2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Old Nov 24, 2009 | 07:41 PM
  #376
Rubberdude88's Avatar
Big Thanks to "blktrax" - Removal made EASY!!!
Kudo's to "blktrax" - you're awesome!!!
2009 Cobalt LT 2.2 LAP... running a K&N 69-4515TS Typhoon Cold Air Intake. Just followed your "GM Service Instructions" and what an easy removal. Didn't even have to remove the headlight or the headlight bracket. Did what you advised... removed the rim, removed I think 7 bolts holding the splashguard in and the 1 plastic pin, pulled the guard back, removed the bolt on the resonator, popped the plastic retainer out and bada bing bada boom - It came out. Cleaned the entire area and reassembled the splashguard. Done. Not exactly 5 minutes but for sure under 20 including the jacking of the car!!!
Due to the fact I am already running the K&N, I can't really notice more growl but I am sure that it will now have much better air flow and colder (live in Canada - not short on cold air ) Little bit shocked at the size of the resonator... expected it to be this little pipe. I snapped a pick to give a perspective of the size of it.
Thanks again "blktrax" - on to my next mod!!!
If I can figure out how to add a pic of the resonator, I will and one of my K&N (Looks awesome) - When I try to insert a pic, it asks for the URL of the pic??? Any suggestions?
Old Nov 25, 2009 | 01:58 PM
  #377
shawn672's Avatar
Old Jan 26, 2010 | 05:58 PM
  #378
QueenRahel's Avatar
i just did this. i did notice a slight increase in throttle and sound yay free mod!!!
Old Feb 12, 2010 | 03:16 PM
  #379
AndrewTT's Avatar
Ok so i just got done doing this mod wow what a pain.. I was stuck for about an hour on the plastic pin under the intake.. best thing to do is take the fender well halfway u don't have to take it all the way off..just pull a bit and you can completely see the plastic pin that you've been tugging at for about and hour..Take pliers and pull it out and bam done.But thanks Great mod and a much deeper tone even with my megan racing exhaust
Old Feb 12, 2010 | 03:35 PM
  #380
07cobalt2.2's Avatar
saving this for tonite when i get home from work
Old Feb 13, 2010 | 04:02 AM
  #381
ok got this done, it was worth it, just makes the intake sound deeper at high revs. easy also! about a hr, took me a long time to get the head light back on right lol
Old Feb 17, 2010 | 02:36 PM
  #382
QueenRahel's Avatar
all i did was pull back the fender and backing... was pretty easy!
Old Feb 18, 2010 | 09:09 PM
  #383
alchemist1130's Avatar
does anyone know if this effects emissons testing? I live in like the one of two counties that still have an echeck and i sure as hell dont want to fail it.
Old Feb 18, 2010 | 09:34 PM
  #384
shawn672's Avatar
negative! it wont affect emissions testing at all. im in NY where we have Cali emissions regulations - strictest bullshit ever
Old Feb 18, 2010 | 11:52 PM
  #385
Wink
haha alright thanks! you wouldnt happen to know about CAIs or aftermarket exhaust systems with the emissions would ya?
Old Feb 19, 2010 | 08:43 AM
  #386
m1k3d4h3r's Avatar
did this mod yesterday, well worth it. better throttle response, and definitely a nicer deeper tone.
Old Feb 19, 2010 | 12:15 PM
  #387
shawn672's Avatar
only certain CAI's are "CARB" legal, like the GM one and a few select others. Depends on what state you're in and what type of emissions testing they have. Some states they just hookup a hose to your tailpipe and make sure it's not emitting too many bad gases, in NY/Cali they're a lot more involved (inspection, testing, etc)
Old Feb 19, 2010 | 02:59 PM
  #388
yea i just talked to my local emissions test place and they said as long as the CAI allows the engine to warm up to a closed loop and that the computer must be able to regulate the right air:fuel ratio then it would be ok. Yea my car is a 2006 and they require that all car newer than 1995 be inspected and the computer be tested. so it might be worth a little money to buy an AEM CAI and see what happens. worst case senario, I put the stock intake system on a month before testing. she also said the exhaust system usually does effect emissions so were good there.
Old Feb 20, 2010 | 03:35 PM
  #389
XgunsmokeX's Avatar
did it. ummm not a differnce
Old Feb 20, 2010 | 04:54 PM
  #390
shawn672's Avatar
yep a CAI only increase airflow a tiny tiny amount, hence why you're lucky if you get 5hp (2whp) - it wont have any adverse effects on your emissions testing, nor will this mod (the airbox mod that this post is about)
Old Feb 22, 2010 | 07:14 PM
  #391
Wink
haha yea, so ima go for it, who cares?
Old Mar 7, 2010 | 07:34 PM
  #392
nateboyg's Avatar
just finished. bit of a pain. did it at the headlight used a hacksaw blade lol tok me a min. will test 2marow going to class. cant wait.
Old Mar 9, 2010 | 04:40 PM
  #393
2.2balt's Avatar
So will this make any noticeable difference if I have the GMPP intake? I never really thought to take it out , but if it will make a difference I will. If not, I got better things to do with my time hahahahahahaha
Old Mar 9, 2010 | 04:50 PM
  #394
XgunsmokeX's Avatar
i dont think so. i got a K&N intake and i noticed nothing
Old Mar 17, 2010 | 02:42 PM
  #395
cobythecobalt's Avatar
I just finished taking it out, THAT SUCKED!! I couldn't get the fender thing off to get to the other screw for some reason, so I just took a saw and cut it off! I hope it's worth it, it took long enough! lol
Old Mar 23, 2010 | 01:43 AM
  #396
juan1101's Avatar
im thinking of doing this what do i need to start doing this
Old Mar 23, 2010 | 11:33 PM
  #397
car passed e-check for those who were wondering =)
Old Mar 24, 2010 | 04:35 PM
  #398
XgunsmokeX's Avatar
wtf is e-check?
Old Mar 28, 2010 | 10:05 PM
  #399
Originally Posted by XgunsmokeX
wtf is e-check?
hahahahaha its an emmsions test, some states have it and some dont.
Old Mar 28, 2010 | 10:51 PM
  #400
shawn672's Avatar
of course it did, it only increases air flow by like maybe 1-2%, might be good for like 1hp..
