2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Take one or the other off, not both. I think it's easier to take the wheel off and pull the fender well lining back. It takes about 30 minutes max, start to finish including jack time.
I did mine yesterday and the thing that took the longest was finding the lug nut that I kicked under the my work bench. Its has a nice sound a response that surprised me a couple times. Now have to work on getting rid of the SAI and I will be good to go.
im working on it now, headlight removed, but i cant get the silencer out for the life if me. im gonna try dremeling it out but its taking forever. ideas? no matter how much i twist and turn i cant seem to get it out without bending the fender.
It's easier to access if you take the front passenger wheel off and pull the fender well lining back.
I just wanted to let everyone know that I completed this mod two weeks ago and am very happy with the results. The most noticable change is the increase in sound, sound almost like a short ram intake when I get on it. FYI, I figured out how to get this thing out without removing the wheel liner. Remove the front passenger wheel and locate two bolts in upper right (they are in a line perpindicular with the ground). Remove these and gently peel back the plastic they were holding. You should then be able to locate the "pin/clip" holding the resonator thing. This is done after removing headlight, airbox, front bolt on resonator thing. Hope I have helped or will help somebody.
Hi, sorry if this sounds but I still don't know what version of the Cobalt I still have...even when looking at the different sections on this forum. I have a 2005 LS coupe..will this mod work on my car??
also, how does this mod do in the cold weather???
you would get an interesting sound.
Rip off the top mushroom looking piece, it just pops off with some firm tugging, then when you get the clips off pull the front bottom of the headlight assembly hole forward slightly.
Last edited by tru2nrtt777; Mar 16, 2008 at 02:47 PM. Reason: Automerged Doublepost
