All Engines: Spark Plug Change How-To
Old May 19, 2010 | 12:18 PM
  #51
Ion's Avatar
Ion
I ended up going with AutoLite Iridiums after Seafoaming it. AAP didn't have any NGKs in stock. Once I turbo, I'll change out to a better plug anyway.
Old May 19, 2010 | 12:23 PM
  #52
neumannl001's Avatar
Very cool DIYcss9450!!!
Old May 20, 2010 | 12:09 AM
  #53
juice3's Avatar
sub'd
Old Aug 10, 2010 | 01:32 AM
  #54
08'2.4N/A's Avatar
Originally Posted by MasterTech
It's also wise to use anti-seize grease on the spark plug threads, and dielectric grease on the spark plug boots and ceramic portions of the spark plug.
I second this ^ you can pick up little packets at your local auto store
Old Aug 27, 2010 | 12:01 AM
  #55
ssr345's Avatar
Do you need to replace spark plug wires when you do this?
Old Dec 28, 2010 | 07:03 PM
  #56
cobaltdriver07's Avatar
Originally Posted by Cefaln452
do you have to remove the sparkplugs to remove the valve cover?
no you dont have to you only have to take the coil pack off ive had my valve cover off before and it takes about 10 minutes to get off cause of all the bolts and getting the coil packs off but no need to take the spark plugs out to get the cover off and this is true i believe for all model years.
Old May 15, 2011 | 12:36 PM
  #57
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
this guided me through pretty well.. Just had to read it once and I knew exactly what I was doing.
Stock plugs on an 07 ss s/c are NGK???
they were labeled NGK R
pfr6t 10g
Old Jun 1, 2011 | 08:47 PM
  #58
mason753's Avatar
there is one that I can not get to!
Old Oct 7, 2011 | 05:28 AM
  #59
Getaway_Driver's Avatar
Going to be switching my spark plugs soon as well. Good DIY.
Old Oct 7, 2011 | 06:21 AM
  #60
donald's Avatar
would there be an advantage for me to one step colder in a ss/na 2.4 with a few mods like exhaust 3 inch intake need new ones and was wondering if i would get any more power
Old Oct 7, 2011 | 09:57 AM
  #61
Gelladuga69's Avatar
Couldn't figure out what the bit was to cover, thanks.
Old Oct 10, 2011 | 02:34 PM
  #62
BlackyK's Avatar
Can you use the BKR7E's on a stock setup/stock tune or are those 1 step colder?
Old Oct 10, 2011 | 03:12 PM
  #63
Those are also gapped at 0.40, so yeah you can.
I'm using those now on a stock tune.
Old Oct 18, 2011 | 10:30 AM
  #64
BlackyK's Avatar
What's the best way to get to the plugs when 2 of the 4 Torx bolts look like this?
Old Oct 18, 2011 | 11:26 AM
  #65
emiller's Avatar
Drill them out. Its just the cover.
Old Oct 18, 2011 | 12:03 PM
  #66
BlackyK's Avatar
That's what I was thinking it was going to come to heh.
Edit: Drilled them out, install was a cake walk, no hick ups. Started up great. Haven't taken it for a spin yet, daughter is still asleep. But I have high hopes! Any difference over stock?
Old Oct 18, 2011 | 12:40 PM
  #67
What plugs and what gap?
Old Oct 18, 2011 | 01:26 PM
  #68
BlackyK's Avatar
BKR7E's, .40
Old Oct 18, 2011 | 02:14 PM
  #69
BKR7E's, .40
Then, not really.
Those and the AC Delco's are about the same at .40.
The reason people get the BKR7E's over stock, is that they seem more stable at colder steps. Like .32
Old Jan 13, 2012 | 03:19 PM
  #70
Sully20's Avatar
I cant get the Spark Plug cover Off! The Bolts that are used with the T27 are sooooo Rusted/ Stuck I cant break them Loose! Any Suggestions?
Old Mar 4, 2012 | 02:25 AM
  #71
ZZP COBALT's Avatar
hey i just bought ngk iridiums for my car, you cannot gap them, will my car start up fine with the gap that they are set at? I'm not really modded other than an intake 3" downpipe and a magna flow muffler
Old Apr 11, 2012 | 11:22 PM
  #72
g21's Avatar
g21
Any difference for a ss/tc??
Old May 16, 2012 | 01:53 AM
  #73
g21's Avatar
g21
Old Jun 23, 2012 | 03:52 AM
  #74
slickstang01's Avatar
nice write up
Old Jul 2, 2012 | 11:44 PM
  #75
CrashMurphy's Avatar
Is there some extra bit of work that could/should be done to remove the boot on cylinder 4? Being on the far right, there's a lot of extra cables/hoses in the way and doesn't give a lot of room to just pull straight up like the other three, so I think I may have somehow damaged the boot as I'm getting a misfire on that cylinder now.
