Interior: So You Want To Remove Your Radio : A How-To Guide For Removing 05-07 Cobalt Radios
Old 07-27-2008, 10:20 AM
07touringcoupe's Avatar
Originally Posted by OrngBalt
the 07 can't be swapped out with a simple plug and play... their is a different wiring harness.
Would be i able to simply keep the stock radio and get a line out converter to hook my subwoofers up to it?
Old 08-13-2008, 02:15 PM
aniceguy1984's Avatar
Thank for posting this how to guide, it was very easy to take the dash trim apart...
I have an 06 cobalt ss with a single disk dc player...i baught an mp3 radio (stock) off of ebay...so i take it i can't use the wiring harness that goes to my stock radio? Where can i purchase one that will work with the mp3 radio? Has anyone taken their radio to the dealer to reprogram it? If so... how much did they charge? Also, is there any other place i can take the radio to get reprogrammed or does it have to be the dealer?
Old 08-13-2008, 08:36 PM
CobaltDude81's Avatar
a butter knife takes off the side panels just as easily
Old 09-12-2008, 09:02 AM
Rydis's Avatar
How do you remove the larger black cord? I am guessing thats the antenna (sorry this is my first aftermarket install)..I tried following the wire down into the fuse box but it seems to just dissapear, and I dont see a way to remove it from the box...
Edit: nevermind...found it said you just pull it out...but didn't work..so grabed pliers to try, and it jus tpulled the black cable out of the antenna leaving the antenna stuck inside the stock radio so...lol
Old 09-15-2008, 12:44 AM
MikeDirntRulez's Avatar
You know that it disconnects right from the stock radio, right?
Old 04-30-2009, 08:51 PM
09CobaltLT's Avatar
I didn't read many of the previous posts but be careful when installing an aftermarket radio on the 09's. The metra website is wrong when it comes to the antenna harness. its not the GM-20 or whatever its called. For some reason GM decided to use their chrysler option on some of their models according to the guy at bestbuy when i went in asking why my adapter wouldn't work. just a heads up lol
Old 06-02-2009, 07:43 PM
c0balt2007's Avatar
Originally Posted by williamhvx1
does is possible to install a 2007 cobalt factory radio on 2006 cobalt ??? i think the 07 radio is more neat and got mp3 jacks
doesnt matter because GM has each radio coded and programmed to a specific car. you would have to get the dealer to recode it to work in your car.
Old 08-08-2009, 12:26 AM
Ryum's Avatar
Does this guide for removing the trim still apply to the 09s or is it different?
edit: I just got in from taking off the trim that is to the left of the radio... holy crap that little piece of plastic was holding on for dear life.
But I did get all of those off without causing and dmg or even pulling the lil metal piece off so I should be golden tomorrow when I take the trim off that is above the glove box, then the outside of the radio itself then I can finally get that thing out of there and check out the back it.
Old 09-02-2009, 09:02 AM
Shogokuma's Avatar
im going to do that when i get home!
Old 09-02-2009, 02:11 PM
mrfitz's Avatar
How about putting an 09 radio with the usb jack into an 07? Or is it cheaper to instal a Personal Audio Link?
Old 09-14-2009, 02:45 PM
  #36
jakilo's Avatar
Does removing the factory radio mess with the Driver Info Center? If so, how do I keep that? And what exactly does it change?
Old 02-02-2010, 08:10 PM
  #37
JonJon's Avatar
I know that with the pioneer and onstar system you'll lose certain funcition. But with a basic setup you should lose your info bar.
Old 03-01-2010, 02:47 PM
  #38
blegends's Avatar
so it is possible to plug and play a 2007 radio to a 06 cobalt if the dealer reprogrammed it?
and how much is an average reprogramming?
Old 04-11-2010, 02:14 PM
  #39
zerosk8ter83's Avatar
Question
thats what i wanna know to,does anybody know???
Old 04-11-2010, 05:41 PM
  #40
Mr_Slobalt's Avatar
it's a lot of work and not worth it
there's a thread on here somewhere about it, but I can't remember the username
Old 12-27-2012, 06:39 PM
  #41
R.Furgason's Avatar
I know this thread is old but I just bought a new stereo to install into my 2007 Cobalt SS. Does anyone know if I absolutely HAVE to buy the $150 wiring harness adapter?
Old 01-15-2013, 09:51 PM
  #42
slider699's Avatar
barney style lol
Old 01-26-2013, 05:39 PM
  #43
roth's Avatar
ill be giving this a try!
Old 06-10-2013, 09:01 PM
  #44
airbagsystems's Avatar
This worked perfect ! Thank you for the great pictures and step by step detailed instruction. This was about a 15 minute job with soldering and all. Piece of cake! Thank you for the post and pictures.
The Rookie24
01-20-2016 05:14 PM
chefhhr
10-26-2015 10:36 PM
shawnsseries
09-10-2015 08:29 PM
Getaway_Driver
09-08-2015 09:41 AM
Quick Reply: Interior: So You Want To Remove Your Radio : A How-To Guide For Removing 05-07 Cobalt Radios
