2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
Old May 9, 2009 | 03:44 AM
  #251
JBomm's Avatar
so the car is running with 265bhp with stock internals?
Old May 11, 2009 | 01:03 AM
  #252
rockstar014's Avatar
ok wat u gotta do with the harness is the same u need to do with the 2.4?
Old May 24, 2009 | 09:43 PM
  #253
Cobaltsky05's Avatar
is that stock pulley? what injectors did you initially use or are using... I am worried about my tune, my guy told me lsj stock injectors tend to come up short for eaton swaps on the 2.2
Thanks alot I have used this thread many times for assistance like with rewiring the SS TB.
Old May 24, 2009 | 11:18 PM
  #254
BULLETSSMOKE's Avatar
ive been following this thread since the beginning hunter. ill start my own once you complete steps 8+ with pictures lol. going to start collecting parts now and i may need your phone number. quick question: what is the easiest/cheapest route for having a tune already when the supercharger is installed. i really dont want to deal with HPT or dynos or any of that other crap. i would love to have the ECU with a starter tune for boost in my hand as soon as i install the kit for minimal downtime. this is my DD and i need it sometimes lol
Old May 25, 2009 | 08:52 PM
  #255
MP81's Avatar
So, my '07 LT should have an 8-Pin TB connector?
Old May 25, 2009 | 09:35 PM
  #256
Jn2's Avatar
Jn2
U need to be using 42's
Old May 25, 2009 | 10:46 PM
  #257
you say 42's someone else told me 60's I don't know what's right... I doubt the ss ones are at full cycle stock no company does that let alone gm... I have no major upgrades and don't plan on upgrading pulleys for awhile or anything else for that matter. I was told the stock lsj one's should be just fine as long as I don't want to rev past 6500... Sounds like no one knows.... I want to hear from someone who has the eaton installed on their 2.2 with no upgrades (cai, exhaust, header etc...)
Old May 26, 2009 | 12:52 AM
  #258
HunterKiller89's Avatar
42lbers are fine for this application. stock LSJ injectors may be a bit on the small side. I would stick to 42lbs. If you EVER think you even MIGHT upgrade lower than a 2.9", get the 60lb injectors from the start. It will save you a LOT of money doing this. im not sure if the 8pin-6pin changeover for TBs was in '07 or in '08, so i cant answer that question for certain.
As far as a starter tune, if you arent going to be doing your own tunes, then trifecta can help you there. they have a base tune that they send out to you, and then once the car is running, you will fine tune it specific to your car.
yes, its completely stock internals (for now )
sorry i missed the question rockstar, but yea, same thing needs to be done with the 2.4 harness as with the 2.2 harness. The colors of the wires will be different though, but beck hasthe wiring diagram (with colors) for the 2.4 in his how to
Old May 26, 2009 | 01:02 AM
  #259
MP81's Avatar
****, just went out and checked. 2007 has a 6-Pin TB connection...
...I'm not sure how that'll work...
Old May 26, 2009 | 01:53 AM
  #260
IonNinja's Avatar
go here and do your own calculations...
http://www.gtsparkplugs.com/InjectorSizeCalc.html
Old May 26, 2009 | 02:14 AM
  #261
elecblue06's Avatar
keep in mind ecotec's fuel pressure is at like 58 psi
Old May 26, 2009 | 11:54 AM
  #262
THANKS!!!! that was a huge help.
Old May 26, 2009 | 12:57 PM
  #263
6 pin has one ground reference wire, and one 5v reference wire. the 8 pin has 2 ground wires and 2 5v reference wires. You can split the wires to make 2 additional wires to connect to the 2 additional pins on a LSJ TB. you will need an 8 pin connector though...and thats a pain to get
Old May 26, 2009 | 02:47 PM
  #264
where did you get your map sensor connector from? you did end up using an SS map sensor right? I have been trying to track one down and the only one my local dealer can find is the only one available right now and they want 96.00 for it... :-S insane! so with that said this is the only thing I am waiting on now thanks again for your help.
Old May 26, 2009 | 03:29 PM
  #265
MP81's Avatar
Yeah - it's like $80 new. I really don't wanna spend that much...
Old May 26, 2009 | 03:36 PM
  #266
yeah so hopefully someone knows where to get one for cheaper... the map sensor has to be used in other cars that aren't SS or redline and if that is the case we ought to be able to get one from the junk yard for free.
Old May 26, 2009 | 04:16 PM
  #267
nope. i used the 1 bar in the Ss/sc, not the 2.5 bar. That one is a direct plug and play to your stock connector.
Old May 26, 2009 | 04:21 PM
  #268
where did you locate it? the intake manifold? if so how did you seal and secure it?
Old May 27, 2009 | 06:47 PM
  #269
so anyone readin this who has finished this swap?? I need to know what alternator, crank, and ac compressor pulleys you ran cause right now I'm done just cant get the belt on cause the ribs are different. no one has said anything about this that I could find please help!!!!!
Old May 27, 2009 | 10:08 PM
  #270
RobHole's Avatar
FYI: To add to this parts list, any 2.2L WITHOUT AC will need to buy an AC Condenser to just SIT there and spin or if there is an a/c delete kit of some sorts you can buy for it to sit there... that would work as well.
just finished supercharging however I need to fix some of my setup since car isn't running properly (long story, I have 3 things I need to check)... You need to cut one of the ribs off the belt for it to fit since our pulleys only use 4 ribs and the s/c's have 5 ribs.
Old May 27, 2009 | 10:10 PM
  #271
my car has AC and I just aquired an SS ac compressor with pulley, and alternator with pulley... now I just need a crank pulley... did you get your car finished?
Old May 27, 2009 | 11:07 PM
  #272
RobHole's Avatar
Almost... lol... supercharger install is COMPLETE... I just need to fix my install though because of some minor issues which is preventing me from properly driving... I need to do some minor rewiring & move where I had the sensors positioned & fix my vacuum/boost line.... after that, hopefully, all will be good!
Old May 27, 2009 | 11:11 PM
  #273
rock on definately got to get some footage up soon then! I see jbp sells an aftermarket crank pulley for a reasonable price so I'm just going to buy that. Hopefully next week I will get to start it only been 6 months waiting...
Old May 27, 2009 | 11:15 PM
  #274
RobHole's Avatar
you may want to think twice about jbp.... that's were Rod's car is at & I'm sure you are aware of ALL the problems!
Old May 27, 2009 | 11:27 PM
  #275
no I'm not what happened?
