05ss/sc Need Help with what to do next...
Old Apr 14, 2015 | 12:52 AM
YoungThor18's Avatar
Question 05ss/sc Need Help with what to do next...
Hey everyone! I'm pretty new to the car hobby in general and I just got my cobalt 3 months ago.
I've already put a few things on the car which I'm going to start off by listing below.
Hahn RaceCraft 3" full header(shorties....) back exhaust. Was already installed by previous owner
Centerforce DFX Clutch set with pressure plate. Was already installed by previous owner
Ingalls Torque Dampner
ZZP Stage3 kit: 2.8, 60#Injectors
Hurst short throw Shifter
Poly Trans mounts. Was already installed by previous owner
Cross drilled and slotted rotors
Now I have 2 questions, #1 being how much whp/tq do you think my car would put down on a dyno with and without a dyno tune on the existing build.
#2 is what I should do next to the car for optimal gains, I'm only 19 and still in school so I sadly don't have 4k for ZZP's turbo kit :/ and I know I'm not going to be able to put 340+whp without spending big money. I have around $1,000-$1,700 to spend on the car(labor not included) so I'd like to know what and what not to spend it on for best hp gains.
I'd like to say thank you all in advance for taking the time to help me out with this. Looking forward to hearing from you all
Old Apr 14, 2015 | 01:01 AM
turbosmart4's Avatar
Around 250-260 whp
You should add cooling mods.. The more cooling mods, the better...
Last edited by turbosmart4; Apr 14, 2015 at 01:01 AM. Reason: Automerged Doublepost
Old Apr 14, 2015 | 01:13 AM
Around 250-260 whp
Could you please be a little more specific, I have the zzp heat ex-changer on the car. Thanks for the quick reply btw
Old Apr 14, 2015 | 01:22 AM
goaliemo's Avatar
Option B tank, dual pass endplate, and a phenolic spacer.
All of which you can save on labor by doing yourself. I am some-what new to working on cars as well, and doing those 3 thinks only took me a few hours after doing a bunch of research.
Old Apr 14, 2015 | 01:25 AM
Yea the phenolic spacer , option B, and dual pass are great cooling mods... Another thing you might want to check is your IC pump to make sure it's working properly.
Old Apr 14, 2015 | 01:30 AM
goaliemo's Avatar
Good point. I don't know why I didn't mention that.
Old Apr 14, 2015 | 01:51 AM
Okay so out of curiosity because I really don't know much at all lol, why is it that I should get all these cooling mods? After I got the heat ex-changer my car runs at 175, 182 max when doing pulls. I've checked my IC and it's working fine! .
Old Apr 14, 2015 | 01:55 AM
double clutch's Avatar
Coolant temps off the DIC or IAT2 temps? Theres a big difference. If your IAT2 temps are too high then your computer is going to pull timing resulting in loss of power. The cooler the air, the denser it is. The denser the air, the more that can be crammed in. Cool dense air = moar power
Old Apr 14, 2015 | 02:04 AM
I'm talking about what is says on the dash so I guess DIC... also I do have a injen CAI on the car aswell. So do you think getting the dual pass endplate and the Phenolic spacer would do good with the temps, or would you suggest moarr?
Thank you all for the information, I really appreciate it!
Old Apr 14, 2015 | 02:11 AM
I'm talking about what is says on the dash so I guess DIC... also I do have a injen CAI on the car aswell. So do you think getting the dual pass endplate and the Phenolic spacer would do good with the temps, or would you suggest moarr? Thank you all for the information, I really appreciate it!
CAI is not going to do much. Alot of ppl dont care for injen either. Theres really no such thing as too many cooling mods. Some ppl go all out and some ppl do the bare minimum. Its all up to you but dont cheap out and then wind up melting your internals. Imo is better to spend a little more for the peace of mind. You also might want to invest in an interceptor gauge to keep an eye on your temps.
Old Apr 14, 2015 | 02:28 PM
CAI is not going to do much. Alot of ppl dont care for injen either. Theres really no such thing as too many cooling mods. Some ppl go all out and some ppl do the bare minimum. Its all up to you but dont cheap out and then wind up melting your internals. Imo is better to spend a little more for the piece of mind. You also might want to invest in an interceptor gauge to keep an eye on your temps.
Okay so after getting the Phenolic spacer and dual pass endplate would I have to re flash my ecu or would the can tune from zzp still be okay?
Also other than the Cooling mods what should I go with next? Don't think I didn't take the advice on the cooling mods, already have them ordered!
Old Apr 14, 2015 | 02:53 PM
No you dont need a reflash. Option b would be another good mod. Also you can look into getting a meth injection kit
Old Apr 14, 2015 | 03:00 PM
CobaltSS 16's Avatar
best bank for your buck is get a custom tune. canned tunes are ok but usually pretty conservative and not catered to your specific car.
I agree with getting all the mentioned cooling mods. the more efficient/cooler your intake temps are... the more power you can make consistently... especially on back to back runs.
if you have e85 in your area... you can grab 80# injectors and get retuned. You can probably pick up 20+ whp with corn.
Old Apr 14, 2015 | 11:05 PM
What do you mean by "corn"? Also should I get a handheld tuner before thinking about getting meth/tune and which brand should I buy?
Also I've been told even know I have Hahn headers; because they're shorties I'm losing a lot of power compared to something like zzp's midlength/longtube header/downpipe combo, is that true?
Old Apr 14, 2015 | 11:09 PM
What do you mean by "corn"? Also should I get a handheld tuner before thinking about getting meth/tune and which brand should I buy? Also I've been told even know I have Hahn headers; because they're shorties I'm losing a lot of power compared to something like zzp's midlength/longtube header/downpipe combo, is that true?
Corn is Ethanol.
Its a single header for starters. With a shorty you gain low end torque. With a long tube you gain high end torque. A mid length is looked at as the middle between the two.
Old Apr 15, 2015 | 01:16 AM
Corn is Ethanol.
Okay thanks for clearing that up. But I'm looking into tuning the car. Should I get a handheld tuner like a diablo tuner or something before taking it to get a dyno tune?
Old Apr 15, 2015 | 08:14 AM
The best thing to do is to buy hptuners and have someone on here remote tune you. Bluelnfftw can tune lsjs. PM him and see what he thinks. A tuner on here is gonna be better than a dyno tune from a shop that doesnt know our platform all that well.
Old Apr 15, 2015 | 09:13 AM
Okay, thank you so much for the info that you've provided me with.
But I do have one more question lol, do I need to get some handheld thing also or just HP tuners?
Old Apr 15, 2015 | 09:32 AM
No you dont need any handheld tuner devices. Blue can tell you exactly what you need to buy to get started. There are other lsj tuners on here also but none come to mind at the moment
Old Apr 15, 2015 | 09:58 AM
Staged07SS's Avatar
Administrator
Administrator
I suggest you take a little time and poke around this site....
Take a look at the dyno thread as well. Lots of good info in there to help you pick a route to go for the numbers you're looking for.
Old Apr 15, 2015 | 04:29 PM
ionRL_585's Avatar
Cooling mods on a LSJ FTW. The HEATON M62 on a 2.8 pulley is building alot of heat. More cooling means more power possible.
Old Apr 16, 2015 | 12:48 AM
Hey man I tried contacting him on here but no response. Do you know of any other tuners on here that can tune lsj's or you could direct me a link to the correct forum page of a list lol.
Old Apr 16, 2015 | 08:55 AM
He hasnt posted in about a week but hes usually pretty active so im sure he will respond when he gets back. No others come to mind at the moment. Maybe someone will chime in. This is probably a good time for you to do some research to see what mods you want for your power goals.
Old Apr 16, 2015 | 10:48 AM
Okay cool, just wanted to make sure he wasn't an inactive user lol.
As far as mods here's what I plan on doing with the money:
Spacer, dual pass endplate, LS4tb, port SC, HPT and have someone help me out with the tune, hopefully the guy you directed me to lol. I also plan on getting an option B tank I just don't have the funds atm.
Old Apr 16, 2015 | 12:12 PM
I got a ported & polished SC (M62) that should be available soon. PM me if you're interested.
