2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Old Aug 23, 2009 | 02:01 PM
  #351
caocao's Avatar
Somebody should make a youtube video doing this for me cuz im dumb.
oh and here is a video for those having troubles with the headlights ---- http://www.youtube.com/watch?v=y1wJUeuwaUg
Old Aug 31, 2009 | 11:06 PM
  #352
padlock's Avatar
i just did this mod and to be honest i didn't really notice a thing. I dont know if me having the k&n drop in filter has anything to do with it but this is just my opinion. maybe if u just have a stock filter it makes this difference you guys are talking about. Sound and fuel mileage aslo seem to be unchanged.. good wieght reduction tho
Old Aug 31, 2009 | 11:14 PM
  #353
MP81's Avatar
Umm...I had both stock and K&N drop in and it made a huge noise difference...
Old Sep 2, 2009 | 05:35 PM
  #354
nhanson's Avatar
just did it today and from 3-4k rpms it sounds DEEP...was a bitch to get out tho
Old Sep 7, 2009 | 12:29 AM
  #355
dillw33d's Avatar
Just did this mod on my car Friday- I love it! It sounds bad ass when you break the ~3500 rpm mark under load. Dont dick with the headlight way... Just take out the ten bolts or whatever and two clips in the fender well.
(First post btw.)
Old Sep 23, 2009 | 04:56 PM
  #356
HyperMuffin's Avatar
So what is the easiest way to do this?
Old Oct 10, 2009 | 05:50 PM
  #357
LMCobalt's Avatar
I took mine out through the headlight opening. I had to twist it around a little but it finally came out.
I get a real nice deep sound between 2000 and 3000 rpm. Also I have a flowmaster exhaust so maybe that helps. I don't notice improvement in either performance or MPG but it sounds really nice.
Oh, I did this about 3 months ago and haven't noticed any negative issues.
Old Oct 14, 2009 | 11:37 AM
  #358
tonio5555's Avatar
Originally Posted by XgunsmokeX
until i see IAT results i call BS on this truely helping anything
I agree. Sure it might help the sound but who knows the effect on performance.
Old Oct 14, 2009 | 12:14 PM
  #359
shawn672's Avatar
less air turbulence and quick throttle response. IAT's might be slightly higher but I can guarantee the pros outweight the cons. While it may be small, maybe 1whp? The extra throttle response is really nice, and it sounds better to boot
Old Oct 14, 2009 | 06:42 PM
  #360
c4w18's Avatar
i did this and to be honest the "increased horsepower/throttle response" seems like a placebo effect to me...however the sound is definitely noticable from 3 to 4 k rpms.....according to my DIC my mpg went up slighty but I've been doing alot of driving on the highway so that might be the true factor. I'm eventually adding in a CAI or other intake because imo restricted airflow is better than hot airflow from being right next to the engine..
Old Oct 15, 2009 | 01:21 AM
  #361
shawn672's Avatar
I currently own 2 cobalts, one has the mod and one doesn't. You can feel the difference in throttle response between the two. I drive them both about the same amount, there is no bias here
Old Oct 26, 2009 | 10:04 AM
  #362
red2006 ls's Avatar
is this mod just for balts with fog lights in the bumper or will it work on ones with the solid bumper
Old Oct 26, 2009 | 11:47 AM
  #363
shawn672's Avatar
solid bumper too, my LS coupe has a solid bumper and the mod was the same
Old Oct 26, 2009 | 01:38 PM
  #364
red2006 ls's Avatar
i have a k&n cold air intake will this help or hurt the car with the intake on
Old Oct 26, 2009 | 01:48 PM
  #365
shawn672's Avatar
you should have removed the silencer when you installed the intake. if you didn't, it might not make a huge difference, but it might allow that K&N to pickup a little more cold air because that huge piece of plastic wont be there
Old Oct 26, 2009 | 03:37 PM
  #366
red2006 ls's Avatar
how can it get more air when u put the inner fender on it blocks the air unless i need to cut a hole in it for the air to go through do i if so where at
Old Oct 27, 2009 | 12:27 AM
  #367
shawn672's Avatar
theres a big hole that connects where the Air Intake Box used to sit, and where the mushroom looking silencer sits, if you take that out, i bet more air from right below the fender will flow up top there.
again, VERY small difference if any, but if you decrease your IAT's by 10degrees thats not bad either
Old Oct 27, 2009 | 10:41 PM
  #368
mjruiz123's Avatar
I did it today and throttle response is amazing!
Old Oct 27, 2009 | 11:09 PM
  #369
red2006 ls's Avatar
after u take out the box and put the fender on it cuts off the air flow there's no open place for air to come in unless i don't see it
Old Oct 27, 2009 | 11:33 PM
  #370
outtamymind's Avatar
there should be an opening in the lower front portion of the bumper. above the fog lamp for those who have fog lights
Old Oct 27, 2009 | 11:46 PM
  #371
red2006 ls's Avatar
i dont got fog lights
Old Oct 31, 2009 | 05:14 PM
  #372
shobalt87's Avatar
"bugle" mod
-haha first of all you shouldn't have to take the fender off and the factory air filter box has a 2.5inch tube mounted on the bottom of it that one end of the "bugle" resonator fits into. When you put everything back together, the hole is still there, NOT blocked in any way
Old Nov 1, 2009 | 01:14 AM
  #373
shawn672's Avatar
yup, and that hole can now pull in cold air from that big empty space - cold air flows into that space where the mushroom silencer was, through the fascia and other cracks
i wish i had a picture, i'd show ya
Old Nov 16, 2009 | 10:33 PM
  #374
padlock's Avatar
i did this mod a month or two ago and now i changed it up a lil bit a week ago.. i took all the "mushroom" stuff off of the factory tube itself.. so now i just have a plain straight tube that uses the two factory bolt locations. i did this to prevent the possible "sucking in hot air theory".. It sounds basically the same but i think it is better. just an opinion!
Old Nov 21, 2009 | 05:34 PM
  #375
tru2nrtt777's Avatar
I have the solid front bumper and cut slots where the horizontal lines are. You cant see it cause I painted the back part black. I dont really know if that helped any but I like the piece of mind that it isnt relying on the attempt of air coming in from the lower radiator grille.
