2.0 LSJ Engine: Injen intake installed (2.0 SS)
Old May 11, 2006 | 11:13 PM
CobaltSS/SC's Avatar
does anyone have any sound or video clips of the injen air intake intalled
Old May 11, 2006 | 11:22 PM
WarlordSunTzu's Avatar
yeah right here http://videos.streetfire.net/player....B-2BDAFF7507A7 hope this helps
Old Sep 24, 2006 | 01:25 PM
06cobaltls's Avatar
nice how to, they are simple to install but it never hurts to have a picture just in case
Old Mar 9, 2007 | 09:12 PM
What is the reasons for the cel?
Old Mar 11, 2007 | 07:16 PM
saunders1986's Avatar
well i cleaned mine, and u should of seen what came out............ on another note, y intake sits awesome, my filer even sits about 1-2 inches from the bumper, and comes no where close to the "grounding screw"
Old Apr 9, 2007 | 11:49 PM
sealy's Avatar
before installing shouldn't you disconnect the neg. battery cable. then reconnect it afterwards?
I just looked at the stock intake now...and that damn screw is rubbing and making a notch in the stock rubber pipe...anybody else notice that?
do you think there is a way to file that thing down?
Old Apr 15, 2007 | 09:24 PM
splitintlss's Avatar
my injen is rubbing where it passes through the engine pay down into the bumper area.. on that metal hole.. anyone have this problem? how worried should i be i can see its getting scuffed up
Old Apr 15, 2007 | 09:36 PM
LScoupeTUNER's Avatar
Slick write up
Old Apr 16, 2007 | 01:27 PM
Rusty's Avatar
Originally Posted by LTcoupeTUNER
Slick write up
thanks. i would have had better pictures if the weather didn't suck.
Old Apr 16, 2007 | 01:56 PM
betterthanbad's Avatar
Search for a post on "rd fabs intake". It's a newly designed intake but look at the plastic looking piece they've put around that hole. I think something like that will do the trick!!!! You have to scroll down to the bottom of page 1 to see it!
Last edited by betterthanbad; Apr 16, 2007 at 02:01 PM. Reason: location of the pic
Old Apr 17, 2007 | 01:43 AM
  #36
sealy's Avatar
yep, i've seen pics of people that let it rub through the intake tube...get it realigned or surrounded by rubber.
Old Apr 17, 2007 | 07:01 PM
  #37
sealy's Avatar
So I just installed my injen today... the only problem was that the anti-vib bold (the rubber thing) had rubber stuffed into it where the screw from the car would thread into. i had to drill some of it out and it still didn't go on all the way. I got it on far enough where it wouldn't move much at all and tightened everything. the filter was right up against the front fender, but not pushing on it at all. The top pipe was also pretty close to the hood although i made it fit pretty well. I also took some small hose and boardered all the metal edges in the engine.
overall, the scream made all my worries go away. oh yeah, no CEL yet. 20 miles into it.
Old May 13, 2007 | 02:50 PM
  #38
sstyless18's Avatar
is anyone else having any trouble with the intake being rubbed by the hood bracket?? mine was installed friday and already has a nice gouge in it from the hood bracket i dremeled it down a little bit so i hope that fixes it. is there something i did wrong on install? the gouge is right at the bottom left corner of the injen badge and it looks nasty
Old May 13, 2007 | 11:48 PM
  #39
pinoypapi198369's Avatar
awesome, awesome, awesome, many thanks. This should definitely come in handy when i get my injen intake with the week. I just bought a brand new 150 piece tool set for my cobalt
Old May 18, 2007 | 07:45 PM
  #40
JKennedy1612's Avatar
Great write up!
Who's a good vendor to buy the Injen CAI from?
Last edited by JKennedy1612; May 18, 2007 at 07:45 PM. Reason: Automerged Doublepost
Old May 18, 2007 | 07:47 PM
  #41
KillerBee's Avatar
Originally Posted by jkennedy1612
Great write up!
If you go to the vendor section on here you may be able to find a group buy on them aint sure though i bought mine from nopi.com but i got rapped :LOL:
Old May 18, 2007 | 07:58 PM
  #42
JUICED_SS's Avatar
Nice. Tagging this for future reference...
Old May 18, 2007 | 08:05 PM
  #43
How do I look for group buys?
Old May 18, 2007 | 08:27 PM
  #44
KillerBee's Avatar
Here is a link to all the the vendors there is 2 pages all the way to the right is the vendor you can click on them and pm them or look to your left and see what they posted as far as deals some are cold ait intakes and some are other parts just scroll through those pages and see if you can find what ever one your looking for here is the link ask me anything if you need to i can help you as much as i can trying to find one for you
https://www.cobaltss.net/forums/sear...archid=1583283
Old May 21, 2007 | 10:55 PM
  #45
cobaltblue's Avatar
Originally Posted by Rusty
Thanks to TurboTechRacing, my Injen Cold Air Intake arrived in the mail this saturday morning and I immediately went to install it. I know that many of you have already installed the intake and know how to do it, but I wanted to do a write up for those who havn't and could use some advice.
Tools Needed:
7mm socket
8mm socket
10mm socket
3/4 socket
socket wrench
flat head screwdriver
philips head screwdriver
pliers
side cutters
jack
First thing you need to do is jack up the car on the driver's side. I used the factory jack because I couldn't find my hydraulic jack. Before the tire lifts off the ground, break the lug nuts loose with the 3/4 socket. Then Jack up the car enough so the wheel is just off the ground and can move freely. Remove the lugnuts and remove the tire from the driver's side of the vehicle. Next thing you will want to do is remove the fender liner. Just a warning....the fender liner can be a pain in the but to get back in place properly! Anyway, the fender liner has I think 8 bolts that you will use the 7mm socket to remove as well as 4 or 5 plastic clips. To remove the clips, I used a pair of side cutters to lift the top piece out and then remove the entire clip from the fender liner. If you try to pull the fender liner off and it resists, chances are you missed a bolt or a clip. Be careful not to tear the fender liner (I did ). Place the fender liner aside and open the hood.
From under the hood, with the flat head screwdriver or the 8mm socket, loosen the hose clamp holding the part of the intake to the throttle body. Then loosen the hose clamp towards the fender so you can detach the first part of the intake tube. To remove the rubber hose, use a pair of pliers to squeeze the clamp together and move it away from the intake tube. Once the rubber hose is removed, the first part of the intake should pull away freely.
Back under the wheel well. Unplug the air flow sensor. Now there are three bolts holding the rest of the intake to the fender well. Use your 10mm socket to remove these three bolts. One bolt is easily visible from the wheel well. The other two bolts are on the other side of the air box assembly and you will need to crawl under the car to see them. Once these bolts are removed, the assembly should come out freely.
At this point, you should have the entire intake assembly removed from the car. Now, with a philips head screwdriver, remove the air sensor (carefully!) from the stock air box. With the supplied screws from Injen, put the air sensor in the new intake tube. Now take the coupler with the hose clamps and attach is to the throttle body under the hood. Do not tighten the hose clamps, as you will need to move it around to get it all to fit correctly.
Now, take the anti-vibration screw (the rubber piece with the washer and nut on it) and screw it on behind the fender (location should be shown in instructions). Now, take the intake tube and from in the wheel well, slide it through the opening in the fender to the engine bay. This will be a tight squeeze, so be carefull not to scratch it. I put a piece of rubber hose over the grounding screw by the headlight that everybody says scratches the intake....and it does, so be careful. Once you have it in there, take the nut/washer from the anti-vibration screw and lightly tighten it over the piece of the intake that it attaches to.
Under the hood put the intake tube into the coupler and lightly tighten the hose clamp. Now, attach the air filter to the bottom of the intake tube and tigthen the hose clamp well. Once you are comfortable with how everything fits, tighten all hose clamps and then don't forget to plug in the air sensor! Now you are done with the install and just have to put the fender liner back in and the wheel back on. Let down the car and you're ready to go!
I took a whole bunch of pictures of the install process, but I'm having some trouble getting them off of my camera (I lost the USB cable). Hopefully I will get them on here and will post up as soon as I get em. Hope this write up helped some people out.
Hey Rusty nice write up. One question, I thought you needed to remove the front bumper for this. I own a 2007 SS/SC, Is it the same installation procedure???
Old May 22, 2007 | 03:41 PM
  #46
Rusty's Avatar
don't need to remove the front bumper. you CAN to get more room I guess, but I just took out the wheel and fender liner to gain access. 2007 should be the same.
Old May 22, 2007 | 10:33 PM
  #47
cobalt blue's Avatar
Excellent Rusty thanks so much should be a piece of cake.
Old May 23, 2007 | 09:29 PM
  #48
Excuse my noobness...but what does "CEL" mean? Also, where can I buy the injen shield?
Old May 28, 2007 | 04:24 PM
  #49
CEL stands for check engine light. As for the "injen shield" If im thinking the same thing I presume youre referring to a filter cover, you can purchase one through summit racing equipment or any other places that sell the Injen CAI system.
Old May 30, 2007 | 08:14 PM
  #50
i just posted my fly by video with injen cai installed, its ok. Kinda cool
http://www.youtube.com/watch?v=NAkqbv-W7MA
