View Poll Results: What could be most likely
Lack of spark
0%
Bad connection somewhere
0%
Plugs put together in wrong locations
0%
Bad tune/ bad flash to pcm for upgraded parts
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
B207R swap ?
B207R swap ?
So new guy here have taken a look numerous times at threads, and am stumped, i have changed my exhaust cam to a lsj cam, changed all of my sensors, including as yes while i was this deep into my rebuild, my injectors to #60 injectors, on 91 octane, on a 3.0 pulley for the street, for the supercharger, as i have a 05 Chevy cobalt SS S/C,
Now the motor is a saab engine yes, but i have done everything the way it needs to be in order to make this a easy and run able swap, but car cranks and will not fire, has compression, is reading computer, and obd2 scanner, no codes that should keep it from firing... Any input would help at this point, could someone suggest or send a good photo of under the hood? Wiring purposes actually.....
Hi Saab Folks! Im new to the saab community here. Bought 2 9-three's couple of months ago, 1 2010 fwd 2.0t and the opposite 2009 xwd 2.0t. Unfortunately the 09's engine shakes while bloodless begin inside the colder climate. When recognized i got cyl. Four misfire...My assumptions is that it could want a head task due to tender valves. After warmup the automobile runs perfect. My alternatives are that I actually have 2011 b207r engine to buy pending in a salvage backyard for $500 for a change. Is it viable being that I even have an 09? The other alternative is to do a head activity. The vehicle has 86k by way of the manner. Just need to get some input right here earlier than I take any actions. Thank you!!!
192.168.100.1 192.168.1.1
Mike636
How to requests and questions
Oct 24, 2013 06:07 PM
