2.0 LNF Engine: ZZP's ZFR Turbo Installion
#76
Awesome discussion guys. I am planning to install the ZFR this Christmas
I have the Hahn upper charged piping. Does anyone know what coupler the Hahn upper charged piping would need for the ZRF?
Also I am trying to find the banjo bolt gasket. Does anyone know the part number?
#77
Thanks man yeah I found the banjo gasket part number. But for the Hahn Upper Charge pipe, the 5" coupler wont work with it. On zzp's page it says the 5" coupler will only work with a 2" pipe. Hahn is a 2.5" pipe like zzp's, so I am wondering if zzp's 90deg coupler will work for the Hahn..... hummmm Id rather find a 2" to 2.5" 5" long reducer ..... What ever lol Ill try the zzp 90deg coupler and hope it works.
#78
#80
With the welded on extension, you can use any existing charge tube setup that normally connects to the stock turbo. However, since you have the ZZP upper charge tube, you could also run the longer 90 degree coupler.(The $35 option)
#89
Since Regals have the charge tube bolted directly to the turbo, the flange needs to be cut off in order to run a different turbo. We run the normal compressor outlet without extension. Then we use a straight silicone couple over the charge tube.
#94
Are there any torque specs to follow with turbo install, if so what are they
#97
I ordered a powder coated vc , didn't come with one so mine was easy lol when I tapped out the fitting for the Powell PVC upgrade, came right out. Tried it on old vc I have sitting there. Not so easy lol
#98
where is everyone getting the coolant banjo gaskets from? crate engine depot shows no results for that part number and my local dealer would have to order them, just curious.
edit: NM, i found them at another dealer after 50 phone calls to every dealer in the area lol, also ordered from gmpartsdirect as a last resort before i found them, seems like i would've been waiting weeks for the gaskets, never again ordering from there.
#99
So I just used this to do a ZFR install, love this write up. I, naturally with my luck, had the Injen CAI and Upper Charge Pipe that doesn't fit. So I chucked it and a friend gave me his ZZP Upper Charge Pipe. Unfortunately he doesn't have the coupler for it so I have a make shift one sitting on it at the moment. I just emailed ZZP about the longer coupler but it being my only car I have little to no time.
So, my question is, will the factory coupler work on the ZZP Upper Charge Pipe and ZFR? Cuz I can get that at work. Lol.
#100
