line it up in one of the ribs and then measure the string
Old Jul 27, 2010 | 11:37 AM
  #348
MP81's Avatar
Good idea!
  #349
Pedobear's Avatar
Do you know the length of the stock lsj belt so I can see how accurately I need to measure
Old Jul 29, 2010 | 09:04 AM
  #350
Hay HunterKiller89 whats the wireing like for the LSJ MAP sensor compared to the Map Sensor for the L61 Can I just rewire the plug or does it use a diferent plug? and should I rewire the AIT sensor to the one built in with the LSJ MAP sensor?
