2.0 LSJ Engine: Install Powell F35 Stage2 Mounts
Old 03-04-2010, 05:58 PM
bmaynard06's Avatar
Holy big picture Batman! haha
Nice writeup! "Tested" them out yet?
Old 03-04-2010, 05:59 PM
EXsoccer1921's Avatar
looks like they made some changes. but the ones in the bag are for the front yes.
Old 03-04-2010, 10:36 PM
Dainslaif's Avatar
Originally Posted by MaxVQ35DE
Ok so i ordered Hypersingle and Stage 2 rotated mounts
One of the mounts has spacers/bushings zip tied to them
There were two others in a plastic ziploc bag. Are these for the front trans mount?
woa, sorry for the large cameraphone pic
Yes, if you got 2 mounts there will be 4 spacers total. 2 go on the front mount, 2 go on the rear (one on either side of the mount).
Old 03-09-2010, 10:47 PM
Haz l33t wheelz.
ls1fbody's Avatar
All my spacers were the same thickness, it looks like he has two thinner ones in addition to the normal ones. Took a pit of prybar leverage to get them in, but a tight fit is better i think overall. Too loose = no bueno.
Install done. Good write up
Old 03-10-2010, 12:52 AM
yeah mine were all the same thickness too. i'll email josh and see whats up
Old 03-10-2010, 01:41 AM
slobalt08's Avatar
How are the vibs with these? I was looking to get a pair my self. My tranny slams when I WOT shift to second so I hope these will help stop that.
Old 03-10-2010, 01:57 AM
they will stop it. vibs are not bad if everything is installed/torqued correctly.
Old 03-21-2010, 02:32 PM
advise's Avatar
is it necessary to loosen the rear mount
Old 03-21-2010, 04:15 PM
really you'll want to have all four engine/trans mounts loosened for maximum engine play while installing them
Old 03-21-2010, 04:27 PM
jonnymerk's Avatar
Good write up. Another option to driving it then re tourquing is that you can loosen the upper mounts a little and rock the engine back and forth a we bit then tighten them all back down.
Old 06-24-2010, 03:43 PM
  #36
07 BaLt SS's Avatar
im installing my stage 2s now and im having problems with the rear mount..the brackets in place and tightened down and so is the mount i just cant get them to line up right any suggestions?
Old 06-24-2010, 03:59 PM
  #37
no idea honestly. mine went in pretty easy
Old 06-24-2010, 04:17 PM
  #38
northvibe's Avatar
did you loosen the side passenger mount bolts? loosen those up by 1 turn each and then it should be easy to install the mounts.
Old 06-24-2010, 04:36 PM
  #39
Traviper's Avatar
sub'd should be getting my stage 2 sometime in the next week
Old 07-14-2010, 06:31 PM
  #40
scotch89's Avatar
ill be doing this tonight
Old 07-16-2010, 06:53 PM
  #41
scotch89's Avatar
im getting wheel hop still, but i had a few problems. 1st of i ended up cross threading the tranny hole on the very bottom back mount. where theres 3 bolts. so im going to try to place a nut on the bolt to tighten it down. also i didnt read the hole write up. i didnt do that light drive after. so hopefully this well work out tonight! this is my 3rd dam day working on this......about hour and half each night cause of work.
Old 08-08-2010, 02:08 PM
  #42
SprChrg4Life's Avatar
damn, sorry to hear that bud!! essentially, you wanna loosen up the passenger side mount as every1 suggests. then take both stock tranny mounts out, put the new ones in without the center bolts that go through the mounts... then, rock the engine back and forth until you get the bolts to go in. i recommend getting the rear tranny mount center bolt in first. it's easier to lower and raise the engine to align the front mount's center bolt.
as for cross threading the mount... i nearly did that too, but that was when i put the centering bolt in FIRST, THEN tried getting the mount to bolt in flush to the chassis point by trying to get the bolts in and tighten them down, essentially pulling the engine and mount into place with the bolts! this is a no no!
this order --> undo the front and rear center bolts, loosen up passenger mount, align the rear tranny mount and put center bolt in (do not tighten yet) then get front in, then tighten rear tranny mount, then front tranny mount, THEN upper mount. torque to 72 ft-lbs and call it a day
Old 08-08-2010, 02:16 PM
  #43
ItalianJoe1's Avatar
Did these before, not that bad at all. Did a stage 1 setup yesterday in no time at all.
Old 08-25-2010, 10:00 PM
  #44
BlueSS/SC's Avatar
Got mine off John on saturday Excited to put them in!
Old 08-29-2010, 02:26 PM
  #45
BlueSS/SC's Avatar
Great write up!! Just installed mine,vibes are VERY minimal.... amazing product
Old 01-13-2011, 09:11 PM
  #46
Turbalt2010's Avatar
sub'd just got my stage 2 mounts, will be putting these in very soon.
Old 01-29-2011, 08:08 PM
  #47
importkiller's Avatar
Great write up. I just did this today but it took 4 hours. Getting the spacers in was a PITA, the front was hard but the rear was impossible without using a prybar and muscle to get the second one in. My car is now free of wheel hop.
Old 01-29-2011, 08:21 PM
  #48
RooTBeeR's Avatar
lol then you did something wrong it goes easy. raise/lower the jack under the oil pan to line it up and itll slide right togather. and have the 3 engine mount bolts already loosened
Old 01-29-2011, 08:24 PM
  #49
All the bolts went in fine, the spacers were just a very tight fit, all holes lined up good. No complaints, it was just a tight fit.
Old 01-29-2011, 08:51 PM
  #50
RooTBeeR's Avatar
hmm, odd...shouldnt be that snug.
are these the brand new ottp mounts they made on their own?
Quick Reply: 2.0 LSJ Engine: Install Powell F35 Stage2 Mounts
