Engine swap help
Engine swap help
I’m in the process of swapping a 2009 cobalt vvt 2.2 into a 2008 cobalt and I’m looking for some wiring advice. Do I just need the vvt engine wiring harness and ecm? Or will I have to swap out the bcu, fuse box, and everything in between? I’ve tried searching for the answer with very little luck so any help is appreciated. Thanks
Lots of info in this google search. The first 2 results are 2.4 VVT engine swaps into non-VVT. I have heard this swap would be much easier into 09 that had the LAP.
https://www.google.com/search?q=coba...0a%202.2&cad=h
[QUOTE=blu3_v1p3r;7733328]Lots of info in this google search. The first 2 results are 2.4 VVT engine swaps into non-VVT. I have heard this swap would be much easier into 09 that had the LAP.
https://www.google.com/search?q=cobaltss.net%202.4%20vvt%20in%20to%20a%20 2
are the 2.2 and 2.4 harnesses the same?
