2.0 LSJ Engine: Install pics mechanical boost gauge , to go with ExHondaMans write up
Old 03-24-2007, 01:57 PM
stvn's Avatar
Originally Posted by SilverSS/SC
This is what I was talking about .....
....just make sure you either solder and use shrink tube , or use a butt connector .
im sorry im asking to many questions about it, but how do you make it like that? do you get the main power wire and strip it and just twist the 3 power wires on? i dont know. help me please!!
Old 03-24-2007, 03:33 PM
SilverSS/SC's Avatar
twist them on or crimp them with a butt connector .
Old 03-24-2007, 03:59 PM
stvn's Avatar
Thumbs up
ok i get it. thanks alot.
Old 03-27-2007, 08:32 AM
stvn's Avatar
if i do wire it like that is there a chance i will blow a fuse, or accidently short something out?
Old 07-29-2007, 05:46 PM
Boosted07SSSC's Avatar
how much boost can you run on stock fuel system? and has anyone installed a mbc on their car?
Old 07-29-2007, 10:27 PM
not sure , I havent seen anyone reach the limits of the stock pump as of yet . There is a turbo car on this site that dynoed at 401 wp @ 21 psi using the stock pump without issue . I believe GM rates the stock pump to 475hp .
Old 07-29-2007, 10:40 PM
so can you just put a mbc on this, i know that is the first thing i did on my vr4
Old 07-13-2008, 08:36 PM
ViSiONZ's Avatar
Subscribed for when I get my mechanical gauge.
Old 07-18-2008, 04:56 PM
Dead Zen's Avatar
x2..
Old 09-21-2008, 07:01 PM
ACESSbalt's Avatar
click
Old 09-21-2008, 07:31 PM
  #36
1bdstlLSJ's Avatar
You have a Supercharged car, hahaha....MBC is used for turbo cars.
Old 06-29-2009, 05:40 PM
  #37
07touringcoupe's Avatar
hes right mbc= Manual boost controller
Old 07-09-2009, 05:45 PM
  #38
Joe Schulte's Avatar
Thanks for the how-to, I'll contribute my pics-
Factory Autometer was dead, solid 6psi all day everyday-
After owning multiple Autometer's and SW Max Perf series I decided to give GlowShift a try despite their somewhat cheap appearance. I browsed reviews, became confident and ordered up the 7-color tinted series-
First order of business was ripping off the factory retainer that only the factory gauge seems to line up with, this went easy and looks flawless-
Only wiring I had to do was a constant power for the GS, I used a mini add-a-circuit as I enjoy the protection and not bastardizing any of my factory wiring, I found one and tapped in-
I snipped the factory plug from the Autometer to use it's ignition and ground, wired it to GS accordingly, this is with the line ran too ready to go (notice I loomed it too)-
The loom allowed me to hide it under factory wiring, I then tapped it into the correct source and proceeded to zip-tie that out of view-
Blue showed up the best for the pictures, so eh, it's a 7-color deal so at night we'll be seeing red-
Further away-
I'm satisfied, enjoy!
Old 08-16-2009, 12:13 PM
  #39
Collin's SS's Avatar
i just replaced mine yesterday, works great!!
Old 10-16-2009, 08:26 AM
  #40
Fast Black SS's Avatar
So is it just hot and ground then the boost line?
Old 10-18-2009, 12:15 PM
  #41
yup, easy install
Old 11-07-2009, 10:49 AM
  #42
cobaltguy889's Avatar
sorry to bring back the dead, but this thread was alot of help!
Old 01-11-2010, 10:41 AM
  #43
terry.davis1's Avatar
BACK FROM THE DEAD! AGAIN!
Anybody know what gauge the OP used? Autometer Sport Comp II???
My stocker has been out for months now, and I need to get this changed once it warms up.
Old 07-01-2010, 03:15 PM
  #44
jbenso4's Avatar
nice write up
Old 08-09-2010, 07:16 AM
  #45
DEZZIE41's Avatar
what size hose how much do u need and what size t fitting?
Old 11-28-2010, 02:56 PM
  #46
laserblue07's Avatar
This how-to was very useful. I must warn people not to buy Auto Meter C2 gauges as they are MUCH too bright at night.
Old 12-06-2010, 11:32 AM
  #47
Red 2.0's Avatar
Nice write up Same way i did it. Heres my result
Old 12-18-2010, 03:41 PM
  #48
rekameohs_nire's Avatar
so im just about to install my boost gauge and i wanted to know what wire to tap into for the power so it still dims like stock and also which is the ground
Old 12-30-2010, 01:11 PM
  #49
OiangeSS's Avatar
this thread is a BIG help the only thing i noticed was i didnt have to cut into the sound deafining rubber to get my vacuum hose through the fire wall i just went straight through the gromet behind the clutch pedal i did however have to cut a small hole in the side faceing the engine bay to get the hose through then i used a wire coat hanger and looped one side to get the hose and pull it up to my hand
Old 10-22-2011, 09:56 PM
  #50
Dirtdevil77571's Avatar
Quick Question
What is the easiest way to get the vacuum hose through the fire wall?? Im having trouble with this
Quick Reply: 2.0 LSJ Engine: Install pics mechanical boost gauge , to go with ExHondaMans write up
