Engine swap help
Old Jun 22, 2020 | 09:18 PM
Tyler Ranes's Avatar
Engine swap help
I’m in the process of swapping a 2009 cobalt vvt 2.2 into a 2008 cobalt and I’m looking for some wiring advice. Do I just need the vvt engine wiring harness and ecm? Or will I have to swap out the bcu, fuse box, and everything in between? I’ve tried searching for the answer with very little luck so any help is appreciated. Thanks
Old Jun 23, 2020 | 02:43 AM
blu3_v1p3r's Avatar
There is a thread around here where someone swapped in an LE5 2.4 VVT in to a 2.2 non vvt. I'll see if I can find a link to the thread.
Old Jun 23, 2020 | 03:44 AM
blu3_v1p3r's Avatar
Lots of info in this google search. The first 2 results are 2.4 VVT engine swaps into non-VVT. I have heard this swap would be much easier into 09 that had the LAP.
https://www.google.com/search?q=coba...0a%202.2&cad=h
Old Jun 23, 2020 | 06:09 AM
[QUOTE=blu3_v1p3r;7733328]Lots of info in this google search. The first 2 results are 2.4 VVT engine swaps into non-VVT. I have heard this swap would be much easier into 09 that had the LAP.
https://www.google.com/search?q=cobaltss.net%202.4%20vvt%20in%20to%20a%20 2
are the 2.2 and 2.4 harnesses the same?
Old Jun 23, 2020 | 06:31 AM
blu3_v1p3r's Avatar
from what I have read, it looks like the 2.2 engine harness can be modified to work. You will for sure need to do some wiring. I also don't know about the ECU situation and tuning.
Jrocky
2.2L LAP Performance Tech
39
Feb 3, 2017 01:37 PM
michaelwd
Feb 17, 2014 04:02 PM
badboylb32
Jan 27, 2011 02:40 PM
sidewidnerbiker
Jun 10, 2007 02:58 AM
ckymike
Aug 20, 2006 04:37 AM
