2.0 LNF Engine: Removing Stock Airbox
Old Jun 11, 2011 | 04:10 PM
jzehren11's Avatar
Tools Need:
• Philips Screwdriver
• Flat Head Screwdriver
• T30 Screwdriver
• ¼” drive socket wrench
• 3/8” drive socket wrench
• ½” drive socket wrench
• 19mm deep socket
• 10mm deep socket
• 10mm socket
• 8mm socket(not really needed but can use for couplers)
• 7mm socket
• T30 Bit
• Jack and Jack Stand(I used the one from the trunk)
Step 1:
Disconnect the battery (10mm socket ¼ Drive)
Step 2:
Open Hood
Step 3:
Unscrew the 2 screws and GENTLY remove. Then disconnect Sensor from wiring harness and then reinstall sensor back into the Intake(Philips Screwdriver)
Step 4:
Remove the vacuum line by moving the yellow plastic piece to the right and then down (Fingers)
Step 5:
Unscrew the Clamp for the intake cover (flat head screwdriver or 8mm socket and ¼” drive)
Step 6:
Undo the retaining clips on the cover (Fingers)
Step7: Gently Remover the cover and Filter and set aside. (Hands)
Step 8:
Unscrew the two nuts (10mm deep socket and 3/8” drive)
Step 9: Unscrew the T30 bolt at the bottom mounting for the air box. (T30 bit or T30 screwdriver)
Step 10: Unscrew the coupler on the turbo. This one is a pain to get to and unscrew (Flat Head Screwdriver)
Step 11:
GENTLY remove the tubing from the turbo and set aside. (Hands)
Step 12: Loosen lug nuts (but do not remove all the way) on the passenger side tire. (19mm socket and ½ Drive)
Step 13:
Slowly Jack up the car (Jack and Jack Stand)
Step 14:
Remove the lug nuts and remove tire (19mm socket and ½ Drive)
Step 15:
Unscrew the 9 screws holding the fender liner In place. Don’t forget the ones under the bumper (7mm socket and ¼” drive)
Step 16:
Remove the 6 push pin retaining clip. Don’t forget the ones under the bumper (Flat Head)
Step 17:
Remove the fender wall lining. Takes a lot of time and finesse. (Hands and some strength)
Step 18: Pull the push pin retaining clip that hold the snorkel up (Flathead Screwdriver)
Step 19: Unscrew the bolt holding in the snorkel up(10mm socket and ¼ Drive) Pic^^^^
Step 20:
Remove snorkel and set aside. (Hands)
Old Jun 11, 2011 | 04:47 PM
TommyP's Avatar
AWD > FWD
Approved. Nice write up!
Old Jun 11, 2011 | 04:55 PM
Dart_SI's Avatar
i think you can also just remove the passenger side headlight and headlight bracket to get to the snorkel. i dont remember exactly, i did it when i swapped my intercooler.
Old Jun 11, 2011 | 05:00 PM
jzehren11's Avatar
Never thought about that, I just didnt know how many bolts were holding it in and where they were placed.
This was my first time ever doing it.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
